- Thank you received: 1480
Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
9 years 5 months ago #92918
Replied by Todd Zuercher on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
In this image
forum.linuxcnc.org/media/kunena/attachme...iniacc10.0vel1.0.png
you were able to invert the following error spike during acceleration. This tells us that you should be able to almost completely zero it out by finding just the right amount of FF2 to apply.
It looks like you will eventually find a very well tuned set up. Don't be afraid to experiment with higher maximum velocities. You may find that you can achieve as high or maybe even slightly higher rapid travel rates than you had with the original control. The limit will be the maximum voltage of your servo power supply. The limit for your max acceleration is the maximum current your servo drives can supply. It is probably best to leave a little headroom here because under load the current needed will be higher (In other words, it won't be able to accelerate as fast under load.)
- new2linux
- Thank you received: 9
9 years 5 months ago #93023
by new2linux
Replied by new2linux on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Todd, many thanks for all your help!
Attached are a few pics of the best yet of x and y axes traces. The max acceleration helped a great deal, will post .ini file next time. How do the axes trace look, both are the same "gain" scale, the f.error I can move/shift the 0.0 of the trace, but not having a lot of luck reducing the spike. The trace will vary about 1/10th of the scale w/o changing any settings, just push jog again.
Many thanks! Your comments/suggestions are warmly welcomed.
9 years 5 months ago #93024
What happens to the spike, with FF2 set to about 1 for the X axis and about 0.1 for the Y?
- new2linux
9 years 5 months ago - 9 years 5 months ago #93027
by new2linux
Last edit: 9 years 5 months ago by new2linux. Reason: clearify
- new2linux
9 years 5 months ago #93030
by new2linux
9 years 5 months ago #93032
Looks pretty good. Congratulations. Now you just need to get that Z axis hooked up.
Time to create page: 2.092 seconds
