Dual PID loops with motor encoder + scale encoder per axis
2 years 6 months ago #298553 by TangentAudio
So by that definition, it's behaving more like torque mode because commanded "0" means no voltage and no current on the motor; it will freely spin by hand. But my observations seem to show the command value is changing the drive voltage to the motor in a linear fashion with respect to the PWM value (0 - 80V). Current varies based on motor loading (ignoring small voltage drops).
This is why that quote from PCW caught my eye - he says PWM H-bridge drives appear to work as a hybrid between velocity and torque mode drives. H-bridge seems likely to me as they are simple and relatively low-cost, and this would not have been an exceptionally high-end system back in the 1980s.
So maybe this is all good news? I should be able to make an inner velocity PID loop that takes in commanded velocity from an outer position loop, and uses the motor encoder velocity for feedback.
2 years 6 months ago #298604 by Tinine
Yes, the voltage has to increase to produce more current. I don't want to contradict the "hybrid" statement but for all intents and purposes, it's torque mode and yes it's great news.
Provided that the control system is capable of handling position and velocity control, a dumb drive keeps things simple.
Craig
The following user(s) said Thank You: TangentAudio
2 years 6 months ago #298614 by PCW
I would say a voltage mode drive (PWM)  is more like a velocity drive.
(the inherent velocity feedback from the BEMF makes it so)
At 0 voltage, the shaft _will_ resist turning because it acts as a generator
into a shorted load. In fact, if the PWM and motor had 0 resistance it would
hold position!
This similarity to velocity mode also is illustrated in the tuning which
matches velocity mode tuning in that the FF1 term (that compensates for BEMF)
is critical. (torque mode tuning typically uses no FF1)
2 years 6 months ago #298616 by TangentAudio
Well, I'm as confused as ever.  image missing /media/kunena/emoticons/cheerful.png
2 years 6 months ago #298618 by TangentAudio
Based on my rough experiment where I plotted PWM vs motor voltage/current, my intuition was telling me it behaved more as a velocity drive as well.  Unfortunately I don't have a good enough grasp of the theory to prove it.  Trying to cram the motor theory and controls theory into my brain is going about as well as you would expect.  But I'm learning and starting to understand from an intuitive level.
If we assume it is a velocity-like drive, I'm a bit confused about the topology of the PID loops, especially the inner one in this dual loop scenario.
Rather than the summed dual loop that I diagrammed several days ago in this thread (the one that splits PD and I across the two loops), it seems like it's preferable to have the two loops cascade?  In other words, outer loop takes a position command from the axis joint and uses the linear scale encoder position value to close that loop.  The output from the outer loop would be a velocity command fed into the inner loop, which would use the velocity from the motor encoder as its feedback.
Here's my main point of confusion, however: wouldn't the output of that inner loop would be a torque command and not a velocity command?  How do we use that when the PWM drives seem to expect a velocity input.  Am I wrong in my understanding that the output of the loop is the derivative of its command/feedback ?
2 years 6 months ago #298619 by Tinine
I use H-Bridge drivers for my desk-top motion developments (I design motion controllers).
With no motor command, they freely rotate.
When the loop is closed, I absolutely need the D-term (of the PID) or I have unacceptable overshoot.
These are the characteristics of an industrial drive in torque-mode (aka: current mode).
Craig
Time to create page: 0.269 seconds
