Replacing Advanced Motion Controls "brush type 12A8 with "Axcent" amplifier
6 years 3 weeks ago - 6 years 3 weeks ago #184994 by new2linux
This is a better pic of what is set how. Current the machine will run 60 "/min w/o joint error. I do not believe the hal scope is complete, the 0 and 1 axes a set as per tommylight excellent tuning advise. I am not shore this is set up completely?
"On the "hal scope" press "1" at the bottom left and chose "joint.N.motor-pos-cmd" by scrolling down, press "2" and find and choose "joint.N.f-error", set it at "auto" and "roll" on the upper right corner.
Last edit: 6 years 3 weeks ago by new2linux. Reason: new screen shot
6 years 3 weeks ago #185060 by Todd Zuercher
For setings for hal scope, I like to look at the joint.N.joint-vel-cmd and and encoder velocity feed back as well as the f-error. Also sometimes it is also helpful to see the pid.N.output. (to be sure you are not ever saturating the command.) Then set the Run Mode and Trigger both to Normal. Set the trigger source channel to the joint.N.joint-vel-cmd and move the trigger level and position sliders to appropriate settings for the move you are testing with. I usualy use an incremental jog using the keyboard (increment length set to a half inch or inch or so) with the jog speed set as fast as I can get and still have a nice steady cruse at the the commanded velocity (not all acceleration and deceleration.) Then adjust the PID parameters according to the tuning tutorials to get the commanded velocity to match the velocity feedback as closely as possible while minimizing the position error. With enough fiddling you should be able to get them to match almost perfectly and the position error to be less than about a half dozen encoder counts.
You may need to play with the vertical gains, Zoom, and horizontal position to get everything nicely visible on the scope. As you improve the tuning you might need to increase the gain on the f-error to better see where you can improve.
The following user(s) said Thank You: tommylight, new2linux
6 years 3 weeks ago - 6 years 3 weeks ago #185090 by new2linux
Todd, Many, many thanks for your help! I have set up the hal scope as per your reply, and included pic of it. I release that as I tune the scale will need to be changed as to get to the necessary quality of the tuning. The only way to move axes that I have found to work is the "+"&"-" like used with jog (use the mouse pointer) and the axes in question.
The scope 1 through 6 are as follows (1,2,&3=x axes 4,5,&6=y axes):
1) joint.0.joint-vel-cmd
2) f-error
3) pid.x.output
4) joint.1.joint-vel-cmd
5) f-error
6) pid.y.output
Many thanks
Edit: I plan to turn off the x axes (the 1,2 & 3 channels, as to see clearer) as to tune the heavy (y) axes 1st. Will use jog to move axes.
Last edit: 6 years 3 weeks ago by new2linux. Reason: Add the plan
6 years 3 weeks ago #185092 by Todd Zuercher
The X axis should jog using the left/right arrow keys on the keyboard, Y axis should be up/down, and Z should be Page Up/Page Down.
In Halscope, work on one axis at a time, Turn off the Y axis pins, and add one for pin "hm2_5i25.0.encoder.00.velocity" (change 00 to the encoder number used for your X-axis). Reduce the gain on the joint.0.joint-vel-cmd, until you can see the cruse section on the screen. Then adjust the gain on the encoder velocity to match. You can then save these settings in Halscope (File/Save Configuration) that you can reload as needed. Save a different configuration for Halscope for each axis you need to tune.
Reduce your P until the over shoot osculations mostly go away. Once you have it smooth, then adjust the FF1 to minimize the following error during the cruse (looks like you may have a little too much FF1 in that screen shot.). Then you can use FF2 to try to smooth out the remaining following error during the acceleration and deceleration portions of the move.
Once you have the Feed Forwards tuned you might be able to add a little more P to stiffen it a bit more without adding too much overshoot.
6 years 3 weeks ago - 6 years 3 weeks ago #185104 by new2linux
Todd, Thank you! The source of the encoder number, is this the correct place? So 00= x axis & 05= y axis. Use a copy and past in text edit or with change? Or will this be inside the Hal file that needs edit?
Edit; I found the other list. Will tune to this. Many thanks!
6 years 3 weeks ago - 6 years 3 weeks ago #185108 by Todd Zuercher
The number of the encoder each axis is using will be dependent on where you plugged each one in to the board. It should be noted in your hal file, and you should be able to see what each is connected to in the Halshow window if you click on them.
That image above is very noisy, turn down the gain and hopefully it will be a bit easier to look at.
Last edit: 6 years 3 weeks ago by Todd Zuercher.
Time to create page: 4.844 seconds
