Retrofitting a 1986 Maho MH400E
- db1981
- Thank you received: 276
26 Feb 2018 08:21 #106528
by db1981
Replied by db1981 on topic Retrofitting a 1986 Maho MH400E
Hello Mark
Q1 after your question i noticed that your power schematic on page 1 of this thread is a little different to the 700C. There have to be made some changes because your brake for toggeling is engaged by the triangle Relais. Can you tell me what kind of device 1K6 is and what its contacts do?
Q2 I let the Heidenhain Panel stay in the Machine and it has these buttons for manual milling, simple set the auto input fix to true.
Q3 No, this has to come out from the NC Programm, following the standart way is that you can not send Axis movement commands from hal,comp or ladder. But i never note about speed changes while the tool is in the material, normaly this comes with an toolchange or a new chapter of your Cam Application.
- RotarySMP
- Thank you received: 595
26 Feb 2018 22:21 - 26 Feb 2018 22:21 #106578
by RotarySMP
Thanks for your help Dominik.
Q1 1K6 is a time delay relay. It is set for 7.5 seconds.
I've expanded the 7 to the 18 gear ratios of the MH400E, entered the resulting speeds, expanded the single gear states list, entered the MH400 States, and expanded the data.pos[N].max_rpm = max_rpm_N+1 list.
Q2 I wasn't sure what you meant by auto input fix.
Thanks clarifying that you cant do axis motion from a comp, hal or ladder. Is there any standard behavior associated with spindle speed which will need to be deactivated when this COMP is added?
Mark
-available gear states = position count [line114]
-you have to set the rpms for the singles states (so much as position count) [see line 73-79]
-the positions for the single gear states are defined in the Extra_Setup Part line 177 ff.
Mark
Last edit: 26 Feb 2018 22:21 by RotarySMP.
- db1981
27 Feb 2018 09:06 #106609
by db1981
Is the 1K6 Contact wired to an PLC Input?
I then will do some changes for the brake part soon.
I have an hal config for testing/setup the single stages step by step, i will comment it and then post it.
sorry for my writing, but my native language is C/C#/Assembler/Jave/Python etc. then german and unlucky at least english.....
- RotarySMP
27 Feb 2018 20:26 - 27 Feb 2018 20:31 #106660
by RotarySMP
Thanks for looking at that. The MH400E has no PLC.The 1K6 relay controls the 1K7 relay which signals that the spindel is stopped to the NC controller. 1K7 is also the inhibit on the tool changer.
I live in Wien. I can also speak german if you prefer, although it is probably better for the forum to keep this conversation in english.
Mark
Mark
Last edit: 27 Feb 2018 20:31 by RotarySMP.
- db1981
27 Feb 2018 20:35 #106661
by db1981
The intern Philips PLC (gearchange, safty etc.) ...
But now this signal is wired to linuxcnc?
- RotarySMP
27 Feb 2018 22:53 #106681
by RotarySMP
Yes, through the Mesa 7i84.
- RotarySMP
05 Mar 2018 08:22 #106942
by RotarySMP
Still too cold in the basement. I sprayed one coat of green paint ont he control housing, but it will probably take all week to dry.
Mark
Mark
- drimaropoylos
- Thank you received: 40
11 Mar 2018 16:57 - 11 Mar 2018 16:59 #107223
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Last edit: 11 Mar 2018 16:59 by drimaropoylos.
- RotarySMP
13 Mar 2018 18:54 #107290
by RotarySMP
Nice workmanship John. I am laid up with bronchitis, so I haven't been in the basement. Look forward to spring and getting back to the Maho.
Mark
Mark
- RotarySMP
26 Mar 2018 20:02 #107910
by RotarySMP
Moderators: piasdom
Time to create page: 0.368 seconds
