Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
9 years 5 months ago #92813 by Todd Zuercher
Replied by Todd Zuercher on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
I thought we determined FF1 should be around 25.
At this point I thing setting I to 0 until you get a better handle on whats going on would be a good idea (I is usually the last thing to tune).
What happens if you increase D (try 30, 40, 50, 60) and show us the results?
9 years 5 months ago - 9 years 5 months ago #92814 by new2linux
Todd and tommylight, Many, many thanks!!
Attached are several screenshots, as the P goes up the f error goes down, up to a point where it slows.
many thanks!
Last edit: 9 years 5 months ago by new2linux. Reason: spelling
9 years 5 months ago #92821 by Todd Zuercher
That would be expected behavior. Increasing P will decrease following errror, but will also increasingly become more and more unstable, until at some point it goes completely out of control.
You need to increase D until you only have one small bump of over shoot, instead of the half a dozen (or more) wild oscillations you have now. If you find a point where increasing the D causes the system to become unstable, set D to about 2/3s the value for D that made it unstable and you will have to reduce your P until those oscillations are under control. (The I should be set to 0 while doing all this.)
Then use FF1 to get the cruising following error as close to 0 as you can.
Then use FF2 to try to smooth out the error during acceleration as best you can.
9 years 5 months ago #92828 by new2linux
Todd, thank you!!
Attached are a few screenshots, I have tried several settings, this is the best so far!
Many thanks!!
9 years 5 months ago #92829 by Todd Zuercher
Too much FF1. (causing you to have a negative following error while cruising.)
Does more FF2 reduce the following error on acceleration further?
(I think there is still too much over shoot, so more D and/or less P. it will be hard to tune the FF2 until you get the overshoot under control.)
9 years 5 months ago #92830 by Todd Zuercher
It is also possible your your max acceleration could still be a hair too high, causing a big following error during acceleration because the motor just can't quite catch up to the commanded position.
Time to create page: 0.317 seconds
