Forum Header
Need help to install 5 axis knematics
4 years 7 months ago #237438 by JackRay
Sorry i made z mistake about "step xyza c-trt-kins.z-rot-point -44.6 " it's setp xyzac-trt-kins.z-offset -44.6 ( in fac it's a raduis of A axe)
To make my zero "Z" I first make a G41h1, then I come tangent to the middle of my axis Pivot AC. and I enter the value "step xyzac-trt-kins.z-rot-point ..." in relation to the machine origin (taking into account the offset of tools). This part is not well documented on the linuxcnc documentation, many people are trying to understand how it works.
Thank you
4 years 7 months ago #237464 by JackRay
Hello,
I found the simple but necessary calculation concerning the value of "setp xyzac-trt-kins.z-rot-point ..." .
Here is my procedure : with an axis A of 44.6mm radius
 and tool N°1 of 50 mm length .
- Mount the tool in the spindle (50 mm overhang)
- add this tool and this length in the tool table
- activate the G43h1 (tool length compensation "code G")
- Come tangent to the center of the AC axis (be careful that the A axis is horizontal "A0")
-Read on LinuxCNC the offset in Z ( ex : -222 mm from the origin )
- calculation : 50 ( tool length ) + 44.6 ( A axis pivot point ) - 222 = -127.4 mm
setp xyzac-trt-kins.z-rot-point -127.4
Maybe there are other calculations but on my xyzac-trt machine it works very well.
Sincerely
4 years 7 months ago #237541 by andypugh
The documentation does rather assume that you can glance at matrix maths and understand exactly what it represents.
I can't.
3 years 10 months ago #260609 by akg1904
Hi all,
I am using 2.8.4 linuxcnc which works fine, but now I want to implement 5 axis switchkins.
Is there a way to do it in v2.8.4 without switching to v2.9 as I think 2.8.4 works best for me.
Regards
Abhishek
Time to create page: 0.238 seconds
