component compile problem
7 years 10 months ago #123036 by Skidloaders1
For a little video action showing the one push turret rotation
7 years 10 months ago #123040 by newbynobi
Replied by newbynobi on topic component compile problem
I do not see, that you have connected the tool changed signal!
So the toolchange loop stays open and LinuxCNC will wait for ever, until the loop is closed.
Norbert
7 years 10 months ago #123058 by Skidloaders1
I am not sure what all the timedelay components are for?
Hi Andy
I'm using the 3 part delay sequence to turn turret with single push on VCP button (or M6 command soon )
Instead of classic ladder
Not a big fan of having pieces of code everywhere.( don't know ladder anyway)
regards Wilfried
7 years 10 months ago #123059 by Skidloaders1
andypugh wrote: The Wieler turret needs the version of carousel from master / 2.8 and then needs the parity and strobe bits connected.
Hi Andy
-With what should I connect the strobe?
-Not sure if I need parity ??? have 4 position turret each with its own sensor
wilfried
7 years 10 months ago #123193 by andypugh
Replied by andypugh on topic component compile problem
That isn't the Weiler turret I was expecting.
The carousel component has jog inputs, do they not work?
7 years 10 months ago #123221 by Skidloaders1
Managed to get the turret (carousel) to rotate with a VCP button
No ladder program used.
Still have a little bug when connecting to spindle-enable,
as the turret lock always requires hydraulic pressure.
Henk helped me to connect it to the iocontrol - M6
Thanks again Henk
will post when completed.(bug free)
PS. Andy I used your carousel component - had to use num_sense= 5 ( I only have 4 sensors)
But it works great, thanks
Time to create page: 0.198 seconds
