Hi Robert,
Thanks again for the pics and info.
Trying to connect the dots. Various pieces of information with assorted pedigrees.
Here's a little more of the known history of the Hurco. It was owned by Lockheed/Martin. In 2005 it was donated to Colorado State University with a claimed value of $31,000. It was also claimed to be working at this time. It apparently sat in the corner of this CSU workshop for 15 years until they got tired of looking at it and put it up for auction. A friend of mine bought the machine at auction. I'm helping him to try and resurrect the beast.
Its likely the "parajust" spindle controller was the cause of retirement. Not only has it been removed (didn't somebody say the machine was working?), in the documentation I have, there are quite a few notes probably made by some technician trying to fix the thing. And probably they decided the parajust was defunct and given the oddball Hurco controller, retrofitting a new VFD was out of the question.
The left side cabinet is basically a disaster zone. Parts removed, power cord totally disconnected, servo upgrade, a challenge to correlate what's there with the various schematics. I'm not hugely bothered by this. Expecting to install a new VFD. I'll figure it out.
It does look like the DC supply is powered off of 120VAC. Although with what I see in the left hand cabinet, I'm not sure where that was coming from. I need to dig more through the wiring and mystery of the transformer attached poorly to the rear of the machine. This was from the servo upgrade. I don't have any schematics on that. In the short term, if I can power the DC supply and the servos off of 120VAC, that's most convenient. My plan is to get the logic controller and servos working first. Once that's working I can move on to the spindle motor and its VFD. The ultimate goal is to power the machine off of 3 phase 440. Its likely I will need to find a new transformer(s) to generate the 120VAC and the servo drive 80 VAC.
I did find a schematic for the Hurco DC supply. Its pretty straight forward and correlates well with what I see in the right hand cabinet. I recognize the linear regulator part numbers. If I blow one up, I should be able to find a replacement.
My plan is to remove the drive belts from all the servos. This will absolutely prevent any crashing. And facilitate testing of the various limit switches and E-stop buttons. When I re-install the belts, I should have good confidence in the protection system.
Leith
