Ubuntu Bugs steppgen in 10.04
14 Mar 2011 20:00 #7823
by radekB
Replied by radekB on topic Re:Ubuntu Bugs steppgen in 10.04
Please test this configuration is 10.04 and EMC version 2.4.6 or lowest. And 2.4.5 and the highest.
thanks
Radek
thanks
Radek
14 Mar 2011 20:15 #7824
Replied by PCW on topic Re:Ubuntu Bugs steppgen in 10.04
Can you try setting the stepgens maxaccell to a reasonable value (say 10% higher than the mechanical maxaxcell)
14 Mar 2011 20:24 #7825
by radekB
Please test and this configuration is a software stepgen and do the same (joint folloving error).
Radek
Radek
14 Mar 2011 20:30 #7826
by radekB
This is also a very strange behavior. One and the same PC.
RADEK
RADEK
14 Mar 2011 20:36 #7827
what is you max latency?
14 Mar 2011 20:42 - 14 Mar 2011 20:46 #7828
by radekB
Last edit: 14 Mar 2011 20:46 by radekB.
14 Mar 2011 20:49 #7829
by radekB
14 Mar 2011 20:54 #7830
by radekB
14 Mar 2011 21:03 #7831
Can you chart what works and what doesn't work? with Ubunto, EMC versions listed and all using the same HAL/INI files? This will be hard to find without very specific information
14 Mar 2011 21:11 #7832
by radekB
"Can you chart what works and what does not work?"
Please how to create such a graph and how to proceed in order to make sense and you understand well?
RADEK
RADEK
Time to create page: 0.632 seconds
