× Forum Header
stepconf woes..
14 Jun 2011 00:20 #10474 by submicro
Replied by submicro on topic Re:stepconf woes..
OK in a last ditch effort I have here the output from grep|dmsg I'm hoping that someone will be able to decipher it and find my problem.
[ 0.132520] pci 0000:00:0b.0: PME# disabled
[ 0.132585] pci 0000:00:0b.1: reg 20 io port: [0xd400-0xd41f]
[ 0.132621] pci 0000:00:0b.1: supports D1 D2
[ 0.132624] pci 0000:00:0b.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.132630] pci 0000:00:0b.1: PME# disabled
[ 0.132673] pci 0000:00:0b.2: reg 10 32bit mmio: [0xea100000-0xea1000ff]
[ 0.132731] pci 0000:00:0b.2: supports D1 D2
[ 0.132734] pci 0000:00:0b.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.132740] pci 0000:00:0b.2: PME# disabled
[ 0.132841] pci 0000:00:11.0: quirk: region 0400-047f claimed by vt8235 PM
[ 0.132846] pci 0000:00:11.0: quirk: region 0500-050f claimed by vt8235 SMB
[ 0.132933] pci 0000:00:11.1: reg 20 io port: [0xe400-0xe40f]
[ 0.133056] pci 0000:01:00.0: reg 10 32bit mmio pref: [0xe0000000-0xe7ffffff]
[ 0.133066] pci 0000:01:00.0: reg 14 io port: [0xa000-0xa0ff]
[ 0.133075] pci 0000:01:00.0: reg 18 32bit mmio: [0xea020000-0xea02ffff]
[ 0.133098] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.133126] pci 0000:01:00.0: supports D1 D2
[ 0.133178] pci 0000:00:01.0: bridge io port: [0xa000-0xafff]
[ 0.133184] pci 0000:00:01.0: bridge 32bit mmio: [0xea000000-0xea0fffff]
[ 0.133191] pci 0000:00:01.0: bridge 32bit mmio pref: [0xe0000000-0xe7ffffff]
[ 0.133202] pci_bus 0000:00: on NUMA node 0
[ 0.133210] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.185217] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 10 *11 12)
[ 0.185489] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 10 11 12) *5
[ 0.185765] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 11 12) *5
[ 0.186040] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 *11 12)
[ 0.186268] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.186487] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.186705] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.186923] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.187248] ACPI: PCI Interrupt Link [ALKA] (IRQs 20) *0, disabled.
[ 0.187513] ACPI: PCI Interrupt Link [ALKB] (IRQs *21), disabled.
[ 0.187779] ACPI: PCI Interrupt Link [ALKC] (IRQs *22), disabled.
[ 0.188099] ACPI: PCI Interrupt Link [ALKD] (IRQs *23), disabled.
[ 0.188238] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.188243] vgaarb: loaded
[ 0.188437] SCSI subsystem initialized
[ 0.188517] libata version 3.00 loaded.
[ 0.188620] usbcore: registered new interface driver usbfs
[ 0.188640] usbcore: registered new interface driver hub
[ 0.188680] usbcore: registered new device driver usb
[ 0.188869] ACPI: WMI: Mapper loaded
[ 0.188873] PCI: Using ACPI for IRQ routing
[ 0.189061] NetLabel: Initializing
[ 0.189065] NetLabel: domain hash size = 128
[ 0.189067] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.189087] NetLabel: unlabeled traffic allowed by default
[ 0.189131] Switching to clocksource tsc
[ 0.191828] AppArmor: AppArmor Filesystem Enabled
[ 0.191845] pnp: PnP ACPI init
[ 0.191864] ACPI: bus type pnp registered
[ 0.197034] pnp: PnP ACPI: found 15 devices
[ 0.197038] ACPI: ACPI bus type pnp unregistered
[ 0.197045] PnPBIOS: Disabled by ACPI PNP
[ 0.197062] system 00:00: iomem range 0xcd000-0xcffff has been reserved
[ 0.197067] system 00:00: iomem range 0xf0000-0xf7fff could not be reserved
[ 0.197072] system 00:00: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.197076] system 00:00: iomem range 0xfc000-0xfffff could not be reserved
[ 0.197080] system 00:00: iomem range 0x1fff0000-0x1fffffff could not be reserved
[ 0.197085] system 00:00: iomem range 0xffff0000-0xffffffff has been reserved
[ 0.197089] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.197093] system 00:00: iomem range 0x100000-0x1ffeffff could not be reserved
[ 0.197098] system 00:00: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.197102] system 00:00: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.197106] system 00:00: iomem range 0xfff80000-0xfffeffff has been reserved
[ 0.197115] system 00:02: ioport range 0x400-0x47f has been reserved
[ 0.197120] system 00:02: ioport range 0x500-0x50f has been reserved
[ 0.197128] system 00:03: ioport range 0x4d0-0x4d1 has been reserved
[ 0.197132] system 00:03: ioport range 0x800-0x805 has been reserved
[ 0.197136] system 00:03: ioport range 0x290-0x297 has been reserved
[ 0.231926] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.231932] pci 0000:00:01.0: IO window: 0xa000-0xafff
[ 0.231939] pci 0000:00:01.0: MEM window: 0xea000000-0xea0fffff
[ 0.231945] pci 0000:00:01.0: PREFETCH window: 0xe0000000-0xe7ffffff
[ 0.231968] pci 0000:00:01.0: setting latency timer to 64
[ 0.231976] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.231979] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.231983] pci_bus 0000:01: resource 0 io: [0xa000-0xafff]
[ 0.231987] pci_bus 0000:01: resource 1 mem: [0xea000000-0xea0fffff]
[ 0.231990] pci_bus 0000:01: resource 2 pref mem [0xe0000000-0xe7ffffff]
[ 0.232039] NET: Registered protocol family 2
[ 0.232171] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.232591] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.232698] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.232801] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.232804] TCP reno registered
[ 0.232897] NET: Registered protocol family 1
[ 0.232924] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.232988] pci 0000:01:00.0: Boot video device
[ 0.233254] Scanning for low memory corruption every 60 seconds
[ 0.233371] audit: initializing netlink socket (disabled)
[ 0.233386] type=2000 audit(1308008690.230:1): initialized
[ 0.241629] Trying to unpack rootfs image as initramfs...
[ 0.251052] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.258903] VFS: Disk quotas dquot_6.5.2
[ 0.259009] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.259825] fuse init (API version 7.13)
[ 0.259947] msgmni has been set to 968
[ 0.260239] alg: No test for stdrng (krng)
[ 0.260321] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.260326] io scheduler noop registered
[ 0.260329] io scheduler anticipatory registered
[ 0.260332] io scheduler deadline registered
[ 0.260387] io scheduler cfq registered (default)
[ 0.260549] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.260586] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.260689] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.260696] ACPI: Power Button [PWRB]
[ 0.260761] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 0.260771] ACPI: Sleep Button [SLPB]
[ 0.260860] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.260865] ACPI: Power Button [PWRF]
[ 0.263007] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.263119] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.263223] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.263652] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.263809] 00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.265261] brd: module loaded
[ 0.265904] loop: module loaded
[ 0.266025] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.266419] ACPI: PCI Interrupt Link [ALKA] disabled and referenced, BIOS bug
[ 0.266606] ACPI: PCI Interrupt Link [ALKA] BIOS reported IRQ 0, using IRQ 20
[ 0.266611] ACPI: PCI Interrupt Link [ALKA] enabled at IRQ 20
[ 0.266618] alloc irq_desc for 20 on node -1
[ 0.266621] alloc kstat_irqs on node -1
[ 0.266634] pata_acpi 0000:00:11.1: PCI INT A -> Link[ALKA] -> GSI 20 (level, low) -> IRQ 20
[ 0.266709] pata_acpi 0000:00:11.1: PCI INT A disabled
[ 0.271328] isapnp: Scanning for PnP cards...
[ 0.277233] Fixed MDIO Bus: probed
[ 0.277289] PPP generic driver version 2.4.2
[ 0.277367] tun: Universal TUN/TAP device driver, 1.6
[ 0.277370] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.277501] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.277533] alloc irq_desc for 16 on node -1
[ 0.277536] alloc kstat_irqs on node -1
[ 0.277545] ehci_hcd 0000:00:0b.2: PCI INT C -> GSI 16 (level, low) -> IRQ 16
[ 0.277568] ehci_hcd 0000:00:0b.2: EHCI Host Controller
[ 0.277617] ehci_hcd 0000:00:0b.2: new USB bus registered, assigned bus number 1
[ 0.277705] ehci_hcd 0000:00:0b.2: irq 16, io mem 0xea100000
[ 0.326726] ehci_hcd 0000:00:0b.2: USB 2.0 started, EHCI 1.00
[ 0.326910] usb usb1: configuration #1 chosen from 1 choice
[ 0.326958] hub 1-0:1.0: USB hub found
[ 0.326974] hub 1-0:1.0: 4 ports detected
[ 0.327051] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.327076] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.327137] alloc irq_desc for 18 on node -1
[ 0.327141] alloc kstat_irqs on node -1
[ 0.327149] uhci_hcd 0000:00:0b.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.327161] uhci_hcd 0000:00:0b.0: UHCI Host Controller
[ 0.327209] uhci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
[ 0.327262] uhci_hcd 0000:00:0b.0: irq 18, io base 0x0000d000
[ 0.327384] usb usb2: configuration #1 chosen from 1 choice
[ 0.327425] hub 2-0:1.0: USB hub found
[ 0.327439] hub 2-0:1.0: 2 ports detected
[ 0.327497] alloc irq_desc for 19 on node -1
[ 0.327501] alloc kstat_irqs on node -1
[ 0.327507] uhci_hcd 0000:00:0b.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.327519] uhci_hcd 0000:00:0b.1: UHCI Host Controller
[ 0.327574] uhci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 3
[ 0.327624] uhci_hcd 0000:00:0b.1: irq 19, io base 0x0000d400
[ 0.327750] usb usb3: configuration #1 chosen from 1 choice
[ 0.327790] hub 3-0:1.0: USB hub found
[ 0.327802] hub 3-0:1.0: 2 ports detected
[ 0.327937] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.328470] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.328480] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.328667] mice: PS/2 mouse device common for all mice
[ 0.328866] rtc_cmos 00:05: RTC can wake from S4
[ 0.328923] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.328976] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 0.329123] device-mapper: uevent: version 1.0.3
[ 0.331721] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.332804] device-mapper: multipath: version 1.1.0 loaded
[ 0.332810] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.333818] EISA: Probing bus 0 at eisa.0
[ 0.333861] EISA: Detected 0 cards.
[ 0.333866] cpuidle: using governor ladder
[ 0.333869] cpuidle: using governor menu
[ 0.334434] TCP cubic registered
[ 0.334609] NET: Registered protocol family 10
[ 0.335229] lo: Disabled Privacy Extensions
[ 0.335646] NET: Registered protocol family 17
[ 0.335688] Using IPI No-Shortcut mode
[ 0.335818] registered taskstats version 1
[ 0.336157] rtc_cmos 00:05: setting system clock to 2011-06-13 23:44:50 UTC (1308008690)
[ 0.336162] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.336165] EDD information not available.
[ 0.348399] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.678637] usb 1-1: new high speed USB device using ehci_hcd and address 2
[ 0.877663] usb 1-1: configuration #1 chosen from 1 choice
[ 0.942758] isapnp: No Plug & Play device found
[ 1.032627] Freeing initrd memory: 12800k freed
[ 1.049149] Freeing unused kernel memory: 620k freed
[ 1.049911] Write protecting the kernel text: 4540k
[ 1.049938] Write protecting the kernel read-only data: 1668k
[ 1.050976] usb 1-3: new high speed USB device using ehci_hcd and address 4
[ 1.080051] udev: starting version 151
[ 1.197448] usb 1-3: configuration #1 chosen from 1 choice
[ 1.362142] pata_via 0000:00:11.1: version 0.3.4
[ 1.362169] pata_via 0000:00:11.1: PCI INT A -> Link[ALKA] -> GSI 20 (level, low) -> IRQ 20
[ 1.362488] Linux agpgart interface v0.103
[ 1.371990] scsi0 : pata_via
[ 1.400063] Initializing USB Mass Storage driver...
[ 1.400184] scsi1 : pata_via
[ 1.405590] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xe400 irq 14
[ 1.405596] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xe408 irq 15
[ 1.405839] agpgart: Detected VIA PM800/PN800/PM880/PN880 chipset
[ 1.408836] agpgart-via 0000:00:00.0: AGP aperture is 32M @ 0xe8000000
[ 1.409158] scsi2 : SCSI emulation for USB Mass Storage devices
[ 1.409400] usb-storage: device found at 2
[ 1.409403] usb-storage: waiting for device to settle before scanning
[ 1.409444] scsi3 : SCSI emulation for USB Mass Storage devices
[ 1.409619] usbcore: registered new interface driver usb-storage
[ 1.409625] USB Mass Storage support registered.
[ 1.409747] usb-storage: device found at 4
[ 1.409751] usb-storage: waiting for device to settle before scanning
[ 1.410517] [drm] Initialized drm 1.1.0 20060810
[ 1.452028] usb 2-2: new low speed USB device using uhci_hcd and address 2
[ 1.624677] ata1.00: ATA-6: ST3200822A, 3.01, max UDMA/100
[ 1.624682] ata1.00: 390721968 sectors, multi 16: LBA48
[ 1.626463] usb 2-2: configuration #1 chosen from 1 choice
[ 1.629467] usb 1-3: USB disconnect, address 4
[ 1.640664] ata1.00: configured for UDMA/100
[ 1.640845] scsi 0:0:0:0: Direct-Access ATA ST3200822A 3.01 PQ: 0 ANSI: 5
[ 1.641080] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.641555] sd 0:0:0:0: [sda] 390721968 512-byte logical blocks: (200 GB/186 GiB)
[ 1.641638] sd 0:0:0:0: [sda] Write Protect is off
[ 1.641643] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.641685] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.641909] sda: sda1 sda2 < sda5 >
[ 1.682380] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.804435] ata2.00: ATAPI: LITE-ON CD-RW SOHR-5238S, 4S04, max UDMA/33
[ 1.820325] ata2.00: configured for UDMA/33
[ 1.821669] scsi 1:0:0:0: CD-ROM LITE-ON CD-RW SOHR-5238S 4S04 PQ: 0 ANSI: 5
[ 1.825423] sr0: scsi3-mmc drive: 31x/52x writer cd/rw xa/form2 cdda tray
[ 1.825429] Uniform CD-ROM driver Revision: 3.20
[ 1.825570] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.825661] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.864145] usbcore: registered new interface driver hiddev
[ 1.868079] usb 1-3: new high speed USB device using ehci_hcd and address 5
[ 1.879919] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:0b.0/usb2/2-2/2-2:1.0/input/input5
[ 1.880108] generic-usb 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:0b.0-2/input0
[ 1.880146] usbcore: registered new interface driver usbhid
[ 1.880151] usbhid: v2.6:USB HID core driver
[ 1.907188] [drm] radeon defaulting to kernel modesetting.
[ 1.907193] [drm] radeon kernel modesetting enabled.
[ 1.907272] radeon 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.912759] [drm] radeon: Initializing kernel modesetting.
[ 1.912864] [drm] register mmio base: 0xEA020000
[ 1.912868] [drm] register mmio size: 65536
[ 1.913161] [drm] GPU reset succeed (RBBM_STATUS=0x00000140)
[ 1.913185] agpgart-via 0000:00:00.0: AGP 3.5 bridge
[ 1.913206] agpgart-via 0000:00:00.0: bridge is in legacy mode, falling back to 2.x
[ 1.913217] agpgart-via 0000:00:00.0: putting AGP V2 device into 4x mode
[ 1.913294] radeon 0000:01:00.0: putting AGP V2 device into 4x mode
[ 1.913300] [drm] radeon: VRAM 64M
[ 1.913303] [drm] radeon: VRAM from 0x00000000 to 0x03FFFFFF
[ 1.913306] [drm] radeon: GTT 32M
[ 1.913308] [drm] radeon: GTT from 0xE8000000 to 0xE9FFFFFF
[ 1.913332] [drm] radeon: irq initialized.
[ 1.913564] [drm] Detected VRAM RAM=64M, BAR=128M
[ 1.913570] [drm] RAM width 64bits DDR
[ 1.913822] [TTM] Zone kernel: Available graphics memory: 254616 kiB.
[ 1.913847] [drm] radeon: 64M of VRAM memory ready
[ 1.913851] [drm] radeon: 32M of GTT memory ready.
[ 1.924342] [drm] radeon: cp idle (0x00008080)
[ 1.924391] [drm] Loading R100 Microcode
[ 1.924658] platform radeon_cp.0: firmware: requesting radeon/R100_cp.bin
[ 1.934205] [drm] radeon: ring at 0x00000000E8000000
[ 1.934350] [drm] ring test succeeded in 1 usecs
[ 1.939844] [drm] radeon: ib pool ready.
[ 1.939959] [drm] ib test succeeded in 0 usecs
[ 1.940361] [drm] DFP table revision: 2
[ 1.940626] [drm] Default TV standard: NTSC
[ 1.940630] [drm] 27.000000000 MHz TV ref clk
[ 1.940632] [drm] No TV DAC info found in BIOS
[ 1.940636] [drm] Default TV standard: NTSC
[ 1.940639] [drm] 27.000000000 MHz TV ref clk
[ 1.940719] [drm] Radeon Display Connectors
[ 1.940723] [drm] Connector 0:
[ 1.940725] [drm] VGA
[ 1.940729] [drm] DDC: 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60
[ 1.940731] [drm] Encoders:
[ 1.940734] [drm] CRT1: INTERNAL_DAC1
[ 1.940737] [drm] Connector 1:
[ 1.940739] [drm] DVI-D
[ 1.940741] [drm] HPD1
[ 1.940745] [drm] DDC: 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[ 1.940747] [drm] Encoders:
[ 1.940749] [drm] DFP1: INTERNAL_TMDS1
[ 1.940752] [drm] Connector 2:
[ 1.940754] [drm] S-video
[ 1.940756] [drm] Encoders:
[ 1.940759] [drm] TV1: INTERNAL_DAC2
[ 2.013321] usb 1-3: configuration #1 chosen from 1 choice
[ 2.094252] [drm] fb mappable at 0xE0040000
[ 2.094257] [drm] vram apper at 0xE0000000
[ 2.094260] [drm] size 3145728
[ 2.094263] [drm] fb depth is 24
[ 2.094265] [drm] pitch is 4096
[ 2.094738] fb0: radeondrmfb frame buffer device
[ 2.094743] registered panic notifier
[ 2.094752] [drm] Initialized radeon 2.0.0 20080528 for 0000:01:00.0 on minor 0
[ 2.099398] vga16fb: initializing
[ 2.099405] vga16fb: mapped to 0xc00a0000
[ 2.099412] vga16fb: not registering due to another framebuffer present
[ 2.281756] Console: switching to colour frame buffer device 128x48
[ 2.751969] xor: automatically using best checksumming function: pIII_sse
[ 2.768011] pIII_sse : 4512.000 MB/sec
[ 2.768016] xor: using function: pIII_sse (4512.000 MB/sec)
[ 2.807202] device-mapper: dm-raid45: initialized v0.2594b
[ 3.077714] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 6.412027] usb-storage: device scan complete
[ 6.412651] scsi 2:0:0:0: Direct-Access PNY USB 2.0 FD 8.02 PQ: 0 ANSI: 0 CCS
[ 6.413355] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 6.416744] sd 2:0:0:0: [sdb] 7856127 512-byte logical blocks: (4.02 GB/3.74 GiB)
[ 6.417240] sd 2:0:0:0: [sdb] Write Protect is off
[ 6.417245] sd 2:0:0:0: [sdb] Mode Sense: 45 00 00 08
[ 6.417249] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 6.418987] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 6.418993] sdb: sdb1
[ 6.421240] sd 2:0:0:0: [sdb] Assuming drive cache: write through
[ 6.421245] sd 2:0:0:0: [sdb] Attached SCSI removable disk
[ 15.637734] Adding 1490936k swap on /dev/sda5. Priority:-1 extents:1 across:1490936k
[ 15.677848] udev: starting version 151
[ 15.927231] lp: driver loaded but no devices found
[ 16.125384] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 16.125590] parport_pc 00:0a: reported by Plug and Play ACPI
[ 16.125654] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 16.264344] lp0: using parport0 (interrupt-driven).
[ 16.273134] parport_serial 0000:00:09.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 16.273162] parport1: PC-style at 0xb800 [PCSPP,TRISTATE,EPP]
[ 16.355925] lp1: using parport1 (polling).
[ 16.356134] 0000:00:09.0: ttyS2 at I/O 0xb000 (irq = 16) is a 16550A
[ 16.356318] 0000:00:09.0: ttyS3 at I/O 0xb400 (irq = 16) is a 16550A
[ 16.481010] ppdev: user-space parallel port driver
[ 16.483653] irda_init()
[ 16.483676] NET: Registered protocol family 23
[ 16.510823] psmouse serio1: ID: 10 00 64
[ 16.575495] gameport: NS558 PnP Gameport is pnp00:0e/gameport0, io 0x201, speed 774kHz
[ 16.605623] usbcore: registered new interface driver cdc_ether
[ 16.667611] usb0: register 'rndis_host' at usb-0000:00:0b.2-3, RNDIS device, c6:b8:47:a2:84:aa
[ 16.667651] usbcore: registered new interface driver rndis_host
[ 16.764544] cfg80211: Calling CRDA to update world regulatory domain
[ 16.772063] gameport: EMU10K1 is pci0000:00:0a.1/gameport0, io 0xcc00, speed 962kHz
[ 16.803428] usbcore: registered new interface driver rndis_wlan
[ 16.913518] type=1505 audit(1308008707.075:2): operation="profile_load" pid=645 name="/sbin/dhclient3"
[ 16.914455] type=1505 audit(1308008707.075:3): operation="profile_load" pid=645 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 16.914950] type=1505 audit(1308008707.075:4): operation="profile_load" pid=645 name="/usr/lib/connman/scripts/dhclient-script"
[ 16.930331] cfg80211: World regulatory domain updated:
[ 16.930338] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 16.930343] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 16.930347] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 16.930351] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 16.930355] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 16.930359] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 17.121969] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input6
[ 17.558979] alloc irq_desc for 17 on node -1
[ 17.558985] alloc kstat_irqs on node -1
[ 17.559021] EMU10K1_Audigy 0000:00:0a.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 17.581741] type=1505 audit(1308008707.743:5): operation="profile_load" pid=783 name="/usr/share/gdm/guest-session/Xsession"
[ 17.596082] type=1505 audit(1308008707.759:6): operation="profile_replace" pid=784 name="/sbin/dhclient3"
[ 17.617445] type=1505 audit(1308008707.779:7): operation="profile_replace" pid=784 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 17.617958] type=1505 audit(1308008707.779:8): operation="profile_replace" pid=784 name="/usr/lib/connman/scripts/dhclient-script"
[ 17.665096] type=1505 audit(1308008707.827:9): operation="profile_load" pid=785 name="/usr/bin/evince"
[ 17.756628] type=1505 audit(1308008707.919:10): operation="profile_load" pid=785 name="/usr/bin/evince-previewer"
[ 17.879690] type=1505 audit(1308008708.039:11): operation="profile_load" pid=785 name="/usr/bin/evince-thumbnailer"
[ 28.028012] usb0: no IPv6 routers present
[ 70.431425] I-pipe: Domain RTAI registered.
[ 70.431438] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 70.431441] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 70.431450] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 70.431453] PIPELINE layers:
[ 70.431457] e1311e20 9ac15d93 RTAI 200
[ 70.431461] c085cb20 0 Linux 100
[ 70.468978] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 70.469136] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 70.469144] RTAI[sched]: hard timer type/freq = APIC/8299581(Hz); default timing: periodic; linear timed lists.
[ 70.469149] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2788587000 hz.
[ 70.469152] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 70.469294] RTAI[usi]: enabled.
[ 70.586698] RTAI[math]: loaded.
[ 70.796688] config string '0x378 out '
[ 81.840411] 10849: ERROR: Unexpected realtime delay: check dmesg for details.
[ 81.840417]
[ 81.840418] In recent history there were
[ 81.840420] 2783876, 2786511, 2805957, 2786448, and 2786269
[ 81.840421] elapsed clocks between calls to the motion controller.
[ 81.840425] This time, there were 3604965 which is so anomalously
[ 81.840427] large that it probably signifies a problem with your
[ 81.840429] realtime configuration. For the rest of this run of
[ 81.840430] EMC, this message will be suppressed.
[ 81.840432]
[ 115.082198] RTAI[math]: unloaded.
[ 115.158846] SCHED releases registered named ALIEN RTGLBH
[ 115.173140] RTAI[malloc]: unloaded.
[ 115.272023] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 115.278538] I-pipe: Domain RTAI unregistered.
[ 115.278552] RTAI[hal]: unmounted.
[ 205.983585] I-pipe: Domain RTAI registered.
[ 205.983595] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 205.983599] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 205.983607] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 205.983610] PIPELINE layers:
[ 205.983615] e1311e20 9ac15d93 RTAI 200
[ 205.983618] c085cb20 0 Linux 100
[ 206.018460] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 206.018629] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 206.018637] RTAI[sched]: hard timer type/freq = APIC/8299581(Hz); default timing: periodic; linear timed lists.
[ 206.018642] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2788587000 hz.
[ 206.018645] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 206.018787] RTAI[usi]: enabled.
[ 206.126719] RTAI[math]: loaded.
[ 206.210040] config string '0x378'
[ 221.818375] RTAI[math]: unloaded.
[ 221.901020] SCHED releases registered named ALIEN RTGLBH
[ 221.917773] RTAI[malloc]: unloaded.
[ 222.016020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 222.021753] I-pipe: Domain RTAI unregistered.
[ 222.021767] RTAI[hal]: unmounted.
[ 1728.690293] I-pipe: Domain RTAI registered.
[ 1728.690304] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 1728.690308] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 1728.690317] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1728.690320] PIPELINE layers:
[ 1728.690324] e1311e20 9ac15d93 RTAI 200
[ 1728.690328] c085cb20 0 Linux 100
[ 1728.725751] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1728.725916] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 1728.725924] RTAI[sched]: hard timer type/freq = APIC/8299581(Hz); default timing: periodic; linear timed lists.
[ 1728.725929] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2788587000 hz.
[ 1728.725933] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1728.726074] RTAI[usi]: enabled.
[ 1728.846480] RTAI[math]: loaded.
[ 1728.961826] config string '0x378 out '
[ 1769.480351] RTAI[math]: unloaded.
[ 1769.559285] SCHED releases registered named ALIEN RTGLBH
[ 1769.573870] RTAI[malloc]: unloaded.
[ 1769.672019] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1769.677747] I-pipe: Domain RTAI unregistered.
[ 1769.677760] RTAI[hal]: unmounted.
submicro@submicro-desktop:~$
14 Jun 2011 07:27 #10478 by cncbasher
Replied by cncbasher on topic Re:stepconf woes..
see this section
[ 81.840417]
[ 81.840432]
Real time Kernal has been removed or stopped etc , so in that case the parrell port will not work , so i'm not convinced the problem is in the hardware ,
i'd go more for a configuration issue
try loading any of the parrell port configurations , and then relist and see if the RTA errors dissapear , if this works then the chances are , the error is in the step conf configuration
if it still shows errors then i would look at the installation of the emc cd
was this a clean installation form the live cd
14 Jun 2011 11:58 #10485 by BigJohnT
Replied by BigJohnT on topic Re:stepconf woes..
Have you tried the parallel port tester as suggested by Rick?
14 Jun 2011 17:12 - 14 Jun 2011 17:23 #10491 by submicro
John, yes I have tried it.
cncblaster, yes this is a clean install from cd. thanks for the suggestion I'll give it a shot and then I will try the stepconf again..................................... and try and figure out what I'm doing wrong in the config.
I'm using the Keling C10 breakout, and the 4030 controllers.
I also tried Ubuntu 8.04 with the same problem.....
Last edit: 14 Jun 2011 17:23 by submicro.
14 Jun 2011 17:34 #10493 by BigJohnT
What was the results of using the parallel port tester?
14 Jun 2011 19:15 - 14 Jun 2011 19:16 #10497 by submicro
John, The results were the same, constant +5vdc
Last edit: 14 Jun 2011 19:16 by submicro.
14 Jun 2011 19:18 #10498 by BigJohnT
What about the inputs, do they work?
14 Jun 2011 19:49 #10499 by submicro
John, I haven't tried the inputs, but I will. I'll let you know. Meanwhile here's some fine reading material for cncblaster
[    0.000000] Fast TSC calibration using PIT
[    0.000000] Detected 2788.597 MHz processor.
[    0.004006] Calibrating delay loop (skipped), value calculated using timer frequency.. 5577.19 BogoMIPS (lpj=11154388)
[    0.004031] Security Framework initialized
[    0.004056] AppArmor: AppArmor initialized
[    0.004068] Mount-cache hash table entries: 512
[    0.004257] Initializing cgroup subsys ns
[    0.004265] Initializing cgroup subsys cpuacct
[    0.004273] Initializing cgroup subsys memory
[    0.004285] Initializing cgroup subsys devices
[    0.004290] Initializing cgroup subsys freezer
[    0.004294] Initializing cgroup subsys net_cls
[    0.004330] CPU: Trace cache: 12K uops, L1 D cache: 16K
[    0.004336] CPU: L2 cache: 1024K
[    0.004340] CPU: Hyper-Threading is disabled
[    0.004345] mce: CPU supports 4 MCE banks
[    0.004360] CPU0: Thermal monitoring enabled (TM1)
[    0.004373] Performance Events: no PMU driver, software events only.
[    0.004384] Checking 'hlt' instruction... OK.
[    0.021452] SMP alternatives: switching to UP code
[    0.035400] ACPI: Core revision 20090903
[    0.048014] ftrace: converting mcount calls to 0f 1f 44 00 00
[    0.048023] ftrace: allocating 21003 entries in 42 pages
[    0.063861] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.064967] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.068001] ..MP-BIOS bug: 8254 timer not connected to IO-APIC
[    0.068001] ...trying to set up timer (IRQ0) through the 8259A ...
[    0.068001] ..... (found apic 0 pin 2) ...
[    0.108384] ....... works.
[    0.108387] CPU0: Intel(R) Pentium(R) 4 CPU 2.80GHz stepping 03
[    0.112001] Brought up 1 CPUs
[    0.112001] Total of 1 processors activated (5577.19 BogoMIPS).
[    0.112001] CPU0 attaching NULL sched-domain.
[    0.112001] devtmpfs: initialized
[    0.112001] regulator: core version 0.5
[    0.112001] NET: Registered protocol family 16
[    0.112001] EISA bus registered
[    0.112001] ACPI: bus type pci registered
[    0.112001] PCI: PCI BIOS revision 2.10 entry at 0xfbb20, last bus=1
[    0.112001] PCI: Using configuration type 1 for base access
[    0.112442] bio: create slab <bio-0> at 0
[    0.113313] ACPI: EC: Look up EC in DSDT
[    0.123080] ACPI: Interpreter enabled
[    0.123085] ACPI: (supports S0 S5)
[    0.123103] ACPI: Using IOAPIC for interrupt routing
[    0.131423] ACPI: No dock devices found.
[    0.131578] ACPI: PCI Root Bridge [PCI0] (0000:00)
[    0.131646] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xe8000000-0xe9ffffff]
[    0.132061] pci 0000:00:01.0: supports D1
[    0.132103] pci 0000:00:09.0: reg 10 io port: [0xb000-0xb007]
[    0.132113] pci 0000:00:09.0: reg 14 io port: [0xb400-0xb407]
[    0.132122] pci 0000:00:09.0: reg 18 io port: [0xb800-0xb807]
[    0.132132] pci 0000:00:09.0: reg 1c io port: [0xbc00-0xbc07]
[    0.132141] pci 0000:00:09.0: reg 20 io port: [0xc000-0xc007]
[    0.132150] pci 0000:00:09.0: reg 24 io port: [0xc400-0xc40f]
[    0.132206] pci 0000:00:0a.0: reg 10 io port: [0xc800-0xc81f]
[    0.132305] pci 0000:00:0a.1: reg 10 io port: [0xcc00-0xcc07]
[    0.132435] pci 0000:00:0b.0: reg 20 io port: [0xd000-0xd01f]
[    0.132471] pci 0000:00:0b.0: supports D1 D2
[    0.132474] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.132481] pci 0000:00:0b.0: PME# disabled
[    0.132546] pci 0000:00:0b.1: reg 20 io port: [0xd400-0xd41f]
[    0.132582] pci 0000:00:0b.1: supports D1 D2
[    0.132585] pci 0000:00:0b.1: PME# supported from D0 D1 D2 D3hot D3cold
[    0.132591] pci 0000:00:0b.1: PME# disabled
[    0.132634] pci 0000:00:0b.2: reg 10 32bit mmio: [0xea100000-0xea1000ff]
[    0.132692] pci 0000:00:0b.2: supports D1 D2
[    0.132695] pci 0000:00:0b.2: PME# supported from D0 D1 D2 D3hot D3cold
[    0.132701] pci 0000:00:0b.2: PME# disabled
[    0.132802] pci 0000:00:11.0: quirk: region 0400-047f claimed by vt8235 PM
[    0.132807] pci 0000:00:11.0: quirk: region 0500-050f claimed by vt8235 SMB
[    0.132895] pci 0000:00:11.1: reg 20 io port: [0xe400-0xe40f]
[    0.133018] pci 0000:01:00.0: reg 10 32bit mmio pref: [0xe0000000-0xe7ffffff]
[    0.133027] pci 0000:01:00.0: reg 14 io port: [0xa000-0xa0ff]
[    0.133035] pci 0000:01:00.0: reg 18 32bit mmio: [0xea020000-0xea02ffff]
[    0.133058] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[    0.133086] pci 0000:01:00.0: supports D1 D2
[    0.133138] pci 0000:00:01.0: bridge io port: [0xa000-0xafff]
[    0.133145] pci 0000:00:01.0: bridge 32bit mmio: [0xea000000-0xea0fffff]
[    0.133152] pci 0000:00:01.0: bridge 32bit mmio pref: [0xe0000000-0xe7ffffff]
[    0.133164] pci_bus 0000:00: on NUMA node 0
[    0.133172] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.185164] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 10 *11 12)
[    0.185435] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 10 11 12) *5
[    0.185711] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 11 12) *5
[    0.185986] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 *11 12)
[    0.186213] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[    0.186431] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[    0.186650] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[    0.186868] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[    0.187193] ACPI: PCI Interrupt Link [ALKA] (IRQs 20) *0, disabled.
[    0.187459] ACPI: PCI Interrupt Link [ALKB] (IRQs *21), disabled.
[    0.187725] ACPI: PCI Interrupt Link [ALKC] (IRQs *22), disabled.
[    0.188044] ACPI: PCI Interrupt Link [ALKD] (IRQs *23), disabled.
[    0.188182] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[    0.188187] vgaarb: loaded
[    0.188380] SCSI subsystem initialized
[    0.188460] libata version 3.00 loaded.
[    0.188563] usbcore: registered new interface driver usbfs
[    0.188583] usbcore: registered new interface driver hub
[    0.188623] usbcore: registered new device driver usb
[    0.188812] ACPI: WMI: Mapper loaded
[    0.188816] PCI: Using ACPI for IRQ routing
[    0.189003] NetLabel: Initializing
[    0.189007] NetLabel:  domain hash size = 128
[    0.189009] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.189028] NetLabel:  unlabeled traffic allowed by default
[    0.189071] Switching to clocksource tsc
[    0.191763] AppArmor: AppArmor Filesystem Enabled
[    0.191779] pnp: PnP ACPI init
[    0.191797] ACPI: bus type pnp registered
[    0.197030] pnp: PnP ACPI: found 15 devices
[    0.197034] ACPI: ACPI bus type pnp unregistered
[    0.197041] PnPBIOS: Disabled by ACPI PNP
[    0.197058] system 00:00: iomem range 0xcd000-0xcffff has been reserved
[    0.197063] system 00:00: iomem range 0xf0000-0xf7fff could not be reserved
[    0.197067] system 00:00: iomem range 0xf8000-0xfbfff could not be reserved
[    0.197071] system 00:00: iomem range 0xfc000-0xfffff could not be reserved
[    0.197076] system 00:00: iomem range 0x1fff0000-0x1fffffff could not be reserved
[    0.197080] system 00:00: iomem range 0xffff0000-0xffffffff has been reserved
[    0.197084] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[    0.197088] system 00:00: iomem range 0x100000-0x1ffeffff could not be reserved
[    0.197093] system 00:00: iomem range 0xfec00000-0xfec00fff could not be reserved
[    0.197097] system 00:00: iomem range 0xfee00000-0xfee00fff has been reserved
[    0.197101] system 00:00: iomem range 0xfff80000-0xfffeffff has been reserved
[    0.197111] system 00:02: ioport range 0x400-0x47f has been reserved
[    0.197115] system 00:02: ioport range 0x500-0x50f has been reserved
[    0.197123] system 00:03: ioport range 0x4d0-0x4d1 has been reserved
[    0.197127] system 00:03: ioport range 0x800-0x805 has been reserved
[    0.197131] system 00:03: ioport range 0x290-0x297 has been reserved
[    0.231921] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[    0.231927] pci 0000:00:01.0:   IO window: 0xa000-0xafff
[    0.231934] pci 0000:00:01.0:   MEM window: 0xea000000-0xea0fffff
[    0.231940] pci 0000:00:01.0:   PREFETCH window: 0xe0000000-0xe7ffffff
[    0.231963] pci 0000:00:01.0: setting latency timer to 64
[    0.231970] pci_bus 0000:00: resource 0 io:  [0x00-0xffff]
[    0.231974] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[    0.231978] pci_bus 0000:01: resource 0 io:  [0xa000-0xafff]
[    0.231982] pci_bus 0000:01: resource 1 mem: [0xea000000-0xea0fffff]
[    0.231985] pci_bus 0000:01: resource 2 pref mem [0xe0000000-0xe7ffffff]
[    0.232034] NET: Registered protocol family 2
[    0.232164] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.232590] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.232696] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[    0.232798] TCP: Hash tables configured (established 16384 bind 16384)
[    0.232802] TCP reno registered
[    0.232895] NET: Registered protocol family 1
[    0.232921] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[    0.232986] pci 0000:01:00.0: Boot video device
[    0.233250] Scanning for low memory corruption every 60 seconds
[    0.233366] audit: initializing netlink socket (disabled)
[    0.233382] type=2000 audit(1308079590.230:1): initialized
[    0.241655] Trying to unpack rootfs image as initramfs...
[    0.251109] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[    0.258929] VFS: Disk quotas dquot_6.5.2
[    0.259032] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.259849] fuse init (API version 7.13)
[    0.259970] msgmni has been set to 968
[    0.260262] alg: No test for stdrng (krng)
[    0.260346] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.260351] io scheduler noop registered
[    0.260354] io scheduler anticipatory registered
[    0.260357] io scheduler deadline registered
[    0.260413] io scheduler cfq registered (default)
[    0.260575] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.260612] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.260714] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    0.260721] ACPI: Power Button [PWRB]
[    0.260785] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[    0.260795] ACPI: Sleep Button [SLPB]
[    0.260885] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    0.260889] ACPI: Power Button [PWRF]
[    0.263015] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.263127] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.263231] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[    0.263658] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.263815] 00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[    0.265280] brd: module loaded
[    0.265923] loop: module loaded
[    0.266044] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[    0.266436] ACPI: PCI Interrupt Link [ALKA] disabled and referenced, BIOS bug
[    0.266622] ACPI: PCI Interrupt Link [ALKA] BIOS reported IRQ 0, using IRQ 20
[    0.266626] ACPI: PCI Interrupt Link [ALKA] enabled at IRQ 20
[    0.266634]   alloc irq_desc for 20 on node -1
[    0.266637]   alloc kstat_irqs on node -1
[    0.266649] pata_acpi 0000:00:11.1: PCI INT A -> Link[ALKA] -> GSI 20 (level, low) -> IRQ 20
[    0.266725] pata_acpi 0000:00:11.1: PCI INT A disabled
[    0.271357] isapnp: Scanning for PnP cards...
[    0.277215] Fixed MDIO Bus: probed
[    0.277270] PPP generic driver version 2.4.2
[    0.277347] tun: Universal TUN/TAP device driver, 1.6
[    0.277351] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.277482] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.277514]   alloc irq_desc for 16 on node -1
[    0.277517]   alloc kstat_irqs on node -1
[    0.277526] ehci_hcd 0000:00:0b.2: PCI INT C -> GSI 16 (level, low) -> IRQ 16
[    0.277549] ehci_hcd 0000:00:0b.2: EHCI Host Controller
[    0.277597] ehci_hcd 0000:00:0b.2: new USB bus registered, assigned bus number 1
[    0.277684] ehci_hcd 0000:00:0b.2: irq 16, io mem 0xea100000
[    0.326661] ehci_hcd 0000:00:0b.2: USB 2.0 started, EHCI 1.00
[    0.326828] usb usb1: configuration #1 chosen from 1 choice
[    0.326877] hub 1-0:1.0: USB hub found
[    0.326905] hub 1-0:1.0: 4 ports detected
[    0.326983] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.327006] uhci_hcd: USB Universal Host Controller Interface driver
[    0.327068]   alloc irq_desc for 18 on node -1
[    0.327073]   alloc kstat_irqs on node -1
[    0.327081] uhci_hcd 0000:00:0b.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[    0.327093] uhci_hcd 0000:00:0b.0: UHCI Host Controller
[    0.327140] uhci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
[    0.327194] uhci_hcd 0000:00:0b.0: irq 18, io base 0x0000d000
[    0.327315] usb usb2: configuration #1 chosen from 1 choice
[    0.327356] hub 2-0:1.0: USB hub found
[    0.327369] hub 2-0:1.0: 2 ports detected
[    0.327428]   alloc irq_desc for 19 on node -1
[    0.327432]   alloc kstat_irqs on node -1
[    0.327438] uhci_hcd 0000:00:0b.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    0.327450] uhci_hcd 0000:00:0b.1: UHCI Host Controller
[    0.327504] uhci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 3
[    0.327554] uhci_hcd 0000:00:0b.1: irq 19, io base 0x0000d400
[    0.327682] usb usb3: configuration #1 chosen from 1 choice
[    0.327723] hub 3-0:1.0: USB hub found
[    0.327736] hub 3-0:1.0: 2 ports detected
[    0.327873] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    0.328398] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.328409] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.328598] mice: PS/2 mouse device common for all mice
[    0.328796] rtc_cmos 00:05: RTC can wake from S4
[    0.328854] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[    0.328907] rtc0: alarms up to one year, y3k, 242 bytes nvram
[    0.329054] device-mapper: uevent: version 1.0.3
[    0.331118] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[    0.332745] device-mapper: multipath: version 1.1.0 loaded
[    0.332751] device-mapper: multipath round-robin: version 1.0.0 loaded
[    0.333768] EISA: Probing bus 0 at eisa.0
[    0.333811] EISA: Detected 0 cards.
[    0.333815] cpuidle: using governor ladder
[    0.333819] cpuidle: using governor menu
[    0.334396] TCP cubic registered
[    0.334572] NET: Registered protocol family 10
[    0.335190] lo: Disabled Privacy Extensions
[    0.335595] NET: Registered protocol family 17
[    0.335638] Using IPI No-Shortcut mode
[    0.335772] registered taskstats version 1
[    0.336111] rtc_cmos 00:05: setting system clock to 2011-06-14 19:26:31 UTC (1308079591)
[    0.336116] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[    0.336118] EDD information not available.
[    0.347871] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[    0.766418] usb 1-3: new high speed USB device using ehci_hcd and address 3
[    0.942970] isapnp: No Plug & Play device found
[    0.976907] usb 1-3: configuration #1 chosen from 1 choice
[    1.037736] Freeing initrd memory: 12800k freed
[    1.054245] Freeing unused kernel memory: 620k freed
[    1.055057] Write protecting the kernel text: 4540k
[    1.055083] Write protecting the kernel read-only data: 1668k
[    1.084811] udev: starting version 151
[    1.232058] usb 2-2: new low speed USB device using uhci_hcd and address 2
[    1.361305] pata_via 0000:00:11.1: version 0.3.4
[    1.361331] pata_via 0000:00:11.1: PCI INT A -> Link[ALKA] -> GSI 20 (level, low) -> IRQ 20
[    1.361606] Linux agpgart interface v0.103
[    1.364983] scsi0 : pata_via
[    1.365234] scsi1 : pata_via
[    1.370506] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xe400 irq 14
[    1.370511] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xe408 irq 15
[    1.370744] agpgart: Detected VIA PM800/PN800/PM880/PN880 chipset
[    1.373948] agpgart-via 0000:00:00.0: AGP aperture is 32M @ 0xe8000000
[    1.406370] usb 2-2: configuration #1 chosen from 1 choice
[    1.488093] [drm] Initialized drm 1.1.0 20060810
[    1.588651] ata1.00: ATA-6: ST3200822A, 3.01, max UDMA/100
[    1.588657] ata1.00: 390721968 sectors, multi 16: LBA48
[    1.604511] ata1.00: configured for UDMA/100
[    1.604692] scsi 0:0:0:0: Direct-Access     ATA      ST3200822A       3.01 PQ: 0 ANSI: 5
[    1.604932] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    1.605395] sd 0:0:0:0: [sda] 390721968 512-byte logical blocks: (200 GB/186 GiB)
[    1.605478] sd 0:0:0:0: [sda] Write Protect is off
[    1.605483] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.605526] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.605754]  sda: sda1 sda2 < sda5 >
[    1.647655] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.768435] ata2.00: ATAPI: LITE-ON CD-RW SOHR-5238S, 4S04, max UDMA/33
[    1.784314] ata2.00: configured for UDMA/33
[    1.785676] scsi 1:0:0:0: CD-ROM            LITE-ON  CD-RW SOHR-5238S 4S04 PQ: 0 ANSI: 5
[    1.789420] sr0: scsi3-mmc drive: 31x/52x writer cd/rw xa/form2 cdda tray
[    1.789425] Uniform CD-ROM driver Revision: 3.20
[    1.789575] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    1.789667] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    1.809001] usbcore: registered new interface driver hiddev
[    1.834942] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:0b.0/usb2/2-2/2-2:1.0/input/input5
[    1.835096] generic-usb 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:0b.0-2/input0
[    1.835134] usbcore: registered new interface driver usbhid
[    1.835139] usbhid: v2.6:USB HID core driver
[    1.863951] [drm] radeon defaulting to kernel modesetting.
[    1.863958] [drm] radeon kernel modesetting enabled.
[    1.864069] radeon 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    1.869157] [drm] radeon: Initializing kernel modesetting.
[    1.869265] [drm] register mmio base: 0xEA020000
[    1.869269] [drm] register mmio size: 65536
[    1.869564] [drm] GPU reset succeed (RBBM_STATUS=0x00000140)
[    1.869589] agpgart-via 0000:00:00.0: AGP 3.5 bridge
[    1.869610] agpgart-via 0000:00:00.0: bridge is in legacy mode, falling back to 2.x
[    1.869621] agpgart-via 0000:00:00.0: putting AGP V2 device into 4x mode
[    1.869698] radeon 0000:01:00.0: putting AGP V2 device into 4x mode
[    1.869704] [drm] radeon: VRAM 64M
[    1.869707] [drm] radeon: VRAM from 0x00000000 to 0x03FFFFFF
[    1.869710] [drm] radeon: GTT 32M
[    1.869712] [drm] radeon: GTT from 0xE8000000 to 0xE9FFFFFF
[    1.869736] [drm] radeon: irq initialized.
[    1.869967] [drm] Detected VRAM RAM=64M, BAR=128M
[    1.869974] [drm] RAM width 64bits DDR
[    1.870228] [TTM] Zone  kernel: Available graphics memory: 254616 kiB.
[    1.870255] [drm] radeon: 64M of VRAM memory ready
[    1.870259] [drm] radeon: 32M of GTT memory ready.
[    1.880435] [drm] radeon: cp idle (0x00008080)
[    1.880484] [drm] Loading R100 Microcode
[    1.880755] platform radeon_cp.0: firmware: requesting radeon/R100_cp.bin
[    1.890783] [drm] radeon: ring at 0x00000000E8000000
[    1.890806] [drm] ring test succeeded in 1 usecs
[    1.896128] [drm] radeon: ib pool ready.
[    1.896238] [drm] ib test succeeded in 0 usecs
[    1.896608] [drm] DFP table revision: 2
[    1.896857] [drm] Default TV standard: NTSC
[    1.896861] [drm] 27.000000000 MHz TV ref clk
[    1.896864] [drm] No TV DAC info found in BIOS
[    1.896869] [drm] Default TV standard: NTSC
[    1.896871] [drm] 27.000000000 MHz TV ref clk
[    1.896947] [drm] Radeon Display Connectors
[    1.896950] [drm] Connector 0:
[    1.896953] [drm]   VGA
[    1.896957] [drm]   DDC: 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60
[    1.896959] [drm]   Encoders:
[    1.896962] [drm]     CRT1: INTERNAL_DAC1
[    1.896965] [drm] Connector 1:
[    1.896967] [drm]   DVI-D
[    1.896969] [drm]   HPD1
[    1.896972] [drm]   DDC: 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[    1.896974] [drm]   Encoders:
[    1.896977] [drm]     DFP1: INTERNAL_TMDS1
[    1.896979] [drm] Connector 2:
[    1.896982] [drm]   S-video
[    1.896984] [drm]   Encoders:
[    1.896986] [drm]     TV1: INTERNAL_DAC2
[    2.036473] [drm] fb mappable at 0xE0040000
[    2.036478] [drm] vram apper at 0xE0000000
[    2.036481] [drm] size 3145728
[    2.036483] [drm] fb depth is 24
[    2.036486] [drm]    pitch is 4096
[    2.036661] fb0: radeondrmfb frame buffer device
[    2.036665] registered panic notifier
[    2.036674] [drm] Initialized radeon 2.0.0 20080528 for 0000:01:00.0 on minor 0
[    2.039883] vga16fb: initializing
[    2.039891] vga16fb: mapped to 0xc00a0000
[    2.039897] vga16fb: not registering due to another framebuffer present
[    2.222432] Console: switching to colour frame buffer device 128x48
[    2.692093] xor: automatically using best checksumming function: pIII_sse
[    2.712010]    pIII_sse  :  4512.000 MB/sec
[    2.712014] xor: using function: pIII_sse (4512.000 MB/sec)
[    2.732856] device-mapper: dm-raid45: initialized v0.2594b
[    2.885677] EXT4-fs (sda1): mounted filesystem with ordered data mode
[    9.719260] Adding 1490936k swap on /dev/sda5.  Priority:-1 extents:1 across:1490936k
[    9.765873] udev: starting version 151
[   10.058991] lp: driver loaded but no devices found
[   10.094544] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   10.162937] parport_pc 00:0a: reported by Plug and Play ACPI
[   10.163003] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[   10.334968] lp0: using parport0 (interrupt-driven).
[   10.500597] irda_init()
[   10.500621] NET: Registered protocol family 23
[   10.560884] parport_serial 0000:00:09.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[   10.560915] parport1: PC-style at 0xb800 [PCSPP,TRISTATE,EPP]
[   10.576439] ppdev: user-space parallel port driver
[   10.602916] usbcore: registered new interface driver cdc_ether
[   10.605349] gameport: NS558 PnP Gameport is pnp00:0e/gameport0, io 0x201, speed 764kHz
[   10.644442] lp1: using parport1 (polling).
[   10.644666] 0000:00:09.0: ttyS2 at I/O 0xb000 (irq = 16) is a 16550A
[   10.644876] 0000:00:09.0: ttyS3 at I/O 0xb400 (irq = 16) is a 16550A
[   10.659616] usb0: register 'rndis_host' at usb-0000:00:0b.2-3, RNDIS device, c6:b8:47:a2:84:aa
[   10.659662] usbcore: registered new interface driver rndis_host
[   10.719823] psmouse serio1: ID: 10 00 64
[   10.754167] cfg80211: Calling CRDA to update world regulatory domain
[   10.782116] gameport: EMU10K1 is pci0000:00:0a.1/gameport0, io 0xcc00, speed 962kHz
[   10.789218] usbcore: registered new interface driver rndis_wlan
[   10.927291] cfg80211: World regulatory domain updated:
[   10.927298] 	(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   10.927303] 	(2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   10.927307] 	(2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   10.927311] 	(2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[   10.927315] 	(5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   10.927318] 	(5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[   10.969411] type=1505 audit(1308079602.131:2):  operation="profile_load" pid=623 name="/sbin/dhclient3"
[   10.970161] type=1505 audit(1308079602.131:3):  operation="profile_load" pid=623 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[   10.970560] type=1505 audit(1308079602.131:4):  operation="profile_load" pid=623 name="/usr/lib/connman/scripts/dhclient-script"
[   11.188755]   alloc irq_desc for 17 on node -1
[   11.188761]   alloc kstat_irqs on node -1
[   11.188773] EMU10K1_Audigy 0000:00:0a.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[   11.301093] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input6
[   11.702487] type=1505 audit(1308079602.863:5):  operation="profile_load" pid=839 name="/usr/share/gdm/guest-session/Xsession"
[   11.711161] type=1505 audit(1308079602.871:6):  operation="profile_replace" pid=841 name="/sbin/dhclient3"
[   11.711904] type=1505 audit(1308079602.871:7):  operation="profile_replace" pid=841 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[   11.735846] type=1505 audit(1308079602.895:8):  operation="profile_replace" pid=841 name="/usr/lib/connman/scripts/dhclient-script"
[   11.762307] type=1505 audit(1308079602.923:9):  operation="profile_load" pid=847 name="/usr/bin/evince"
[   11.785946] type=1505 audit(1308079602.947:10):  operation="profile_load" pid=847 name="/usr/bin/evince-previewer"
[   11.792427] type=1505 audit(1308079602.955:11):  operation="profile_load" pid=847 name="/usr/bin/evince-thumbnailer"
[   22.464016] usb0: no IPv6 routers present
[   62.965976] I-pipe: Domain RTAI registered.
[   62.965988] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[   62.965991] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[   62.966000] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[   62.966003] PIPELINE layers:
[   62.966008] e14b1e20 9ac15d93 RTAI 200
[   62.966011] c085cb20 0 Linux 100
[   63.002594] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[   63.002760] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[   63.002767] RTAI[sched]: hard timer type/freq = APIC/8299581(Hz); default timing: periodic; linear timed lists.
[   63.002772] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2788597000 hz.
[   63.002776] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[   63.002913] RTAI[usi]: enabled.
[   63.128609] RTAI[math]: loaded.
[   63.312608] PARPORT: linux parport parport0 does not support mode 4.
[   63.312612] PARPORT: continuing anyway.
[   64.174081] Failed to communicate with pluto-servo board after programming firmware.
[   64.852289] RTAI[math]: unloaded.
[   64.927819] SCHED releases registered named ALIEN RTGLBH
[   64.941129] RTAI[malloc]: unloaded.
[   65.040020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[   65.045745] I-pipe: Domain RTAI unregistered.
[   65.045759] RTAI[hal]: unmounted.
[  138.931287] I-pipe: Domain RTAI registered.
[  138.931299] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[  138.931302] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[  138.931311] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  138.931314] PIPELINE layers:
[  138.931318] e14b1e20 9ac15d93 RTAI 200
[  138.931322] c085cb20 0 Linux 100
[  138.967884] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  138.968184] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[  138.968191] RTAI[sched]: hard timer type/freq = APIC/8299581(Hz); default timing: periodic; linear timed lists.
[  138.968196] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2788597000 hz.
[  138.968199] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[  138.968345] RTAI[usi]: enabled.
[  139.074494] RTAI[math]: loaded.
[  139.234565] config string '0x0378'
[  946.763047] RTAI[math]: unloaded.
[  946.842580] SCHED releases registered named ALIEN RTGLBH
[  946.857351] RTAI[malloc]: unloaded.
[  946.956024] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  946.962630] I-pipe: Domain RTAI unregistered.
[  946.962644] RTAI[hal]: unmounted.
14 Jun 2011 20:12 #10500 by BigJohnT
This doesn't look good.
Are you running a pluto servo board?
14 Jun 2011 20:18 #10501 by andypugh
Replied by andypugh on topic Re:stepconf woes..
it might be worth trying a manual epp_high address.
I think cat /proc/ioports is the clearest way to find where the addresses are.
Time to create page: 0.097 seconds
