- Thank you received: 1480
Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
9 years 8 months ago #88736
Replied by Todd Zuercher on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
QAn and /QAn are the terminals on the 7i77 for the analog control signal wires. For example QA0 is pin #1 on TB3 of your 7i77, and /QA0 is pin#2.
- new2linux
- Thank you received: 9
9 years 8 months ago #88737
by new2linux
Replied by new2linux on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Many thanks Todd!! I believe all the TB3 signal wires were tested and teased out for the proper location in my earlier (prior to the miss wire) and I think a big part of that you helped with. I can research how we got the current locations if needed.
many thanks again!
many thanks again!
- lakeweb
- Thank you received: 23
9 years 8 months ago #88740
by lakeweb
Replied by lakeweb on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Hi new2linux,
Do you have the servo amp make and model? As Todd says, that is a strange voltage requirement to make the motors move.
Best, Dan.
Best, Dan.
- new2linux
9 years 8 months ago #88741
by new2linux
This is the only info out there, on this model:
www.southwesternindustries.com/media/manuals/24923_manual.pdf
I am working to verify the voltage and amp settings, keeping in mind the max amp is no more than 2000 Ohms. as per Todd's suggestion.
- lakeweb
9 years 8 months ago #88743
by lakeweb
In that manual, page 68, 69, there is a picture of the motor drive module. There should be a make and model number on that module.
Best, Dan.
Best, Dan.
- new2linux
9 years 8 months ago #88744
by new2linux
Many thanks lakeweb! I don't know if there is any other info out there. This is on the power supply.
SouthWestern Ind.= Manufacture
ProtoTrak Plus=model
15047= part #
MD1-M1568=serial #
Many thanks for all the help!
15047= part #
MD1-M1568=serial #
Time to create page: 2.767 seconds
