- Thank you received: 54
Yes, there is a piston inside and it has to be pushed up and down per cycle. I think Skidloaders1got around this by placing several timers in his hal file.Carousel might work, though I am a little confused about the rotation sequence.
It looks like it needs to open one valve until a sensor triggers, then it needs to trigger a different valve to lock, and that advances one position.
As i understand the piston is shaped in such a way, that the turret reaches next position if the piston is up. So basicly i have to enable Selenoid 1 till next pos is reached, switch selenoid 1 off an 2 on and wait couple seconds and repeat if neccesarry. So appart of 4 pos switches there are only these 2 selenoids and the hydraulic pump that migth want to be checked if it is set to run. I guess it should be a simple script.Is there a sensor to indicate that the piston is at the end of travel, or is it done purely on time?
yes, that is what Skidloaders1 is doing too.To use "carousel" you would need to use something like a one-shot HAL component to pulse the solenoid valves, and at that point there is more happening outside carousel than inside.
hm i see, i was hoping to maybe misuse the orientation parameter, but i have not yet figured out, how all of this works. how i might be able to acces these parameters for example. I guess setting it manually in a textfile is ok too.Note that the "tooledit" programme will not allow multiple tools in the same pocket, and your changer seems to require that. You can edit the tool table with a text editor, though, and get the desired result.
Good question, i think both would be considerable for me. I have read several forum threads, where these approaches and also using classicladder was discussed. I have to admit i am fairly new to the game and have much to figure out still. right now, i don't understand benefits of one or another.Are you more comfortable with G-code or C for the control sequence?
