Dual PID loops with motor encoder + scale encoder per axis
2 years 6 months ago #298661 by PCW
I would say that its the same (resistance proportional to K * velocity error),
but the loop gain (K) is much lower than a typical servo system velocity loop.
The way you can tell that it does not behave like a torque mode drive
is that in a torque mode drive, the current at a given speed would not change
based on motor load.
BTW, you can test torque mode behaviour easily if you have a constant current
bench supply.
The following user(s) said Thank You: TangentAudio
2 years 6 months ago #298663 by TangentAudio
Fair point, it resists but it can only resist so much.
bench supply.
I do have a bench supply that can do CC, I think I will try that this weekend just to gain some more intuitive understanding.
thanks,
Steve
2 years 6 months ago #298683 by Tinine
It's very straightforward; You tell a velocity-loop ZERO and it's end of story. There are no yeah-buts, ah-buts about it. A velocity loop obeys a command and if that command is ZERO...the drive doesn't decide "oh but this dude is turning my rotor by hand so let it happen"
Will set up a demo tomorrow and video it.
Craig
The following user(s) said Thank You: PCW
2 years 6 months ago #298685 by PCW
False
The velocity loop has finite gain (or it will not be stable)
The force applied to resist motion will be proportional to this
gain * velocity. As long as you move slowly, you can rotate
the motor shaft.
2 years 6 months ago #298689 by Tinine
So how do you calibrate the BEMF gain? Why would our PID filter require a D-term if the motor takes care of it's own velocity damping without a coefficient?
Craig
2 years 6 months ago #298690 by PCW
The D term is required for bare H bridges because you typically want
much higher velocity loop gain than BEMF/motor resistance supplies.
Time to create page: 0.321 seconds
