× Forum Header
stepconf woes..
14 Jun 2011 20:25 - 14 Jun 2011 20:26 #10502 by submicro
Replied by submicro on topic Re:stepconf woes..
No i'm not running a servo board. I might have started with the wrong sample? but the mode thing worries me. But I do have a parallel port card as well that I can use.
I'll post another, and I'll make sure to use the right sample config.
Last edit: 14 Jun 2011 20:26 by submicro.
14 Jun 2011 20:30 #10503 by submicro
Some more fine reading material.............
[ 0.185164] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 10 *11 12)
[ 0.185435] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 10 11 12) *5
[ 0.185711] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 11 12) *5
[ 0.185986] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 *11 12)
[ 0.186213] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.186431] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.186650] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.186868] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.187193] ACPI: PCI Interrupt Link [ALKA] (IRQs 20) *0, disabled.
[ 0.187459] ACPI: PCI Interrupt Link [ALKB] (IRQs *21), disabled.
[ 0.187725] ACPI: PCI Interrupt Link [ALKC] (IRQs *22), disabled.
[ 0.188044] ACPI: PCI Interrupt Link [ALKD] (IRQs *23), disabled.
[ 0.188182] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.188187] vgaarb: loaded
[ 0.188380] SCSI subsystem initialized
[ 0.188460] libata version 3.00 loaded.
[ 0.188563] usbcore: registered new interface driver usbfs
[ 0.188583] usbcore: registered new interface driver hub
[ 0.188623] usbcore: registered new device driver usb
[ 0.188812] ACPI: WMI: Mapper loaded
[ 0.188816] PCI: Using ACPI for IRQ routing
[ 0.189003] NetLabel: Initializing
[ 0.189007] NetLabel: domain hash size = 128
[ 0.189009] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.189028] NetLabel: unlabeled traffic allowed by default
[ 0.189071] Switching to clocksource tsc
[ 0.191763] AppArmor: AppArmor Filesystem Enabled
[ 0.191779] pnp: PnP ACPI init
[ 0.191797] ACPI: bus type pnp registered
[ 0.197030] pnp: PnP ACPI: found 15 devices
[ 0.197034] ACPI: ACPI bus type pnp unregistered
[ 0.197041] PnPBIOS: Disabled by ACPI PNP
[ 0.197058] system 00:00: iomem range 0xcd000-0xcffff has been reserved
[ 0.197063] system 00:00: iomem range 0xf0000-0xf7fff could not be reserved
[ 0.197067] system 00:00: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.197071] system 00:00: iomem range 0xfc000-0xfffff could not be reserved
[ 0.197076] system 00:00: iomem range 0x1fff0000-0x1fffffff could not be reserved
[ 0.197080] system 00:00: iomem range 0xffff0000-0xffffffff has been reserved
[ 0.197084] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.197088] system 00:00: iomem range 0x100000-0x1ffeffff could not be reserved
[ 0.197093] system 00:00: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.197097] system 00:00: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.197101] system 00:00: iomem range 0xfff80000-0xfffeffff has been reserved
[ 0.197111] system 00:02: ioport range 0x400-0x47f has been reserved
[ 0.197115] system 00:02: ioport range 0x500-0x50f has been reserved
[ 0.197123] system 00:03: ioport range 0x4d0-0x4d1 has been reserved
[ 0.197127] system 00:03: ioport range 0x800-0x805 has been reserved
[ 0.197131] system 00:03: ioport range 0x290-0x297 has been reserved
[ 0.231921] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.231927] pci 0000:00:01.0: IO window: 0xa000-0xafff
[ 0.231934] pci 0000:00:01.0: MEM window: 0xea000000-0xea0fffff
[ 0.231940] pci 0000:00:01.0: PREFETCH window: 0xe0000000-0xe7ffffff
[ 0.231963] pci 0000:00:01.0: setting latency timer to 64
[ 0.231970] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.231974] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.231978] pci_bus 0000:01: resource 0 io: [0xa000-0xafff]
[ 0.231982] pci_bus 0000:01: resource 1 mem: [0xea000000-0xea0fffff]
[ 0.231985] pci_bus 0000:01: resource 2 pref mem [0xe0000000-0xe7ffffff]
[ 0.232034] NET: Registered protocol family 2
[ 0.232164] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.232590] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.232696] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.232798] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.232802] TCP reno registered
[ 0.232895] NET: Registered protocol family 1
[ 0.232921] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.232986] pci 0000:01:00.0: Boot video device
[ 0.233250] Scanning for low memory corruption every 60 seconds
[ 0.233366] audit: initializing netlink socket (disabled)
[ 0.233382] type=2000 audit(1308079590.230:1): initialized
[ 0.241655] Trying to unpack rootfs image as initramfs...
[ 0.251109] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.258929] VFS: Disk quotas dquot_6.5.2
[ 0.259032] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.259849] fuse init (API version 7.13)
[ 0.259970] msgmni has been set to 968
[ 0.260262] alg: No test for stdrng (krng)
[ 0.260346] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.260351] io scheduler noop registered
[ 0.260354] io scheduler anticipatory registered
[ 0.260357] io scheduler deadline registered
[ 0.260413] io scheduler cfq registered (default)
[ 0.260575] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.260612] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.260714] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.260721] ACPI: Power Button [PWRB]
[ 0.260785] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 0.260795] ACPI: Sleep Button [SLPB]
[ 0.260885] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.260889] ACPI: Power Button [PWRF]
[ 0.263015] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.263127] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.263231] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.263658] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.263815] 00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.265280] brd: module loaded
[ 0.265923] loop: module loaded
[ 0.266044] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.266436] ACPI: PCI Interrupt Link [ALKA] disabled and referenced, BIOS bug
[ 0.266622] ACPI: PCI Interrupt Link [ALKA] BIOS reported IRQ 0, using IRQ 20
[ 0.266626] ACPI: PCI Interrupt Link [ALKA] enabled at IRQ 20
[ 0.266634] alloc irq_desc for 20 on node -1
[ 0.266637] alloc kstat_irqs on node -1
[ 0.266649] pata_acpi 0000:00:11.1: PCI INT A -> Link[ALKA] -> GSI 20 (level, low) -> IRQ 20
[ 0.266725] pata_acpi 0000:00:11.1: PCI INT A disabled
[ 0.271357] isapnp: Scanning for PnP cards...
[ 0.277215] Fixed MDIO Bus: probed
[ 0.277270] PPP generic driver version 2.4.2
[ 0.277347] tun: Universal TUN/TAP device driver, 1.6
[ 0.277351] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.277482] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.277514] alloc irq_desc for 16 on node -1
[ 0.277517] alloc kstat_irqs on node -1
[ 0.277526] ehci_hcd 0000:00:0b.2: PCI INT C -> GSI 16 (level, low) -> IRQ 16
[ 0.277549] ehci_hcd 0000:00:0b.2: EHCI Host Controller
[ 0.277597] ehci_hcd 0000:00:0b.2: new USB bus registered, assigned bus number 1
[ 0.277684] ehci_hcd 0000:00:0b.2: irq 16, io mem 0xea100000
[ 0.326661] ehci_hcd 0000:00:0b.2: USB 2.0 started, EHCI 1.00
[ 0.326828] usb usb1: configuration #1 chosen from 1 choice
[ 0.326877] hub 1-0:1.0: USB hub found
[ 0.326905] hub 1-0:1.0: 4 ports detected
[ 0.326983] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.327006] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.327068] alloc irq_desc for 18 on node -1
[ 0.327073] alloc kstat_irqs on node -1
[ 0.327081] uhci_hcd 0000:00:0b.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.327093] uhci_hcd 0000:00:0b.0: UHCI Host Controller
[ 0.327140] uhci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
[ 0.327194] uhci_hcd 0000:00:0b.0: irq 18, io base 0x0000d000
[ 0.327315] usb usb2: configuration #1 chosen from 1 choice
[ 0.327356] hub 2-0:1.0: USB hub found
[ 0.327369] hub 2-0:1.0: 2 ports detected
[ 0.327428] alloc irq_desc for 19 on node -1
[ 0.327432] alloc kstat_irqs on node -1
[ 0.327438] uhci_hcd 0000:00:0b.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.327450] uhci_hcd 0000:00:0b.1: UHCI Host Controller
[ 0.327504] uhci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 3
[ 0.327554] uhci_hcd 0000:00:0b.1: irq 19, io base 0x0000d400
[ 0.327682] usb usb3: configuration #1 chosen from 1 choice
[ 0.327723] hub 3-0:1.0: USB hub found
[ 0.327736] hub 3-0:1.0: 2 ports detected
[ 0.327873] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.328398] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.328409] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.328598] mice: PS/2 mouse device common for all mice
[ 0.328796] rtc_cmos 00:05: RTC can wake from S4
[ 0.328854] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.328907] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 0.329054] device-mapper: uevent: version 1.0.3
[ 0.331118] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.332745] device-mapper: multipath: version 1.1.0 loaded
[ 0.332751] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.333768] EISA: Probing bus 0 at eisa.0
[ 0.333811] EISA: Detected 0 cards.
[ 0.333815] cpuidle: using governor ladder
[ 0.333819] cpuidle: using governor menu
[ 0.334396] TCP cubic registered
[ 0.334572] NET: Registered protocol family 10
[ 0.335190] lo: Disabled Privacy Extensions
[ 0.335595] NET: Registered protocol family 17
[ 0.335638] Using IPI No-Shortcut mode
[ 0.335772] registered taskstats version 1
[ 0.336111] rtc_cmos 00:05: setting system clock to 2011-06-14 19:26:31 UTC (1308079591)
[ 0.336116] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.336118] EDD information not available.
[ 0.347871] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.766418] usb 1-3: new high speed USB device using ehci_hcd and address 3
[ 0.942970] isapnp: No Plug & Play device found
[ 0.976907] usb 1-3: configuration #1 chosen from 1 choice
[ 1.037736] Freeing initrd memory: 12800k freed
[ 1.054245] Freeing unused kernel memory: 620k freed
[ 1.055057] Write protecting the kernel text: 4540k
[ 1.055083] Write protecting the kernel read-only data: 1668k
[ 1.084811] udev: starting version 151
[ 1.232058] usb 2-2: new low speed USB device using uhci_hcd and address 2
[ 1.361305] pata_via 0000:00:11.1: version 0.3.4
[ 1.361331] pata_via 0000:00:11.1: PCI INT A -> Link[ALKA] -> GSI 20 (level, low) -> IRQ 20
[ 1.361606] Linux agpgart interface v0.103
[ 1.364983] scsi0 : pata_via
[ 1.365234] scsi1 : pata_via
[ 1.370506] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xe400 irq 14
[ 1.370511] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xe408 irq 15
[ 1.370744] agpgart: Detected VIA PM800/PN800/PM880/PN880 chipset
[ 1.373948] agpgart-via 0000:00:00.0: AGP aperture is 32M @ 0xe8000000
[ 1.406370] usb 2-2: configuration #1 chosen from 1 choice
[ 1.488093] [drm] Initialized drm 1.1.0 20060810
[ 1.588651] ata1.00: ATA-6: ST3200822A, 3.01, max UDMA/100
[ 1.588657] ata1.00: 390721968 sectors, multi 16: LBA48
[ 1.604511] ata1.00: configured for UDMA/100
[ 1.604692] scsi 0:0:0:0: Direct-Access ATA ST3200822A 3.01 PQ: 0 ANSI: 5
[ 1.604932] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.605395] sd 0:0:0:0: [sda] 390721968 512-byte logical blocks: (200 GB/186 GiB)
[ 1.605478] sd 0:0:0:0: [sda] Write Protect is off
[ 1.605483] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.605526] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.605754] sda: sda1 sda2 < sda5 >
[ 1.647655] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.768435] ata2.00: ATAPI: LITE-ON CD-RW SOHR-5238S, 4S04, max UDMA/33
[ 1.784314] ata2.00: configured for UDMA/33
[ 1.785676] scsi 1:0:0:0: CD-ROM LITE-ON CD-RW SOHR-5238S 4S04 PQ: 0 ANSI: 5
[ 1.789420] sr0: scsi3-mmc drive: 31x/52x writer cd/rw xa/form2 cdda tray
[ 1.789425] Uniform CD-ROM driver Revision: 3.20
[ 1.789575] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.789667] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.809001] usbcore: registered new interface driver hiddev
[ 1.834942] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:0b.0/usb2/2-2/2-2:1.0/input/input5
[ 1.835096] generic-usb 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:0b.0-2/input0
[ 1.835134] usbcore: registered new interface driver usbhid
[ 1.835139] usbhid: v2.6:USB HID core driver
[ 1.863951] [drm] radeon defaulting to kernel modesetting.
[ 1.863958] [drm] radeon kernel modesetting enabled.
[ 1.864069] radeon 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 1.869157] [drm] radeon: Initializing kernel modesetting.
[ 1.869265] [drm] register mmio base: 0xEA020000
[ 1.869269] [drm] register mmio size: 65536
[ 1.869564] [drm] GPU reset succeed (RBBM_STATUS=0x00000140)
[ 1.869589] agpgart-via 0000:00:00.0: AGP 3.5 bridge
[ 1.869610] agpgart-via 0000:00:00.0: bridge is in legacy mode, falling back to 2.x
[ 1.869621] agpgart-via 0000:00:00.0: putting AGP V2 device into 4x mode
[ 1.869698] radeon 0000:01:00.0: putting AGP V2 device into 4x mode
[ 1.869704] [drm] radeon: VRAM 64M
[ 1.869707] [drm] radeon: VRAM from 0x00000000 to 0x03FFFFFF
[ 1.869710] [drm] radeon: GTT 32M
[ 1.869712] [drm] radeon: GTT from 0xE8000000 to 0xE9FFFFFF
[ 1.869736] [drm] radeon: irq initialized.
[ 1.869967] [drm] Detected VRAM RAM=64M, BAR=128M
[ 1.869974] [drm] RAM width 64bits DDR
[ 1.870228] [TTM] Zone kernel: Available graphics memory: 254616 kiB.
[ 1.870255] [drm] radeon: 64M of VRAM memory ready
[ 1.870259] [drm] radeon: 32M of GTT memory ready.
[ 1.880435] [drm] radeon: cp idle (0x00008080)
[ 1.880484] [drm] Loading R100 Microcode
[ 1.880755] platform radeon_cp.0: firmware: requesting radeon/R100_cp.bin
[ 1.890783] [drm] radeon: ring at 0x00000000E8000000
[ 1.890806] [drm] ring test succeeded in 1 usecs
[ 1.896128] [drm] radeon: ib pool ready.
[ 1.896238] [drm] ib test succeeded in 0 usecs
[ 1.896608] [drm] DFP table revision: 2
[ 1.896857] [drm] Default TV standard: NTSC
[ 1.896861] [drm] 27.000000000 MHz TV ref clk
[ 1.896864] [drm] No TV DAC info found in BIOS
[ 1.896869] [drm] Default TV standard: NTSC
[ 1.896871] [drm] 27.000000000 MHz TV ref clk
[ 1.896947] [drm] Radeon Display Connectors
[ 1.896950] [drm] Connector 0:
[ 1.896953] [drm] VGA
[ 1.896957] [drm] DDC: 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60
[ 1.896959] [drm] Encoders:
[ 1.896962] [drm] CRT1: INTERNAL_DAC1
[ 1.896965] [drm] Connector 1:
[ 1.896967] [drm] DVI-D
[ 1.896969] [drm] HPD1
[ 1.896972] [drm] DDC: 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[ 1.896974] [drm] Encoders:
[ 1.896977] [drm] DFP1: INTERNAL_TMDS1
[ 1.896979] [drm] Connector 2:
[ 1.896982] [drm] S-video
[ 1.896984] [drm] Encoders:
[ 1.896986] [drm] TV1: INTERNAL_DAC2
[ 2.036473] [drm] fb mappable at 0xE0040000
[ 2.036478] [drm] vram apper at 0xE0000000
[ 2.036481] [drm] size 3145728
[ 2.036483] [drm] fb depth is 24
[ 2.036486] [drm] pitch is 4096
[ 2.036661] fb0: radeondrmfb frame buffer device
[ 2.036665] registered panic notifier
[ 2.036674] [drm] Initialized radeon 2.0.0 20080528 for 0000:01:00.0 on minor 0
[ 2.039883] vga16fb: initializing
[ 2.039891] vga16fb: mapped to 0xc00a0000
[ 2.039897] vga16fb: not registering due to another framebuffer present
[ 2.222432] Console: switching to colour frame buffer device 128x48
[ 2.692093] xor: automatically using best checksumming function: pIII_sse
[ 2.712010] pIII_sse : 4512.000 MB/sec
[ 2.712014] xor: using function: pIII_sse (4512.000 MB/sec)
[ 2.732856] device-mapper: dm-raid45: initialized v0.2594b
[ 2.885677] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 9.719260] Adding 1490936k swap on /dev/sda5. Priority:-1 extents:1 across:1490936k
[ 9.765873] udev: starting version 151
[ 10.058991] lp: driver loaded but no devices found
[ 10.094544] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 10.162937] parport_pc 00:0a: reported by Plug and Play ACPI
[ 10.163003] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 10.334968] lp0: using parport0 (interrupt-driven).
[ 10.500597] irda_init()
[ 10.500621] NET: Registered protocol family 23
[ 10.560884] parport_serial 0000:00:09.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 10.560915] parport1: PC-style at 0xb800 [PCSPP,TRISTATE,EPP]
[ 10.576439] ppdev: user-space parallel port driver
[ 10.602916] usbcore: registered new interface driver cdc_ether
[ 10.605349] gameport: NS558 PnP Gameport is pnp00:0e/gameport0, io 0x201, speed 764kHz
[ 10.644442] lp1: using parport1 (polling).
[ 10.644666] 0000:00:09.0: ttyS2 at I/O 0xb000 (irq = 16) is a 16550A
[ 10.644876] 0000:00:09.0: ttyS3 at I/O 0xb400 (irq = 16) is a 16550A
[ 10.659616] usb0: register 'rndis_host' at usb-0000:00:0b.2-3, RNDIS device, c6:b8:47:a2:84:aa
[ 10.659662] usbcore: registered new interface driver rndis_host
[ 10.719823] psmouse serio1: ID: 10 00 64
[ 10.754167] cfg80211: Calling CRDA to update world regulatory domain
[ 10.782116] gameport: EMU10K1 is pci0000:00:0a.1/gameport0, io 0xcc00, speed 962kHz
[ 10.789218] usbcore: registered new interface driver rndis_wlan
[ 10.927291] cfg80211: World regulatory domain updated:
[ 10.927298] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 10.927303] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 10.927307] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 10.927311] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 10.927315] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 10.927318] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 10.969411] type=1505 audit(1308079602.131:2): operation="profile_load" pid=623 name="/sbin/dhclient3"
[ 10.970161] type=1505 audit(1308079602.131:3): operation="profile_load" pid=623 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 10.970560] type=1505 audit(1308079602.131:4): operation="profile_load" pid=623 name="/usr/lib/connman/scripts/dhclient-script"
[ 11.188755] alloc irq_desc for 17 on node -1
[ 11.188761] alloc kstat_irqs on node -1
[ 11.188773] EMU10K1_Audigy 0000:00:0a.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 11.301093] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input6
[ 11.702487] type=1505 audit(1308079602.863:5): operation="profile_load" pid=839 name="/usr/share/gdm/guest-session/Xsession"
[ 11.711161] type=1505 audit(1308079602.871:6): operation="profile_replace" pid=841 name="/sbin/dhclient3"
[ 11.711904] type=1505 audit(1308079602.871:7): operation="profile_replace" pid=841 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 11.735846] type=1505 audit(1308079602.895:8): operation="profile_replace" pid=841 name="/usr/lib/connman/scripts/dhclient-script"
Usage: grep [OPTION]... PATTERN [FILE]...
Try `grep --help' for more information.
[ 11.762307] type=1505 audit(1308079602.923:9): operation="profile_load" pid=847 name="/usr/bin/evince"
[ 11.785946] type=1505 audit(1308079602.947:10): operation="profile_load" pid=847 name="/usr/bin/evince-previewer"
[ 11.792427] type=1505 audit(1308079602.955:11): operation="profile_load" pid=847 name="/usr/bin/evince-thumbnailer"
[ 22.464016] usb0: no IPv6 routers present
[ 62.965976] I-pipe: Domain RTAI registered.
[ 62.965988] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 62.965991] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 62.966000] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 62.966003] PIPELINE layers:
[ 62.966008] e14b1e20 9ac15d93 RTAI 200
[ 62.966011] c085cb20 0 Linux 100
[ 63.002594] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 63.002760] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 63.002767] RTAI[sched]: hard timer type/freq = APIC/8299581(Hz); default timing: periodic; linear timed lists.
[ 63.002772] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2788597000 hz.
[ 63.002776] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 63.002913] RTAI[usi]: enabled.
[ 63.128609] RTAI[math]: loaded.
[ 63.312608] PARPORT: linux parport parport0 does not support mode 4.
[ 63.312612] PARPORT: continuing anyway.
[ 64.174081] Failed to communicate with pluto-servo board after programming firmware.
[ 64.852289] RTAI[math]: unloaded.
[ 64.927819] SCHED releases registered named ALIEN RTGLBH
[ 64.941129] RTAI[malloc]: unloaded.
[ 65.040020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 65.045745] I-pipe: Domain RTAI unregistered.
[ 65.045759] RTAI[hal]: unmounted.
[ 138.931287] I-pipe: Domain RTAI registered.
[ 138.931299] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 138.931302] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 138.931311] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 138.931314] PIPELINE layers:
[ 138.931318] e14b1e20 9ac15d93 RTAI 200
[ 138.931322] c085cb20 0 Linux 100
[ 138.967884] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 138.968184] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 138.968191] RTAI[sched]: hard timer type/freq = APIC/8299581(Hz); default timing: periodic; linear timed lists.
[ 138.968196] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2788597000 hz.
[ 138.968199] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 138.968345] RTAI[usi]: enabled.
[ 139.074494] RTAI[math]: loaded.
[ 139.234565] config string '0x0378'
[ 946.763047] RTAI[math]: unloaded.
[ 946.842580] SCHED releases registered named ALIEN RTGLBH
[ 946.857351] RTAI[malloc]: unloaded.
[ 946.956024] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 946.962630] I-pipe: Domain RTAI unregistered.
[ 946.962644] RTAI[hal]: unmounted.
[ 1638.074975] I-pipe: Domain RTAI registered.
[ 1638.074988] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 1638.074992] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 1638.075000] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1638.075004] PIPELINE layers:
[ 1638.075008] e14b1e20 9ac15d93 RTAI 200
[ 1638.075012] c085cb20 0 Linux 100
[ 1638.108983] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1638.109144] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 1638.109152] RTAI[sched]: hard timer type/freq = APIC/8299581(Hz); default timing: periodic; linear timed lists.
[ 1638.109157] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2788597000 hz.
[ 1638.109161] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1638.109300] RTAI[usi]: enabled.
[ 1638.217177] RTAI[math]: loaded.
[ 1638.323193] config string '0x0378'
[ 1682.985875] RTAI[math]: unloaded.
[ 1683.063351] SCHED releases registered named ALIEN RTGLBH
[ 1683.077135] RTAI[malloc]: unloaded.
[ 1683.176020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1683.181757] I-pipe: Domain RTAI unregistered.
[ 1683.181771] RTAI[hal]: unmounted.
[ 1780.810161] I-pipe: Domain RTAI registered.
[ 1780.810173] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 1780.810177] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 1780.810186] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1780.810189] PIPELINE layers:
[ 1780.810193] e14b1e20 9ac15d93 RTAI 200
[ 1780.810197] c085cb20 0 Linux 100
[ 1780.843255] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1780.843419] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 1780.843427] RTAI[sched]: hard timer type/freq = APIC/8299581(Hz); default timing: periodic; linear timed lists.
[ 1780.843432] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2788597000 hz.
[ 1780.843435] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1780.843587] RTAI[usi]: enabled.
[ 1780.953519] RTAI[math]: loaded.
[ 1781.056815] config string '0x0378'
[ 1854.310118] RTAI[math]: unloaded.
[ 1854.392651] SCHED releases registered named ALIEN RTGLBH
[ 1854.409142] RTAI[malloc]: unloaded.
[ 1854.508020] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1854.514666] I-pipe: Domain RTAI unregistered.
[ 1854.514679] RTAI[hal]: unmounted.
[ 3693.270642] I-pipe: Domain RTAI registered.
[ 3693.270655] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 3693.270658] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 3693.270667] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3693.270670] PIPELINE layers:
[ 3693.270675] e14b1e20 9ac15d93 RTAI 200
[ 3693.270678] c085cb20 0 Linux 100
[ 3693.303644] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3693.303812] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 3693.303820] RTAI[sched]: hard timer type/freq = APIC/8299581(Hz); default timing: periodic; linear timed lists.
[ 3693.303825] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2788597000 hz.
[ 3693.303828] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 3693.303991] RTAI[usi]: enabled.
[ 3693.423219] RTAI[math]: loaded.
[ 3693.535780] config string '0x0378'
[ 3730.650242] RTAI[math]: unloaded.
[ 3730.727613] SCHED releases registered named ALIEN RTGLBH
[ 3730.741153] RTAI[malloc]: unloaded.
[ 3730.840019] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3730.845977] I-pipe: Domain RTAI unregistered.
[ 3730.845991] RTAI[hal]: unmounted.
submicro@submicro-desktop:~$
14 Jun 2011 20:41 #10504 by BigJohnT
Replied by BigJohnT on topic Re:stepconf woes..
I'm sure your not trying to run the stepconf configuration you posted earlier as stepconf doesn't do pluto or epp.
14 Jun 2011 20:56 #10505 by submicro
John, I tested the inputs and got no response from them.
Has anyone had luck using a USB breakout board?
14 Jun 2011 20:59 - 14 Jun 2011 21:06 #10506 by submicro
No john I've been trying to start with the sample config "Stepper inch" and then use stepconf to modify the settings.
Also my pci parallel port card is shown, why isn't my on board parallel port listed as well. See below
submicro@submicro-desktop:~$ halrun -U
submicro@submicro-desktop:~$ lspci -vv
00:00.0 Host bridge: VIA Technologies, Inc. CN333/CN400/PM880 Host Bridge
Subsystem: VIA Technologies, Inc. CN333/CN400/PM880 Host Bridge
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx-
Latency: 8
Region 0: Memory at e8000000 (32-bit, prefetchable) [size=32M]
Capabilities: <access denied>
Kernel driver in use: agpgart-via
Kernel modules: via-agp
00:00.1 Host bridge: VIA Technologies, Inc. CN333/CN400/PM880 Host Bridge
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
00:00.2 Host bridge: VIA Technologies, Inc. CN333/CN400/PM880 CPU Host Bridge
Latency: 0
00:00.3 Host bridge: VIA Technologies, Inc. CN333/CN400/PM880 Host Bridge
Latency: 0
00:00.4 Host bridge: VIA Technologies, Inc. CN333/CN400/PM880 Host Bridge
Latency: 0
00:00.7 Host bridge: VIA Technologies, Inc. CN333/CN400/PM880 Host Bridge
Latency: 0
00:01.0 PCI bridge: VIA Technologies, Inc. VT8237/VX700 PCI Bridge
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000a000-0000afff
Memory behind bridge: ea000000-ea0fffff
Prefetchable memory behind bridge: e0000000-e7ffffff
Secondary status: 66MHz+ FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA+ VGA+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel modules: shpchp
00:09.0 Communication controller: NetMos Technology PCI 9835 Multi-I/O Controller (rev 01)
Subsystem: LSI Logic / Symbios Logic Device 0012
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 16
Region 0: I/O ports at b000
Region 1: I/O ports at b400
Region 2: I/O ports at b800
Region 3: I/O ports at bc00
Region 4: I/O ports at c000
Region 5: I/O ports at c400
Kernel driver in use: parport_serial
Kernel modules: parport_serial
00:0a.0 Multimedia audio controller: Creative Labs SB Live! EMU10k1 (rev 05)
Subsystem: Creative Labs Device 8023
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32 (500ns min, 5000ns max)
Interrupt: pin A routed to IRQ 17
Region 0: I/O ports at c800
Kernel driver in use: EMU10K1_Audigy
Kernel modules: snd-emu10k1
00:0a.1 Input device controller: Creative Labs SB Live! Game Port (rev 05)
Subsystem: Creative Labs Device 0020
Latency: 32
Region 0: I/O ports at cc00
Kernel driver in use: Emu10k1_gameport
Kernel modules: emu10k1-gp
00:0b.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 61)
Subsystem: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32, Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 18
Region 4: I/O ports at d000
Kernel driver in use: uhci_hcd
00:0b.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 61)
Interrupt: pin B routed to IRQ 19
Region 4: I/O ports at d400
00:0b.2 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 63) (prog-if 20)
Subsystem: VIA Technologies, Inc. USB 2.0
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 32, Cache Line Size: 128 bytes
Interrupt: pin C routed to IRQ 16
Region 0: Memory at ea100000 (32-bit, non-prefetchable)
Kernel driver in use: ehci_hcd
00:11.0 ISA bridge: VIA Technologies, Inc. VT8235 ISA Bridge
Subsystem: VIA Technologies, Inc. VT8235 ISA Bridge
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping+ SERR- FastB2B- DisINTx-
Latency: 0
Kernel modules: i2c-viapro, via-ircc
00:11.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06) (prog-if 8a [Master SecP PriP])
Subsystem: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE
Latency: 32
Interrupt: pin A routed to IRQ 20
Region 0: [virtual] Memory at 000001f0 (32-bit, non-prefetchable)
Region 1: [virtual] Memory at 000003f0 (type 3, non-prefetchable)
Region 2: [virtual] Memory at 00000170 (32-bit, non-prefetchable)
Region 3: [virtual] Memory at 00000370 (type 3, non-prefetchable)
Region 4: I/O ports at e400
Kernel driver in use: pata_via
Kernel modules: pata_via
01:00.0 VGA compatible controller: ATI Technologies Inc Radeon RV100 QY [Radeon 7000/VE]
Subsystem: ATI Technologies Inc Device 053a
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32 (2000ns min), Cache Line Size: 32 bytes
Region 0: Memory at e0000000 (32-bit, prefetchable) [size=128M]
Region 1: I/O ports at a000
Region 2: Memory at ea020000 (32-bit, non-prefetchable) [size=64K]
[virtual] Expansion ROM at ea000000 [disabled] [size=128K]
Kernel driver in use: radeon
Kernel modules: radeonfb, radeon
Last edit: 14 Jun 2011 21:06 by submicro.
14 Jun 2011 21:45 - 14 Jun 2011 21:46 #10507 by BigJohnT
You can't edit a sample config with stepconf, if you create a config with stepconf then you can edit it with stepconf. Sample configs must be hand edited.
lspci -v only lists pci and devices connected to the pci buss, your onboard parallel port may not be on the pci buss.
manpages.ubuntu.com/manpages/intrepid/man8/lspci.8.html
dmesg after a fresh start will show the onboard parallel port.
Have you read this short intro to EMC?
www.linuxcnc.org/docs/EMC2_Getting_Started.pdf
Last edit: 14 Jun 2011 21:46 by BigJohnT.
14 Jun 2011 21:47 - 14 Jun 2011 21:48 #10508 by BigJohnT
No.
Last edit: 14 Jun 2011 21:48 by BigJohnT.
14 Jun 2011 21:53 #10509 by submicro
I must admit I've only read about half of it. Thanx for the info, I guess it's time to RTFM!
I'll be back later this evening after I do alot of reading.
Thak you for your time, and patience.
SubMicro
A.K.A Robert
15 Jun 2011 00:18 #10513 by submicro
Ok I read the entire pdf, but found nothing that would help me with my problem.
I'm now halfway through the Integrators manual (had to take a break it's a bit mind numbing!)
I have another question, If parport is the module controlling the pins on the parallel port. Why does lspci -v show this
Flags: medium devsel, IRQ 16
I/O ports at b000
I/O ports at b400
I/O ports at b800
I/O ports at bc00
I/O ports at c000
I/O ports at c400
NOTICE that parport_serial is the module loaded.................Perhaps I'm grasping at straws here but I'm desperate!
I'm thinking of just building myself a new computer with a D510MO motherboard! but what if I have the same problem????
15 Jun 2011 01:03 #10514 by andypugh
Replied by andypugh on topic Re:stepconf woes..
I keep saying this, but try this in the terminal window
cat /proc/ioports
Anyway, perhaps now is the time to get down to basics.
Open 2 terminal windows, lets call then TA and TB
TA:
halrun
TB:
sudo dmesg -c
(dmesg -c clears the dmesg buffer, so you can see which messages come from which command)
TA:
loadrt hal_parport cfg="0x378 0xB800"
TB:
sudo dmesg -c
TA:
setp parport.0.pin-01-out 1
setp parport.1.pin-01-out 1
TB:
sudo dmesg -c
TA:
setp parport.0.pin-01-out 0
setp parport.1.pin-01-out 0
(and so on…)
Time to create page: 0.143 seconds
