Forum Header
stepconf woes..
- submicro
16 Jun 2011 20:47 #10590
by submicro
Replied by submicro on topic Re:stepconf woes..
Incorrect, up until recently I was measuring directly from the cable nothing attached. I just got tired of plugging and unplugging.
I'm unable to get to the shop today, it's raining and my wheelchair gets stuck real easily. So I will get back at it tomorrow. weather permitting!
And I'll do all the suggestions then. Tthanks again for your patience, I know mine is stretched thin
- Mike_Eitel
- Thank you received: 184
17 Jun 2011 07:38 #10595
by Mike_Eitel
Replied by Mike_Eitel on topic Re:stepconf woes..
Hi Submicro
Must not be but:
Some time ago I got crazy with non changing parport signals. Same HW running well before.
What I had done was swoppinf PCI slot.
At the end I played with interrupts in BIOS ... Hopp after a lot of trys everithing worked fine again.
I came to the conclusion that linux/EMC was not writing correctly to te parport modus registers......
Mike
Must not be but:
Mike
- submicro
20 Jun 2011 18:21 #10674
by submicro
How did you fix it?
- submicro
06 Dec 2011 02:05 #15420
by submicro
Solved! turns out it wwas the cable!
Thanks John and everyone who helped.
Time to create page: 0.059 seconds
