Forum Header
Need help to install 5 axis knematics
5 years 3 months ago - 5 years 3 months ago #214873 by Aciera
I'm also not quite sure this is correct either:
X, Y and Z rot-point pins represent are the offsets of the center of rotation of the A axis relative to the machine absolute zero coordinates.
It looks to me more like the center point of the C axis:
offsets of the center of rotation of the C axis
coordinates.
Last edit: 5 years 3 months ago by Aciera.
  • REX299
  • Topic Author
  • New Member
  • New Member
5 years 3 months ago #214874 by REX299
Replied by REX299 on topic Need help to install 5 axis knematics
Yeh X offset only make sense with xyzbc machine type, for xyzac Y and Z -offset is important. Now i have to find out where to put my machine Y Z offset value :)
Thank you so much Aciera!
  • REX299
  • Topic Author
  • New Member
  • New Member
5 years 3 months ago #214878 by REX299
there are two type of offset you have to handle
1: is the offset between rotation axis depend to machine type, for xyzac machine X and Z offsets are the offsets from the center of rotation of the C axis relative to the center of rotation of the A axis.
2. is the offset X, Y and Z rot-point pins represent are the offsets of the center of rotation of the A axis (pivot point mean intersect point of rotation axis A&C ) relative to the machine absolute zero coordinates
5 years 3 months ago #214879 by Aciera
You would put that into your hal file:
setp xyzac-trt-kins.y-offset 20 setp xyzac-trt-kins.z-offset 10
Of course you would replace 20 and 10 with your numbers.
then you follow the same pattern for the .x-, .y-, ..z-rot-point values
setp xyzac-trt-kins.x-rot-point 0 setp xyzac-trt-kins.y-rot-point 0 setp xyzac-trt-kins.z-rot-point 0
and again replace the values according to where your C- axis rotation-point is in relation to your home position
5 years 3 months ago - 5 years 3 months ago #214881 by Aciera
If you look at the document I linked above and also if you study the simulation config the rotation point is the center point on the surface of the C-axis. Not the intersection of the A and the C axis. At least that is how I read it.
linuxcnc.org/docs/2.8/html/motion/5-axis-figures/Figure-6.png
  • REX299
  • Topic Author
  • New Member
  • New Member
5 years 3 months ago #214882 by REX299
Thanks for very helpful info, i will check it out.
