Dual PID loops with motor encoder + scale encoder per axis
2 years 6 months ago #298646 by Tinine
Friday night and I have a date with a certain cask ale. This is fascinating stuff. Back in the am.
Cheers,
Craig
2 years 6 months ago #298651 by PCW
A velocity loop maintains commanded velocity which can be anything including zero velocity. The drive responds to disturbances to maintain commanded velocity including zero velocity. The actual RPM makes no difference. Turning by hand when commanded velocity is zero, constitutes a load disturbance. IOW the velocity loop won't allow it.
Actually it will, it will just drag with a velocity and loop gain dependent torque.
This is precisely what a shorted PM motor will do (Same as PWM with 0V applied)
This is because of the inherent velocity feedback. It will have lower equivalent gain
than a velocity mode servo but its still chiefly velocity mode.
2 years 6 months ago #298652 by TangentAudio
And yet, with zero command, you can rotate the motor by hand, right?
Correct.  0 PWM command feels no different than if the drive is unplugged.
It does occur to me that this could be an artifact of how the input to the drive works.  It's offset PWM on a differential line driver.  So 50% duty cycle = 0 output.  0% = -100% output, 100% = 100%.  However it does NOT have a separate enable signal, it uses the lack of PWM to shut itself off, which I assume is A=B on the differential inputs.  It only occurs to me now that maybe it interprets 50% duty as "off" as well.
2 years 6 months ago #298655 by PCW
0 PWM should be the same as 0V which means the motor should resist applied
motion (because its acting as a generator into a shorted load). This may not be apparent
for very slow motions but if you spin the motor, it should resist.
2 years 6 months ago #298656 by TangentAudio
OK, I just re-tested and I was mistaken.  I hooked the X motor belt back up to the table, which still has the manual handle.  It's much more obvious with trying to move it fast via the handle.  I can confirm that it does resist as if the motor is shorted when the drive is enabled and has a 0 PWM command, just as you said.  When I disable the output (which disables the diff line driver output), it goes slack again just like the motor is unplugged.
2 years 6 months ago #298659 by TangentAudio
I'm sure it's obvious, but maybe it's worth stating that while it does resist being turned in the 0 value PWM open loop state, it's not in the same way that a closed loop system would fight back. It's more of a modest drag/braking action.
Time to create page: 0.398 seconds
