Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
9 years 7 months ago #89020 by Todd Zuercher
Replied by Todd Zuercher on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
lakeweb wrote: The second link won't work for you, it was for a brushless motor.
Although it is a bldc amp, it can still be used with a single phase brushed motor. You just only connect the A and B phase of the drive to the motor, and disable the comutation. This drive has the advantage of being able to use the digital incremental encoder feedback for the velocity feed back, so you don't need to have a tachometer to close the velocity loop in the drive.
9 years 7 months ago - 9 years 7 months ago #89039 by new2linux
Many, many thanks to Dan & Todd for a much better day with this great news!! It is hard to express my gratitude to you gentlemen! For those like myself that are "electronics challenged" (some of you others, may not use that description) as you followed along it can get ugly quick, sometimes w/o visible signs as to what is goofed up, so self repair is usually not an option. I plan to order at least 2 maybe 3, (need 1 for each axes).
Dan, I read the "off grid charging" looks very cool to me, I also can appreciate the life style, and think that part is pretty cool too.
Many thanks for all the help!
Edit: ordered today will be here later this week ,I hope. Thanks again!
Last edit: 9 years 7 months ago by new2linux. Reason: update
9 years 7 months ago #89042 by lakeweb
Hi Todd,
Thanks. I had no idea you could shut off the commutation. And good point about the feed back. He does have digital if I recall the old thread correctly.
Best, Dan.
9 years 7 months ago #89233 by new2linux
I have received the AMC (Advanced Motion Control) servo amplifier today, they look "like new". Reading parts of the manual leads from the large DC transformer (power supply) will go to each amp. These leads should be separate to each drive, short, heavy and twisted to reduce inductance.
Will I need to mount the capacitor (the big blue one) with its PSB, and go from there to the amps? Should the fan be mounted in the encloser like the ptrak?
The + REF IN & -REF IN (pin 4 and 5) are the leads from DRV O & DRV 1. This are the only leads (control low 1.5v) that will be used, is this correct?
The power supply leads connect to the green terminal block at the bottom, the heavy twisted ones. Is there something else I should be thinking about getting organized?
Many thanks to all who have given support!
9 years 7 months ago #89236 by andypugh
Can you explain what you mean by DRV0 ? On which board is that?
I would rather expect +REF IN and -REF IN to connect to only one 7i77 output.
Do you have tachometers on your motors? I can't remember (I struggle to separate all the threads here in my head)
9 years 7 months ago #89246 by new2linux
andypugh, thank you! I should clarify, DRV 0 & DRV 1 ( TB5 ) on 7i77, the question about the tachometers, I have never seen or come across any reference to that.
forum.linuxcnc.org/media/kunena/attachme...21712/IMG_0816_1.JPG
If you look to the center and see the blue and white leads (with the small wire tie) attach to a PCB (printed circuit board) attached to the top of the large blue capacitor (this is a unit); the other end of these leads go to a square devise (a rectifier. I think) and then to the transformer. All of this needs to be used as an assembly, just checking. And the brown and white leads are the leads to the respective new (AMC) amplifier on the (HIGH VOLTAGE 5) & (POWER GND 4) position. The leads going to the drives are the (-motor 1) & (+motor 2) the green block at bottom. Just trying to understand all that needs to be attached.
Many, many thanks to all!!
Time to create page: 1.677 seconds
