Ubuntu Bugs steppgen in 10.04
14 Mar 2011 21:40 #7837
Replied by PCW on topic Re:Ubuntu Bugs steppgen in 10.04
I dont mean a graph I just mean a text list of what works and what does not work like this:
OS VER EMC VER HARDWARE OK SYMPTOM
U8.04 2.4.3 PARALLEL PORT YES none
U10.04 2.4.6 PARALLEL PORT NO FOLLOWING ERROR
etc
etc
14 Mar 2011 22:04 #7839
by radekB
Replied by radekB on topic Re:Ubuntu Bugs steppgen in 10.04
U8.04 no problem even with the latency nor stepgen. It works both software and hardware stepgen.
U10.04 a strange latency. Using the Base period + hostmot raises a fatal conflict.
Stepgens I work weird. Using EMC version 2.5.0 and above, no used at all, evokes folloving error.
15 Mar 2011 13:33 #7853
Can you give more specific information including max latency in working and non working cases"
When you say base thread causes fatal conflict, what is the error?
and is the basethread actually used? (is an addf xxx basethread statement present)
There is a known bug with _unused_ basethreads and HostMot2
Have you tried setting the stepgens maxaccell value?
What motherboard are you using?
The reason I ask these questions is that its not easy to duplicate this problem
I have EMC 2.5pre on Ubunto 10.04 and testing with a 5I20 and the supplied hm2-stepper
configuration works fine on my system
16 Mar 2011 01:44 #7869
Replied by cmorley on topic Re:Ubuntu Bugs steppgen in 10.04
In my case I have tried the hm2 stepper sample config.
I tried it with master it follow errors quickly.
on 2.4.6 it seems fine.
both use 8.04.
I will edit my personal config to run on 2.4.6 and try it later.
both use 8.04.
16 Mar 2011 01:52 #7870
Is this with the same config files in both cases? as the sample config may have changed
16 Mar 2011 04:20 #7873
Possible it's different. i didn't check.
but I modified my personal config to remove the mux16 (which 2.4 doesn't have) and it seems to jog fine.
I should make a nice clean usable in both versions config, to test with. I'll get back to you.
16 Mar 2011 05:25 #7874
ok made a plain one in 2.4 then tried it on master (though a slightly old version)
seems to jog fine in 2.4 but in master the X axis follow errors, usually in the negative direction.
The other axis seem to jog ok but thats cause the follow error values are different (larger)
16 Mar 2011 05:36 - 16 Mar 2011 05:40 #7875
by mduzi
Replied by mduzi on topic Re:Ubuntu Bugs steppgen in 10.04
Yes I agree, I have other results ...
Here are the results of today's tests.
Anyway EMC ver. > 2.4 has a bug, sorry
Last edit: 16 Mar 2011 05:40 by mduzi.
16 Mar 2011 05:42 - 16 Mar 2011 05:44 #7876
by mduzi
Last edit: 16 Mar 2011 05:44 by mduzi.
16 Mar 2011 05:44 - 16 Mar 2011 05:45 #7877
by mduzi
Last edit: 16 Mar 2011 05:45 by mduzi.
Time to create page: 0.308 seconds
