Zenford Zeigler Retrofit
- Thank you received: 4654
To be honest $250 for 5 spare drives looks like an excellent buy. I think I would have already bought it if I was in your situation.
(If you look under "sold items" they seem to fetch decent money, you might even make a profit if you decide to move on to different drives later. But for now I would get the machine working as-is.)
- snoozer77
- Thank you received: 12
I have to head to Melbourne on the weekend. might offer $200 and see how i go. I guess they can only say no.
- snoozer77
Surely i can get 3 drives working with the 9 drives i will have available...
- snoozer77
Got the drives. They ended up being removed from the same machine as i have. That was nice to know. The guy i got them off retrofitted to Mach 3.
I have been playing with the toolchange drive and motor, and have got them operational.
I have also installed linuxcnc on a pc and installed my 5i24 with 7i49 connected.
Was just wondering what process you recommend for doing some initial setup and testing using the 1 drive and motor i have at home? Im using the toolchange motor and drive as it is single phase and i can work on it at home easier.
I have flashed the 5i24 with the 5i24_sv6_7i49 configuration.
Should i now setup a config in the wizard with 5i23 and edit as required by hand?
Will i need a different firmware when connecting 5i24, 7i49, 7i44, 7i84??
Sorry about all the questions. If there is any reading you suggest i do, that would be great.
Cheers
Matt
Does PnCConf know about the 7i49? If it does then everything will probably be fairly easy.Was just wondering what process you recommend for doing some initial setup and testing using the 1 drive and motor i have at home? Im using the toolchange motor and drive as it is single phase and i can work on it at home easier.
Even if it doesn't you have a fairly easy-to-configure set of components (compared to some).
If you can find something like 5i24_RMSVSS6_6.bit then that would be better:I have flashed the 5i24 with the 5i24_sv6_7i49 configuration.
The pin layout looks like this:
github.com/LinuxCNC/hostmot2-firmware/bl...N_RMSVSS6_6_8_72.vhd
I have exactly the right bitfile for your hardware, but it is at home on my lathe. I will try to remember to find out what it is.
That's probably the best place to start.Should i now setup a config in the wizard with 5i23 and edit as required by hand?
- snoozer77
It looks just like 5i24_16_rmsvss8_8 though, but without the encoder / pwm things on the middle connector.
You need to choose 5i24_16 or 5i24_25 based on the size of the FPGA on your 5i24.
The anything with RM and SS in the name will run your 7i49 (I think). I don't believe that you explicitly need 7i49 in the file name.
I have attached my lathe HAL and INI. They will only be partially helpful because I use brushless motors and software commutation and emulate absolute encoders in HAL and only have two axes...
- snoozer77
Been looking at the Hal and ini files you attached. Im looking through the linuxcnc docs to try get a better understanding of what all the code means.
I have flashed the 5i24_25_rmsvss6_8.bit config to my 5i25-25. Im now looking to do a super basic setup using 1 servo motor, drive with Tach input with resolver feedback into the 7i49.
Am i right to assume (which i should never do coz im always wrong..haha) That i could use your holbrook lathe ini and hal files, and modify them to a basic level? i have a set of your holbrook hal and ini files you posted on another forum post (Hardinge HC Bandit Retrofit) that has alot of stuff edited out.
Do you think i should start with these files and remove things like amp enables, limit switches, e stops, toolchangers etc, to get a basic setup to start up. I tried running the files as is, but get an error on startup.
Any thoughts would be greatly appreciated.
Cheers
Matt
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.13
Machine configuration directory is '/home/matt/linuxcnc/configs/Holbrook'
Machine configuration file is 'Holbrook.ini'
INIFILE=/home/matt/linuxcnc/configs/Holbrook/Holbrook.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=touchy
Starting LinuxCNC...
Found file(REL): ./Holbrook.hal
Killing task linuxcncsvr, PID=4683
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/trivkins.ko: Unknown symbol in module
./Holbrook.hal:2: exit value: 1
./Holbrook.hal:2: insmod for trivkins failed, returned -1
See the output of 'dmesg' for more information.
4683
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
halrunloadrt hostmot2
loadrt hm2_pci
loadrt threads
addf hm2_5i24.0.read thread1
addf hm2_5i24.0.write thread1
startloadusr halmeter pin hm2_5i24.0.resolver-00.position
setp hm2_5i24.0.analogout.00.vale 0.2Please Log in or Create an account to join the conversation.
