- Thank you received: 9
Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
- new2linux
I have got it, just as you say:
" Imagine if you were watching the machine milling though a camera rigidly mounted to the table instead of standing beside it. "
That is the best way to describe, many thanks for your help, I am very grateful to you and so many, many others for all the guidance.
Now what is it I need is to pause, for tool height change? Is this a "g" code edit, or a post processor issue, or something more?
many thanks!
Edit: If I have read correctly the work around is to put "auto tool change in" in the g code or break code up in to smaller sections that allow for the need to raise "Z" axes at each (as in the sample, each letter of the logo) section of letters that make the whole logo.
- new2linux
I am very grateful to each of you for your help! I am also very thankful for this forum, and all who support it.
Many, many thanks!
- Thank you received: 1480
new2linux wrote: Thanks!! Todd
many thanks!
I thought I typed a reply to this before, but I must not have clicked submit.
I think this would technically be more of a CAM / postprocessor problem, But it should be possible to create a script that could automatically insert an M0 code to pause the machine where ever there is a change in Z depth.
I don't think the manual tool change idea is the answer, because it would only stop where tool changes are commanded (not Z depth changes).
I think most of your g-code files are going to need to be optimized specifically for your manual Z application.
Your machine has a DRO feed back for the Z axis? And you have an extra amp? Then all you need is an appropriately sized DC motor and a way to connect it to the Z screw and then you'd have true 3-d capability.
- new2linux
The DRO is the Prototrak type that has a (steel) wheel, running against steel, that turns an encoder, just not now. I will start to keep an eye for the correct price or OEM so it bolts on. There are the "fixed height or set screw" collet issues, so just buy the most popular sizes 1st is the work around. I have a copy of (hopefully, as not to be shamed out) of Bobcad v 23, I used with the Prototrak, is there a more friendly or preferred CAM, I have good model/data input from autocad or solidworks, just need to automate this part a bit.
Many thanks!
- MarkD2
Did you ever get the machine running on linuxcnc? If so can you share the connection diagram for the controller to the 7i77.
Thank you
