Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
9 years 5 months ago #92838 by new2linux
Many thanks!
Attached are a few screenshots, p=3600 and p=5055, I tried to tune each as best it could be. Used low values, went higher and then went to best values.
many thanks!
9 years 5 months ago - 9 years 5 months ago #92843 by new2linux
Many thanks!
This is screenshot going max acceleration (in the .ini file) from 17.0 to 16.5.
I need to look at these to ponder some myself.
Many, many thanks!
Edit: Compare the bottom pic of this to top pic of prior post, all settings the same except ini file. I believe the prior setting (17.0) is best, less f.error.
Last edit: 9 years 5 months ago by new2linux. Reason: after review
9 years 5 months ago #92847 by andypugh
new2linux wrote: This is screenshot going max acceleration (in the .ini file) from 17.0 to 16.5.
I might be tempted to try 8. See if that makes the machine seem sluggish. Unless you plan on doing a lot of 3D-profiling work you might not need to be hard against the machine physical limits. And even then you could probably limit the fierce acceleration to the (light?) Z axis.
9 years 5 months ago - 9 years 5 months ago #92852 by Todd Zuercher
Replied by Todd Zuercher on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Can you go back to having the hm2_5i25.0.encoder.00.velocity shown on the trace as well, so we can see how well the actual velocity matches up with the commanded.
(Remember you are trying to make the following error trace be as close to a flat line on zero as you can, not make it follow the the velocity command trace.)
In the last copy of your ini file that you posted on May 5. You still have the Max_acceleration for X set to 30 (you have Y set to 17)
These last halscope traces you posted were done on the X axis and they seem to imply that the X axis acceleration is still too high.
[strike]It is showing nearly a 1 inch following error during the acceleration phase of the move.
[/strike]
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 0.80
MAX_ACCELERATION = 30.0
P = 6000
I = 50
D = 40
FF0 = 0
FF1 = -0.2
FF2 = 18
BIAS = 0
DEADBAND = 9e-05
MAX_OUTPUT = 0
ENCODER_SCALE = 27500
OUTPUT_SCALE = 10
OUTPUT_MIN_LIMIT = -10
OUTPUT_MAX_LIMIT = 10
MIN_LIMIT = -11.0
MAX_LIMIT = 11.0
HOME_OFFSET = 0.0
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 0.72
MAX_ACCELERATION = 17.0
P = 1000
I = 50
D = 23
FF0 = 0
FF1 = 6e-05
FF2 = 0.0001
BIAS = 0
DEADBAND = 1e-05
MAX_OUTPUT = 0
OUTPUT_SCALE = 10
MIN_LIMIT = -5.5
MAX_LIMIT = 5.5
HOME_OFFSET = 0.0
Last edit: 9 years 5 months ago by Todd Zuercher.
9 years 5 months ago - 9 years 5 months ago #92854 by andypugh
Todd Zuercher wrote: It is showing nearly a 1 inch following error during the acceleration phase of the move.
Isn't that 6 milli-inches? Or am I misunderstanding?
(I had been interpreting it as microns, and thinking it looked quite good)
Last edit: 9 years 5 months ago by andypugh.
9 years 5 months ago #92855 by new2linux
Todd, thanks for your kind advise! Yes the ini file was edited and saved.
andypugh, thanks for your thoughts, this is just 2 axes machine, currently. The rapid travel seems just a little slow, but I can live with it.
many thanks!!
Time to create page: 0.599 seconds
