HURCO KMB-1 Control Update
20 Jun 2025 02:55 - 20 Jun 2025 02:56 #330555 by NT4Boy
Replied by NT4Boy on topic HURCO KMB-1 Control Update
I'm still addressing some old school electronics that needed updating in the VFD, so turned my attention back to the override potentiometers.
When the spindle runs and I read the pot via the 3.3volt Analogue pin 7i92.0.7i71.0.2.input_03, there is a notable hunting in the spindle speed. Not much, but it just doesn't sound steady.
This is down I think to the ADC hopping between bits which is also normal.
I looked at the original Hurco control use of the pots and how the analogue values were read, and note that the conversion to digital was done in a 12 bit ADC. so the increment between bits is tiny in comparison.
In the 7i73 manual. it states:
"OPERATION
ANALOG INPUTS
Inputs 0 through 7 can read analog signal values however only inputs 0 through 3 are supported for analog input by available interface modes. Analog inputs have a range of 0 to 3.3V. Normal resolution is 8 bits. All bits are readable as digital inputs. Note: analog inputs are only accessible in some software modes."
Does this mean I could configure an analogue input to use a increased resolution of 12 bits?
If so How would I do that?
Last edit: 20 Jun 2025 02:56 by NT4Boy. Reason: typo
20 Jun 2025 13:40 #330585 by PCW
Replied by PCW on topic HURCO KMB-1 Control Update
The 7I73 does not currently support any higher resolution  A-D modes,
(I think the issue was exceeded the total serial data available) but
one simple thing to try is to low-pass filter the 8 bit data from the 7I73
in hal before using it to control the spindle speed.
If the flicker is greater than 1 LSB it may also be that you are picking
up some noise in the potentiometer wiper line. You could reduce this
by adding a small (say 1 uF) capacitor from the potentiometer wiper
terminal to 7I73 GND.
The following user(s) said Thank You: NT4Boy
20 Jun 2025 15:20 #330595 by andypugh
Replied by andypugh on topic HURCO KMB-1 Control Update
By experimentation, the Y and X offsets can be entered pressing tool touch off with the wrong axis selected. On a 3 axis mill, as far as I can tell numbers in these columns are ignored.
They are not ignored, but if you have X and/or Y offsets applied when you touch-off then the tool offset anf G54 offsets will cancel out.
XY offsets are not often used on a mill, but some machines have one head and a number of tools that pop down from it, and XY offsets are useful there to account for the different positions of the tool axes.
I suggest making sure that all the offsets are zero in the tool-table editor.
If you do find that you have accidentally put an offset in the wrong axis, then you can MDI
G10 L1 Pn X0 Y0 G43
linuxcnc.org/docs/devel/html/gcode/g-code.html#gcode:g10-l1
Where "n" is the current tool number.
20 Jun 2025 15:53 #330601 by NT4Boy
Thanks Andy,
Since writing that I did manage to inadvertently introduce an axis offset via the tool table, so have become super cautious.
12 Oct 2025 11:42 #336333 by NT4Boy
For too many months I tried in vain to fix the venerable vfd that was the original fitment in the machine and have at last inserted a Yaskawa unit . Tiny thing compared to the old one! But does actually run the motor at the speed commanded without drama and also reverses without needing to stop the spindle. Have also got the Linuxcnc spindle at speed bit to work from the encoder signal.
I think I've been round in circles on the synchronised motion implementation say for tapping.
I believe now that when pncconf writes the hal for a spindle with an encoder, then no additional entries are required to enable synchronised motion. The configuration output has spindle position, speed as well as index enabled pins, and I think that is all that is needed.
The wiki help, to me, implies some specific pin names are required, but after trying to get the suggested ones to work I find that in fact the default ones provided by pncconf work, or at least seem to.. At least I can get a sample G-code file with G33.1 to complete a cycle. Yet to cut metal with it, but nearly there.
I am also confused by the Spindle at speed notion. I can understand that it would be better if the spindle was running before the tool hits the workpiece, and notionally a good idea, but when the spindle reverses in the middle of a tapping cycle, I am guessing that the motion will continue to move as the tool delcels and accels, rather than wait to get up to speed? Must do, but was curious as to what happens under the hood so to speak.
12 Oct 2025 11:46 #336335 by andypugh
Spindle-at-speed only pauses motion for the first feed move after a spindle command (as far as I recall) It definitely doesn;t interfere with rigid taping, for that would be a silly thing.
12 Oct 2025 11:49 #336336 by NT4Boy
I was thinking to my self much the same as I wrote, but I'd reached the point of losing the plot and grateful for the reassurance.
15 Nov 2025 09:43 #338460 by NT4Boy
At last the Spindle is back under control, the new VFD works well, and the rigid tapping cycle executes, so therefore spindle orientation must work....
M19 R120 Q5 simply times out.
Linuxcnc ORIENT Man  explains I need to setup the orientation pins etc.
loadrt orient names=orient
loadrt pid names=orient-pid
net orient-angle spindle.N.orient-angle orient.angle
net orient-mode spindle.N.orient-mode orient.mode
net orient-enable spindle.N.orient orient.enable orient-pid.enable
net spindle-in-pos orient.is-oriented spindle.N.is-oriented
net spindle-pos encoder.position orient.position orient-pid.feedback
net orient-command orient.command orient-pid.command
all good, except for the enigmatic statement at the start:-
"On spindle.N.orient disconnect the spindle control and connect to the orient-pid loop:"
This I cannot quite get into my hal without error.
File Name: Hurco_7i92...1-15.hal
File Size:14 KB
Current error is:-
./Hurco_7i92.hal:347: Pin 'encoder.position' does not exist
Also having failed to get spindle.0.orient to connect, I have reverted to the original enable connection.
I'd appreciate some guidance please.
17 Nov 2025 15:31 #338580 by andypugh
It's almost certainly encoder.0.position that you need (or some other number that identifies the spindle encoder.
18 Nov 2025 10:54 #338635 by NT4Boy
Thanks Andy, I'll go hunting for that missing connection and report back.
Moderators: piasdom
Time to create page: 0.638 seconds
