- Thank you received: 9
Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
- new2linux
9 years 7 months ago - 5 years 10 months ago #88957
by new2linux
Replied by new2linux on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Many apology. My intent 1.6v.
For pic of drive look at link or try paste:
forum.linuxcnc.org/media/kunena/attachme...712/IMG_0742_1-2.JPG
MagneTek
Motor drive p/n 15028R
p/n22241000
model: 4020D-143
many thanks!!
Motor Data Sheet
MagneTek
p/n22241000
model: 4020D-143
many thanks!!
Motor Data Sheet
Last edit: 5 years 10 months ago by new2linux. Reason: Add motor data sheet
- Thank you received: 1480
9 years 7 months ago - 9 years 7 months ago #88962
Replied by Todd Zuercher on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
No, that is the motor, and it has nothing to do with the drive other than it is powered by it.
You should be applying your test voltage between two of the terminals on control input of the amp (With regard to servos that are more complex than a simple amp often called the "drive" because it is what drives the motor.)
Here in the old thread you took a picture of the terminal in question.
forum.linuxcnc.org/media/kunena/attachme...21712/IMG_0813_1.JPG
In that picture either the red and green wires, the red and white, or the white and green is the pair you need to apply the test voltage to. You need to test to see what does what.
You will also have to have the two terminals that were connected with the black jumper wire connected by a jumper to enable the amp (drive).
Last edit: 9 years 7 months ago by Todd Zuercher.
- new2linux
9 years 7 months ago #88991
by new2linux
My many thanks go out to: Todd Zuercher, andypugh, tommylight, PCW, lakeweb and bevins for your invaluable advise, unwavering support, humor, honesty and it is with great regret there has been a most regrettable error on my behalf and I have managed to goof up the "x" axes of the amplifier. Todd the pic you referenced is correct as to my method with exception a meter was placed where the variable power supply gator clip-on leads came together with a length of the gray with red plug. No smoke, I think it is very likely when I turning off variable power supply with protrak amp connected.
I have no change in the lights on the protrak amp as to to indicate any error, but cannot get the servo to move at the same value (in the 1.4 to 1.5v range) from "x" & "y" currently, only the "y" axis will move. I have looked at plug interface to cabinet, swapped out center (see link the big blue cylinder in the center) capacitor with its psb, checked the fuses. I did not want to wait any longer to get this out. I would truly like to thank each of you for your time. I will be looking for another ebay I fear. If there is something I am missing?
forum.linuxcnc.org/media/kunena/attachme...21712/IMG_0816_1.JPG
Many, many thanks to all!
Thanks to the forum!
9 years 7 months ago #89001
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationI don't remember if you said what parts you replaced after your first accident with miss-wiring the transformer.
Did you replace, or repair one or both of the servo amps? Which one? Did you have to spend a lot to find a replacement?
It may be advisable to just cut your losses with these old amps that are undocumented, rare, and probably difficult and expensive to replace, And get something that is common, well documented and easy to use. Something like these.
or
and a simple power supply should work for you.
Hopefully if someone has a better idea for a better amp replacement they will chime in.
or
- new2linux
9 years 7 months ago #89004
by new2linux
Many thanks Todd! Could not find anybody to fix or repair, I purchased "used as where is" and it was high $ enough, from ebay. If you thought the components you describe would work with my servo and power supply I would give it a try.
many thanks!
many thanks!
- lakeweb
- Thank you received: 23
9 years 7 months ago #89018
by lakeweb
Replied by lakeweb on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Absolutely, if your amp is fried, Todd's suggestion is the way to go. I found a few sales of your amp, all were in the $1000 range. And read Todd's list, these things are undocumented. The second link won't work for you, it was for a brushless motor. You want a brushed servo driver. Those Advanced amps are a dime a dozen used. So if you goof one up, it won't cost you like that Prototrak.
If you decide to dump the Prototrak, you will get help here with the power supply you need. Chinese power supplies run less than ten cents a watt. I used them to get a friend's off grid charging going. Link to Off Grid Charging
You won't have to modify the supplies, This was a special case for battery charging. It is that the price point is so attractive.
And everything will be clearly documented. You will get explicit help on how to hook these things up.
Best, Dan.
Best, Dan.
Time to create page: 1.921 seconds
