Forum Header
Need help to install 5 axis knematics
5 years 3 months ago #214810 by Aciera
Go to the simualtion configs and see if you can run the example code in the axis/vismach/millturn simulation.
  • REX299
  • Topic Author
  • New Member
  • New Member
5 years 3 months ago #214818 by REX299
Replied by REX299 on topic Need help to install 5 axis knematics
Thank for your info
your mean I try to run sim axis vismach ... but my LinuxCNC dont have that chose from sim list.
And on my configs Folder also dont have the code "vismach/millturn simulation." as you mentioned. Do I miss to install some things else?
  • REX299
  • Topic Author
  • New Member
  • New Member
5 years 3 months ago #214820 by REX299
5 years 3 months ago - 5 years 3 months ago #214821 by Aciera
If you don't have millturn in the axis/vismach section then you are not running current master. So something must have gone wrong somewhere.
[edit]
your screenshots tell me that you are not looking in the right section. Go to the "Sample Configurations" Folder at the bottom of the configuration picker.
[edit]
Then go to axis/vismach and you should see millturn
Last edit: 5 years 3 months ago by Aciera.
  • REX299
  • Topic Author
  • New Member
  • New Member
5 years 3 months ago #214825 by REX299
Thank you i found it and run vismach/ 5axis/xyzac skin the simulation worked. After run this sim it automatically created config folder "Sim. Axis.vismach.... " As far I understand I have to modify some .hal and .ini files in this folder to match my real machine.
Let me know if I am wrong way.
Thanks so much!
5 years 3 months ago #214826 by Aciera
I had success modified HAL and INI file for my machine on Linux v2.8.
If you already have a configuration from version 2.8 then you would want to copy that folder (user/linuxcnc/configs/yourfolder) to the config folder of your new installation.
Time to create page: 0.392 seconds
