stepconf woes..
- submicro
- BigJohnT
- Thank you received: 1176
- submicro
As I said before pins 1-6 of the parallel port remain at a constant +5.26vdc, regardless of whether EMC is running or not. Nothing I do changes this and I mean NOTHING. Well unless I turn off the computer
I'm not using the PCI card at thks time, decided to go back to the onboard port for awhile.
I have the cable connecting the c10 breakout board which is connected to the keling 4030's which are connected to the motors.
- Thank you received: 4994
Do the other pins change? ie is it only 1-6 that are stuck? If so then I would suspect a hardware fault.
If the other pins don't work either, then I suspect you still haven't got the parport base address right.
What does dmesg say? What does cat /proc/ioports say?
- submicro
submicro@submicro-desktop:~$ cat /proc/ioports
0000-001f : dma1
0020-0021 : pic1
0040-0043 : timer0
0050-0053 : timer1
0060-0060 : keyboard
0064-0064 : keyboard
0070-0073 : rtc0
0080-008f : dma page reg
00a0-00a1 : pic2
00c0-00df : dma2
00f0-00ff : fpu
0170-0177 : 0000:00:11.1
0170-0177 : pata_via
01f0-01f7 : 0000:00:11.1
01f0-01f7 : pata_via
0201-0201 : ns558-pnp
0290-0297 : pnp 00:03
02f8-02ff : serial
0330-0331 : MPU401 UART
0376-0376 : 0000:00:11.1
0376-0376 : pata_via
0378-037f : hal_parport
03c0-03df : vga+
03f6-03f6 : 0000:00:11.1
03f6-03f6 : pata_via
03f8-03ff : serial
0400-047f : 0000:00:11.0
0400-047f : pnp 00:02
0400-0403 : ACPI PM1a_EVT_BLK
0404-0405 : ACPI PM1a_CNT_BLK
0408-040b : ACPI PM_TMR
0420-0423 : ACPI GPE0_BLK
04d0-04d1 : pnp 00:03
0500-050f : 0000:00:11.0
0500-050f : pnp 00:02
0500-0507 : vt596_smbus
0800-0805 : pnp 00:03
0cf8-0cff : PCI conf1
c000-cfff : PCI Bus 0000:01
c000-c0ff : 0000:01:00.0
d000-d01f : 0000:00:0a.0
d000-d01f : EMU10K1
d400-d407 : 0000:00:0a.1
d400-d407 : emu10k1-gp
d800-d81f : 0000:00:0b.0
d800-d81f : uhci_hcd
dc00-dc1f : 0000:00:0b.1
dc00-dc1f : uhci_hcd
ec00-ec0f : 0000:00:11.1
ec00-ec0f : pata_via
[ 0.000000] allocated 2620800 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 495588k/524224k available (4539k kernel code, 27896k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xe07f0000 - 0xff7fe000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdfff0000 ( 511 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=128, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2788.541 MHz processor.
[ 0.004006] Calibrating delay loop (skipped), value calculated using timer frequency.. 5577.08 BogoMIPS (lpj=11154164)
[ 0.004031] Security Framework initialized
[ 0.004060] AppArmor: AppArmor initialized
[ 0.004071] Mount-cache hash table entries: 512
[ 0.004249] Initializing cgroup subsys ns
[ 0.004256] Initializing cgroup subsys cpuacct
[ 0.004265] Initializing cgroup subsys memory
[ 0.004279] Initializing cgroup subsys devices
[ 0.004284] Initializing cgroup subsys freezer
[ 0.004288] Initializing cgroup subsys net_cls
[ 0.004324] CPU: Trace cache: 12K uops, L1 D cache: 16K
[ 0.004330] CPU: L2 cache: 1024K
[ 0.004334] CPU: Hyper-Threading is disabled
[ 0.004339] mce: CPU supports 4 MCE banks
[ 0.004354] CPU0: Thermal monitoring enabled (TM1)
[ 0.004367] Performance Events: no PMU driver, software events only.
[ 0.004378] Checking 'hlt' instruction... OK.
[ 0.021449] SMP alternatives: switching to UP code
[ 0.035428] Freeing SMP alternatives: 31k freed
[ 0.035452] ACPI: Core revision 20090903
[ 0.048006] ACPI: setting ELCR to 0200 (from 0a20)
[ 0.049737] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.049745] ftrace: allocating 21003 entries in 42 pages
[ 0.064073] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.064078] weird, boot CPU (#0) not listed by the BIOS.
[ 0.064080] SMP motherboard not detected.
[ 0.064091] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.068001] SMP disabled
[ 0.068001] Brought up 1 CPUs
[ 0.068001] Total of 1 processors activated (5577.08 BogoMIPS).
[ 0.068001] CPU0 attaching NULL sched-domain.
[ 0.068001] devtmpfs: initialized
[ 0.068001] regulator: core version 0.5
[ 0.068001] NET: Registered protocol family 16
[ 0.068001] EISA bus registered
[ 0.068001] ACPI: bus type pci registered
[ 0.068603] PCI: PCI BIOS revision 2.10 entry at 0xfbb20, last bus=1
[ 0.068607] PCI: Using configuration type 1 for base access
[ 0.069777] bio: create slab <bio-0> at 0
[ 0.070615] ACPI: EC: Look up EC in DSDT
[ 0.080345] ACPI: Interpreter enabled
[ 0.080349] ACPI: (supports S0 S5)
[ 0.080367] ACPI: Using PIC for interrupt routing
[ 0.088582] ACPI: No dock devices found.
[ 0.088734] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.088800] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xe8000000-0xe9ffffff]
[ 0.089202] pci 0000:00:01.0: supports D1
[ 0.089261] pci 0000:00:0a.0: reg 10 io port: [0xd000-0xd01f]
[ 0.089360] pci 0000:00:0a.1: reg 10 io port: [0xd400-0xd407]
[ 0.089491] pci 0000:00:0b.0: reg 20 io port: [0xd800-0xd81f]
[ 0.089529] pci 0000:00:0b.0: supports D1 D2
[ 0.089533] pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.089539] pci 0000:00:0b.0: PME# disabled
[ 0.089605] pci 0000:00:0b.1: reg 20 io port: [0xdc00-0xdc1f]
[ 0.089640] pci 0000:00:0b.1: supports D1 D2
[ 0.089643] pci 0000:00:0b.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.089649] pci 0000:00:0b.1: PME# disabled
[ 0.089692] pci 0000:00:0b.2: reg 10 32bit mmio: [0xea100000-0xea1000ff]
[ 0.089750] pci 0000:00:0b.2: supports D1 D2
[ 0.089753] pci 0000:00:0b.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.089759] pci 0000:00:0b.2: PME# disabled
[ 0.089859] pci 0000:00:11.0: quirk: region 0400-047f claimed by vt8235 PM
[ 0.089865] pci 0000:00:11.0: quirk: region 0500-050f claimed by vt8235 SMB
[ 0.089952] pci 0000:00:11.1: reg 20 io port: [0xec00-0xec0f]
[ 0.090074] pci 0000:01:00.0: reg 10 32bit mmio pref: [0xe0000000-0xe7ffffff]
[ 0.090083] pci 0000:01:00.0: reg 14 io port: [0xc000-0xc0ff]
[ 0.090092] pci 0000:01:00.0: reg 18 32bit mmio: [0xea020000-0xea02ffff]
[ 0.090114] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.090142] pci 0000:01:00.0: supports D1 D2
[ 0.090195] pci 0000:00:01.0: bridge io port: [0xc000-0xcfff]
[ 0.090202] pci 0000:00:01.0: bridge 32bit mmio: [0xea000000-0xea0fffff]
[ 0.090209] pci 0000:00:01.0: bridge 32bit mmio pref: [0xe0000000-0xe7ffffff]
[ 0.090220] pci_bus 0000:00: on NUMA node 0
[ 0.090228] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.138452] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 10 *11 12)
[ 0.138723] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 10 11 12) *5
[ 0.138997] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 11 12) *5
[ 0.139270] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 *11 12)
[ 0.139497] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.139715] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.139932] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.140159] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.140482] ACPI: PCI Interrupt Link [ALKA] (IRQs 20) *0, disabled.
[ 0.140743] ACPI: PCI Interrupt Link [ALKB] (IRQs *21), disabled.
[ 0.141008] ACPI: PCI Interrupt Link [ALKC] (IRQs *22), disabled.
[ 0.141313] ACPI: PCI Interrupt Link [ALKD] (IRQs *23), disabled.
[ 0.141449] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.141453] vgaarb: loaded
[ 0.141642] SCSI subsystem initialized
[ 0.141727] libata version 3.00 loaded.
[ 0.141826] usbcore: registered new interface driver usbfs
[ 0.141850] usbcore: registered new interface driver hub
[ 0.141887] usbcore: registered new device driver usb
[ 0.142078] ACPI: WMI: Mapper loaded
[ 0.142083] PCI: Using ACPI for IRQ routing
[ 0.142264] NetLabel: Initializing
[ 0.142267] NetLabel: domain hash size = 128
[ 0.142270] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.142289] NetLabel: unlabeled traffic allowed by default
[ 0.142335] Switching to clocksource tsc
[ 0.144001] AppArmor: AppArmor Filesystem Enabled
[ 0.144001] pnp: PnP ACPI init
[ 0.144001] ACPI: bus type pnp registered
[ 0.148953] pnp: PnP ACPI: found 15 devices
[ 0.148957] ACPI: ACPI bus type pnp unregistered
[ 0.148963] PnPBIOS: Disabled by ACPI PNP
[ 0.148980] system 00:00: iomem range 0xcd000-0xcffff has been reserved
[ 0.148987] system 00:00: iomem range 0xf0000-0xf7fff could not be reserved
[ 0.148992] system 00:00: iomem range 0xf8000-0xfbfff could not be reserved
[ 0.148996] system 00:00: iomem range 0xfc000-0xfffff could not be reserved
[ 0.149000] system 00:00: iomem range 0x1fff0000-0x1fffffff could not be reserved
[ 0.149005] system 00:00: iomem range 0xffff0000-0xffffffff has been reserved
[ 0.149009] system 00:00: iomem range 0x0-0x9ffff could not be reserved
[ 0.149013] system 00:00: iomem range 0x100000-0x1ffeffff could not be reserved
[ 0.149018] system 00:00: iomem range 0xfec00000-0xfec00fff has been reserved
[ 0.149022] system 00:00: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.149026] system 00:00: iomem range 0xfff80000-0xfffeffff has been reserved
[ 0.149036] system 00:02: ioport range 0x400-0x47f has been reserved
[ 0.149040] system 00:02: ioport range 0x500-0x50f has been reserved
[ 0.149048] system 00:03: ioport range 0x4d0-0x4d1 has been reserved
[ 0.149053] system 00:03: ioport range 0x800-0x805 has been reserved
[ 0.149057] system 00:03: ioport range 0x290-0x297 has been reserved
[ 0.183847] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.183853] pci 0000:00:01.0: IO window: 0xc000-0xcfff
[ 0.183860] pci 0000:00:01.0: MEM window: 0xea000000-0xea0fffff
[ 0.183866] pci 0000:00:01.0: PREFETCH window: 0xe0000000-0xe7ffffff
[ 0.183888] pci 0000:00:01.0: setting latency timer to 64
[ 0.183895] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.183899] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.183903] pci_bus 0000:01: resource 0 io: [0xc000-0xcfff]
[ 0.183907] pci_bus 0000:01: resource 1 mem: [0xea000000-0xea0fffff]
[ 0.183910] pci_bus 0000:01: resource 2 pref mem [0xe0000000-0xe7ffffff]
[ 0.183960] NET: Registered protocol family 2
[ 0.184088] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.184509] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.184612] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.184714] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.184717] TCP reno registered
[ 0.184804] NET: Registered protocol family 1
[ 0.184831] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.184899] pci 0000:01:00.0: Boot video device
[ 0.185154] Scanning for low memory corruption every 60 seconds
[ 0.185274] audit: initializing netlink socket (disabled)
[ 0.185289] type=2000 audit(1308179598.181:1): initialized
[ 0.193561] Trying to unpack rootfs image as initramfs...
[ 0.202157] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.207629] VFS: Disk quotas dquot_6.5.2
[ 0.207707] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.208506] fuse init (API version 7.13)
[ 0.208627] msgmni has been set to 968
[ 0.214173] alg: No test for stdrng (krng)
[ 0.214287] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.214293] io scheduler noop registered
[ 0.214296] io scheduler anticipatory registered
[ 0.214299] io scheduler deadline registered
[ 0.214355] io scheduler cfq registered (default)
[ 0.214515] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.214553] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.214662] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.214669] ACPI: Power Button [PWRB]
[ 0.214734] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 0.214744] ACPI: Sleep Button [SLPB]
[ 0.214830] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.214835] ACPI: Power Button [PWRF]
[ 0.216929] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.217043] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.217147] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.217573] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.217749] 00:09: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.219219] brd: module loaded
[ 0.219860] loop: module loaded
[ 0.219977] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.220834] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
[ 0.220839] PCI: setting IRQ 11 as level-triggered
[ 0.220848] pata_acpi 0000:00:11.1: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 0.220855] pata_acpi 0000:00:11.1: VIA VLink IRQ fixup, from 255 to 11
[ 0.220944] pata_acpi 0000:00:11.1: PCI INT A disabled
[ 0.221424] Fixed MDIO Bus: probed
[ 0.221481] PPP generic driver version 2.4.2
[ 0.221536] tun: Universal TUN/TAP device driver, 1.6
[ 0.221539] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.221691] isapnp: Scanning for PnP cards...
[ 0.229715] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.229745] ehci_hcd 0000:00:0b.2: PCI INT C -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 0.229768] ehci_hcd 0000:00:0b.2: EHCI Host Controller
[ 0.229811] ehci_hcd 0000:00:0b.2: new USB bus registered, assigned bus number 1
[ 0.229876] ehci_hcd 0000:00:0b.2: irq 11, io mem 0xea100000
[ 0.277453] ehci_hcd 0000:00:0b.2: USB 2.0 started, EHCI 1.00
[ 0.277610] usb usb1: configuration #1 chosen from 1 choice
[ 0.277667] hub 1-0:1.0: USB hub found
[ 0.277683] hub 1-0:1.0: 4 ports detected
[ 0.277755] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.277776] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.278485] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11
[ 0.278492] uhci_hcd 0000:00:0b.0: PCI INT A -> Link[LNKC] -> GSI 11 (level, low) -> IRQ 11
[ 0.278503] uhci_hcd 0000:00:0b.0: UHCI Host Controller
[ 0.278560] uhci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
[ 0.278589] uhci_hcd 0000:00:0b.0: irq 11, io base 0x0000d800
[ 0.278711] usb usb2: configuration #1 chosen from 1 choice
[ 0.278749] hub 2-0:1.0: USB hub found
[ 0.278762] hub 2-0:1.0: 2 ports detected
[ 0.279414] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
[ 0.279420] uhci_hcd 0000:00:0b.1: PCI INT B -> Link[LNKD] -> GSI 11 (level, low) -> IRQ 11
[ 0.279428] uhci_hcd 0000:00:0b.1: UHCI Host Controller
[ 0.279473] uhci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 3
[ 0.279499] uhci_hcd 0000:00:0b.1: irq 11, io base 0x0000dc00
[ 0.279624] usb usb3: configuration #1 chosen from 1 choice
[ 0.279661] hub 3-0:1.0: USB hub found
[ 0.279674] hub 3-0:1.0: 2 ports detected
[ 0.279820] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.285885] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.285900] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.286123] mice: PS/2 mouse device common for all mice
[ 0.286328] rtc_cmos 00:05: RTC can wake from S4
[ 0.286390] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 0.286422] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 0.286589] device-mapper: uevent: version 1.0.3
[ 0.286742] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.286819] device-mapper: multipath: version 1.1.0 loaded
[ 0.286824] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.286982] EISA: Probing bus 0 at eisa.0
[ 0.287024] EISA: Detected 0 cards.
[ 0.287028] cpuidle: using governor ladder
[ 0.287031] cpuidle: using governor menu
[ 0.287594] TCP cubic registered
[ 0.287765] NET: Registered protocol family 10
[ 0.288317] lo: Disabled Privacy Extensions
[ 0.288716] NET: Registered protocol family 17
[ 0.288757] Using IPI No-Shortcut mode
[ 0.288880] registered taskstats version 1
[ 0.289201] rtc_cmos 00:05: setting system clock to 2011-06-15 23:13:19 UTC (1308179599)
[ 0.289206] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.289208] EDD information not available.
[ 0.305927] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.721409] usb 1-3: new high speed USB device using ehci_hcd and address 3
[ 0.893555] isapnp: No Plug & Play device found
[ 0.927060] usb 1-3: configuration #1 chosen from 1 choice
[ 0.987739] Freeing initrd memory: 12829k freed
[ 1.004251] Freeing unused kernel memory: 620k freed
[ 1.005009] Write protecting the kernel text: 4540k
[ 1.005035] Write protecting the kernel read-only data: 1668k
[ 1.035022] udev: starting version 151
[ 1.180066] usb 2-2: new low speed USB device using uhci_hcd and address 2
[ 1.310810] pata_via 0000:00:11.1: version 0.3.4
[ 1.310835] pata_via 0000:00:11.1: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 1.310843] pata_via 0000:00:11.1: VIA VLink IRQ fixup, from 255 to 11
[ 1.311430] Linux agpgart interface v0.103
[ 1.316391] scsi0 : pata_via
[ 1.316651] scsi1 : pata_via
[ 1.322018] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xec00 irq 14
[ 1.322024] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xec08 irq 15
[ 1.322211] agpgart: Detected VIA PM800/PN800/PM880/PN880 chipset
[ 1.325391] agpgart-via 0000:00:00.0: AGP aperture is 32M @ 0xe8000000
[ 1.354772] usb 2-2: configuration #1 chosen from 1 choice
[ 1.438019] [drm] Initialized drm 1.1.0 20060810
[ 1.540658] ata1.00: ATA-6: ST3200822A, 3.01, max UDMA/100
[ 1.540664] ata1.00: 390721968 sectors, multi 16: LBA48
[ 1.556502] ata1.00: configured for UDMA/100
[ 1.556680] scsi 0:0:0:0: Direct-Access ATA ST3200822A 3.01 PQ: 0 ANSI: 5
[ 1.556916] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.557380] sd 0:0:0:0: [sda] 390721968 512-byte logical blocks: (200 GB/186 GiB)
[ 1.557464] sd 0:0:0:0: [sda] Write Protect is off
[ 1.557468] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.557511] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.557737] sda: sda1 sda2 < sda5 >
[ 1.599231] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.720431] ata2.00: ATAPI: LITE-ON CD-RW SOHR-5238S, 4S04, max UDMA/33
[ 1.736315] ata2.00: configured for UDMA/33
[ 1.737690] scsi 1:0:0:0: CD-ROM LITE-ON CD-RW SOHR-5238S 4S04 PQ: 0 ANSI: 5
[ 1.739220] sr0: scsi3-mmc drive: 52x/52x writer cd/rw xa/form2 cdda tray
[ 1.739225] Uniform CD-ROM driver Revision: 3.20
[ 1.739377] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.739465] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.758862] usbcore: registered new interface driver hiddev
[ 1.784378] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:0b.0/usb2/2-2/2-2:1.0/input/input5
[ 1.784521] generic-usb 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:0b.0-2/input0
[ 1.784561] usbcore: registered new interface driver usbhid
[ 1.784566] usbhid: v2.6:USB HID core driver
[ 1.816785] [drm] radeon defaulting to kernel modesetting.
[ 1.816790] [drm] radeon kernel modesetting enabled.
[ 1.816869] radeon 0000:01:00.0: PCI INT A -> Link[LNKA] -> GSI 11 (level, low) -> IRQ 11
[ 1.824503] [drm] radeon: Initializing kernel modesetting.
[ 1.825053] [drm] register mmio base: 0xEA020000
[ 1.825057] [drm] register mmio size: 65536
[ 1.825352] [drm] GPU reset succeed (RBBM_STATUS=0x00000140)
[ 1.825382] agpgart-via 0000:00:00.0: AGP 3.5 bridge
[ 1.825405] agpgart-via 0000:00:00.0: bridge is in legacy mode, falling back to 2.x
[ 1.825416] agpgart-via 0000:00:00.0: putting AGP V2 device into 4x mode
[ 1.825490] radeon 0000:01:00.0: putting AGP V2 device into 4x mode
[ 1.825496] [drm] radeon: VRAM 64M
[ 1.825499] [drm] radeon: VRAM from 0x00000000 to 0x03FFFFFF
[ 1.825502] [drm] radeon: GTT 32M
[ 1.825505] [drm] radeon: GTT from 0xE8000000 to 0xE9FFFFFF
[ 1.825531] [drm] radeon: irq initialized.
[ 1.825761] [drm] Detected VRAM RAM=64M, BAR=128M
[ 1.825768] [drm] RAM width 64bits DDR
[ 1.826031] [TTM] Zone kernel: Available graphics memory: 254680 kiB.
[ 1.826057] [drm] radeon: 64M of VRAM memory ready
[ 1.826061] [drm] radeon: 32M of GTT memory ready.
[ 1.836239] [drm] radeon: cp idle (0x00008080)
[ 1.836285] [drm] Loading R100 Microcode
[ 1.836559] platform radeon_cp.0: firmware: requesting radeon/R100_cp.bin
[ 1.846915] [drm] radeon: ring at 0x00000000E8000000
[ 1.846938] [drm] ring test succeeded in 1 usecs
[ 1.851255] [drm] radeon: ib pool ready.
[ 1.851363] [drm] ib test succeeded in 0 usecs
[ 1.852231] [drm] DFP table revision: 2
[ 1.852503] [drm] Default TV standard: NTSC
[ 1.852508] [drm] 27.000000000 MHz TV ref clk
[ 1.852510] [drm] No TV DAC info found in BIOS
[ 1.852515] [drm] Default TV standard: NTSC
[ 1.852517] [drm] 27.000000000 MHz TV ref clk
[ 1.852594] [drm] Radeon Display Connectors
[ 1.852598] [drm] Connector 0:
[ 1.852601] [drm] VGA
[ 1.852605] [drm] DDC: 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60
[ 1.852607] [drm] Encoders:
[ 1.852610] [drm] CRT1: INTERNAL_DAC1
[ 1.852613] [drm] Connector 1:
[ 1.852615] [drm] DVI-D
[ 1.852617] [drm] HPD1
[ 1.852620] [drm] DDC: 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[ 1.852623] [drm] Encoders:
[ 1.852625] [drm] DFP1: INTERNAL_TMDS1
[ 1.852628] [drm] Connector 2:
[ 1.852630] [drm] S-video
[ 1.852632] [drm] Encoders:
[ 1.852635] [drm] TV1: INTERNAL_DAC2
[ 1.993023] [drm] fb mappable at 0xE0040000
[ 1.993028] [drm] vram apper at 0xE0000000
[ 1.993031] [drm] size 3145728
[ 1.993033] [drm] fb depth is 24
[ 1.993035] [drm] pitch is 4096
[ 1.993533] fb0: radeondrmfb frame buffer device
[ 1.993537] registered panic notifier
[ 1.993547] [drm] Initialized radeon 2.0.0 20080528 for 0000:01:00.0 on minor 0
[ 1.998507] vga16fb: initializing
[ 1.998515] vga16fb: mapped to 0xc00a0000
[ 1.998522] vga16fb: not registering due to another framebuffer present
[ 2.180325] Console: switching to colour frame buffer device 128x48
[ 2.651604] xor: automatically using best checksumming function: pIII_sse
[ 2.668011] pIII_sse : 4511.000 MB/sec
[ 2.668015] xor: using function: pIII_sse (4511.000 MB/sec)
[ 2.688443] device-mapper: dm-raid45: initialized v0.2594b
[ 2.910292] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 10.665598] Adding 1490936k swap on /dev/sda5. Priority:-1 extents:1 across:1490936k
[ 11.161776] udev: starting version 151
[ 12.277244] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 12.425731] usbcore: registered new interface driver cdc_ether
[ 12.454875] gameport: NS558 PnP Gameport is pnp00:0e/gameport0, io 0x201, speed 784kHz
[ 12.474067] usb0: register 'rndis_host' at usb-0000:00:0b.2-3, RNDIS device, c6:b8:47:a2:84:aa
[ 12.474108] usbcore: registered new interface driver rndis_host
[ 12.476491] gameport: EMU10K1 is pci0000:00:0a.1/gameport0, io 0xd400, speed 994kHz
[ 12.496240] psmouse serio1: ID: 10 00 64
[ 12.653324] irda_init()
[ 12.653346] NET: Registered protocol family 23
[ 12.846635] cfg80211: Calling CRDA to update world regulatory domain
[ 12.856358] lp: driver loaded but no devices found
[ 12.958506] usbcore: registered new interface driver rndis_wlan
[ 13.080851] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input6
[ 13.231691] cfg80211: World regulatory domain updated:
[ 13.231698] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 13.231703] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 13.231707] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 13.231711] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 13.231715] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 13.231719] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 13.300285] type=1505 audit(1308179612.510:2): operation="profile_load" pid=642 name="/sbin/dhclient3"
[ 13.301072] type=1505 audit(1308179612.510:3): operation="profile_load" pid=642 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 13.301510] type=1505 audit(1308179612.510:4): operation="profile_load" pid=642 name="/usr/lib/connman/scripts/dhclient-script"
[ 13.302086] type=1505 audit(1308179612.510:5): operation="profile_replace" pid=507 name="/sbin/dhclient3"
[ 13.302894] type=1505 audit(1308179612.510:6): operation="profile_replace" pid=507 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 13.303331] type=1505 audit(1308179612.510:7): operation="profile_replace" pid=507 name="/usr/lib/connman/scripts/dhclient-script"
[ 13.338480] type=1505 audit(1308179612.546:8): operation="profile_replace" pid=673 name="/sbin/dhclient3"
[ 13.339301] type=1505 audit(1308179612.546:9): operation="profile_replace" pid=673 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 13.339750] type=1505 audit(1308179612.546:10): operation="profile_replace" pid=673 name="/usr/lib/connman/scripts/dhclient-script"
[ 14.690747] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
[ 14.690765] EMU10K1_Audigy 0000:00:0a.0: PCI INT A -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11
[ 15.465719] type=1505 audit(1308179614.674:11): operation="profile_load" pid=875 name="/usr/share/gdm/guest-session/Xsession"
[ 16.430015] ppdev: user-space parallel port driver
[ 20.672198] spurious 8259A interrupt: IRQ7.
[ 24.192949] cdrom: sr0: mrw address space DMA selected
[ 24.235841] ISO 9660 Extensions: Microsoft Joliet Level 1
[ 24.262488] ISOFS: changing to secondary root
[ 24.600037] usb0: no IPv6 routers present
[ 130.958350] I-pipe: Domain RTAI registered.
[ 130.958362] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 130.958366] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 130.958374] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 130.958378] PIPELINE layers:
[ 130.958382] e14b2e20 9ac15d93 RTAI 200
[ 130.958386] c085cb20 0 Linux 100
[ 130.993696] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 130.993860] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 130.993868] RTAI[sched]: hard timer type/freq = APIC/8299581(Hz); default timing: periodic; linear timed lists.
[ 130.993873] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2788541000 hz.
[ 130.993876] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 130.994046] RTAI[usi]: enabled.
[ 131.109270] RTAI[math]: loaded.
[ 131.286100] config string '0x378 out '
[ 144.471492] probe_parport 00:0a: disabled
[ 144.591327] RTAI[math]: unloaded.
[ 144.674677] SCHED releases registered named ALIEN RTGLBH
[ 144.689128] RTAI[malloc]: unloaded.
[ 144.788080] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 144.795523] I-pipe: Domain RTAI unregistered.
[ 144.795536] RTAI[hal]: unmounted.
[ 175.878081] I-pipe: Domain RTAI registered.
[ 175.878093] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 175.878096] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 175.878105] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 175.878108] PIPELINE layers:
[ 175.878112] e14b2e20 9ac15d93 RTAI 200
[ 175.878116] c085cb20 0 Linux 100
[ 175.913002] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 175.913159] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 175.913167] RTAI[sched]: hard timer type/freq = APIC/8299581(Hz); default timing: periodic; linear timed lists.
[ 175.913172] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2788541000 hz.
[ 175.913175] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 175.913314] RTAI[usi]: enabled.
[ 176.024807] RTAI[math]: loaded.
[ 176.111189] probe_parport 00:0a: activated
[ 176.120470] config string '0x378 out '
For fun, I just loaded hal_parport at a fictional 0x123 address on my machine. Amongst all the other stuff is
0000-001f : dma1
0123-012a : hal_parport
0378-037a : parport0
So, it seems that hal_parport will load anywhere you tell it to, but that might not be an actual parallel port.
In fact, I am not sure that your parallel port is active. Have you tried enabling it in the BIOS?
- submicro
- submicro
- cncbasher
- Thank you received: 288
ok i'd take it at the moment that if your seeing the voltage alternate on the port , that this is working correctly
i would expect once the c10 is connected that you will not see any voltage swing
did you use stepconf and produce a stepper configuration with only the steppers ?
connect only the steppers at this time , and disable the enable on the c10 or if your stepper drives have an enable wire , disconnect it
can you confirm the c10 is wired as www.kelinginc.net/KL-4030WithC10.pdf
and that the jumper x6 is set to pins 1&2
jumper x4 is set to pins 1&2
jumper x5 at this stage is set to 1 & 2
and finaly the enable pin is jumpered to +5v
where is the 5v supply derived from a pc supply or wall wart etc and is it capable of at least 500ma or more
at this stage leave all other limit switches disconnected at the c10 board
then run the stepconf wizard application from the desktop menu
select kelling 4030 and set stepper step & direction pins , configure pins 1 , 8,9,14,16,17 as unused
i.e only the stepper drives are used
pins are active low for these types of stepper drives , dont forget the step & direction opto + input pins on the stepper drives go to +5v supply of the c10
it is possible to check the drives at this stage , by powering up and breifly shorting out the step pin to gnd of the 5v supply or -ve with a peice of wire , each time you touch the wire the motor will move one step
so a quick on off on off , should see or hear the motor moving a few steps , if you have not already done so
in axis configuration set the driver microstepping to 8 if using default microstepping as drivers are supplied
adjust steps per rev etc to your configuration , and try the test this axis function . see what results you get
Dave
well the pins vary between 1.4 and 2.5vdc while emc is running but no movement
I think you have been leaving out one very important bit of information.
We have been working on the assumption that you have been measuring pin voltages at the DB25 connector on the computer, with no hardware attached.
It seems likely that the problem is actually in your hardware, and all out software suggestions have been misguided.
Can you measure the pin voltages with absolutely nothing connected other than a multimeter?
