Leith,
Sorry I have not gotten more up, but I am way behind on paperwork and trying to bid a job this week... stretched thin LOL.
Just to kind of keep you on track, this is what I would be pushing to do.
Quick List:
1) E-stop
2) Proximity Switches (this will be later with Mesa board)
3) Oiler working and/or getting ways and ball screws coated with oil
4) Cap off all exposed wiring in the left cabinet, getting ready for power
5) Check wiring from Disconnect to the Main transformer, then following wiring and cap any exposed A/C power wires.
6) Air working, or temporarily bypass the air switch for E-stop chain. I don't recommend bypassing, you could forget to wire back up.
7) Check all of the wiring in the right cabinet to see if any A/C power needs capping off, or anything exposed like the left cabinet
This gets you close to powering the machine.
More detailed from the Quick List above:
1) Emergency Stop wired in, this is the first and foremost thing to do before firing up the power.... Like I said before this is super easy to do. I would find a way of temporarily mounting a E-Stop and that way you can wire directly into the TB-3 connector. Just simply a loop between two of the TB-3 connectors and the E-stop.
2) You really need the proximity switches wired next, but that will be down the road when you wire up the Mesa board. When you go to wire the Mesa board. E-stop is first and Proximity switches next. Somewhere down the line you will have the table take off and be glad to have either wired to keep from destroying the machine. I actually consider the proximity switches more critical at this stage as you never know what the servo's may do when setting everything up.... but E-stop is a must... safety first.
2) Keep the way oiler in the back of your mind and prep to get it working. You can coat the ways and ball screws with oil before trying to operate the servos, but can't move around much until you get oil flowing. This is critical... that is the life of the machine literally, especially your ball screws.
4) Cap off all of the wiring in the left panel so that you can prep to put power to the mill. If you want to be simple, you can just use electrical tape to temporarily cover all exposed ends/terminals. I am pretty anal about wiring and I usually cut and cap things with crimp terminals (barrels or caps) so there is no chance of touching or shorting anything.... but you should be tearing a lot of that wiring out, as the VFD will have very little wiring.
5) Check the step down transformer wiring and follow it back to the left cabinet. Should actually go back to the disconnect. You should be able to find any other wiring that powered the Parajust board and cap off. Once you figure out the wiring to the transformers and disconnect then you should be getting closer to put power to the machine. When I get a chance I will trace mine, but I am sure it will simply go from the disconnect to the stepdown transformer, and then take off from the step down to a few places such as the servo transformer, the left cabinet for powering the parajust board, and there will be a power leg that goes over to the right cabinet to power the power supply, hour meter, timer for the oiler, coolant contactor, acc contractor and so forth.
6) Air working to get the E-stop chain working. The air pressure switch need pressure to close and make the chain connection for the E-stop loop. I would not bypass it as it is easy to forget and not wire it back up.
7) Follow the A/C wiring into the right cabinet and make sure there is nothing exposed. It should be white and red wires twisted together going through out the cabinet. Such as to the hour meter at the rear of machine, power to the timer for the oiler solenoid, then there will be power to the power supply, power to the line filters, and power to the contactors. There will be another set of red wires that come from the servo transformer to the servo amps, but that is the 80V and separate, but still need to check for anything exposed.
Once you are comfortable with everything, then you are getting close to putting power and seeing what is going to happen. You technically will not get the power working to the servo amps unless the K5 relays are working. This is assuming the aftermarket work was done correctly and tied back into Hurco's original wiring. But once you are close to power, I can tell you what steps to take from there.
Also on a tangent, you may want to find a old desktop computer or whatever you are comfortable using and put LinuxCNC on and start getting use to how it operates. LCNC has a simulator so that you can tinker to get a feel for it. You may have already done this.
Sorry I have not gotten more tonight, but I am super behind on paperwork and got to get things done in the next few days. I will try to get more together, but I have to have a quote together for the Air Force by this weekend, so I am super busy.
I will be back tomorrow, hope the previous post have helped. Up way too late again, LOL.
Robert
