disable home button while running
net Xhomesw => or2.0.in0
net Zhomesw => or2.0.in1
net XZhomesw or2.0.out => axis.0.home-sw-in axis.2.home-sw-in
attached is the whole file
the end mill is moving(right now at 240ipm)
I have no idea what is happening with the homing, other than that it seems to work OK on real machines.
Do you have any offsets in the tool table?
can i use halui (home_all) in the mdi-command =
in the ini ? still trying to make that last button and i can't seem to get the
machines' state
net vcp-btn and2.4.in0 == pyvcp.home-all
#net link-home and2.4.in1 halui.machine.on
net zero-all halui.home-all == and2.4.out
net home-in-manual and2.0.in1 and2.1.in1 and2.2.in1 and2.4.in1 == halui.mode.is-manual
i want to add a +/- jog button. "is" there such a thingy ? figuring the connections will be fun
and can i make the height smaller the 1? anything less faults.
Maybe the jogwheel?is there a pyvcp button or something to increment jogging. besides a button with a + sign
www.anderswallin.net/2010/08/axis-with-pyvcp-jogwheel/
You can make all text smaller, which may do the trick.and can i make the height smaller the 1? anything less faults.
System->Appearance->Fonts_Tab->Details->DPI setting.
changing the font by DPI, doesn't change the font in the buttons/labels font
it does change "axis" title bar
the buttons/labels smaller. not the fonts.
