Tiny Computer with Printer port
- lucrece_lu
07 Jun 2012 01:15 - 08 Jun 2012 01:29 #20692
by lucrece_lu
Tiny Computer with Printer port was created by lucrece_lu
I am sorry to cause trouble, the original intention is to impress to see you can give me some comments, and I want to listen to everyone's needs, and once again am sorry
Last edit: 08 Jun 2012 01:29 by lucrece_lu.
- ArcEye
- Thank you received: 758
07 Jun 2012 10:24 - 07 Jun 2012 10:46 #20702
by ArcEye
Replied by ArcEye on topic Re:Tiny Computer with Printer port
Hi
Just a note of explanation
lucrece_lu is a company or individual who makes this item in Taiwan
He has advertised it on the Mach forum www.machsupport.com/forum/index.php?acti...u=33091;sa=showPosts as user anthony_lu
along with a video which appears to show it cutting circles in polystyrene using Mach.
No info as to what the processor is. (If it is the Vortex86 processor used by roboard for their robotics controllers, it might be possible to compile a RT kernel for it.)
My suggestion lucrece_lu - install LinuxCNC on it and show us it working ( or send me one and I will have a go! )
Last edit: 07 Jun 2012 10:46 by ArcEye.
- Thank you received: 5002
07 Jun 2012 12:03 #20707
Replied by andypugh on topic Re:Tiny Computer with Printer port
This is blatantly commercial, but the computer is so cute I think I have forgiven him already.
- BigJohnT
- Thank you received: 1176
07 Jun 2012 12:41 #20711
by BigJohnT
Replied by BigJohnT on topic Re:Tiny Computer with Printer port
I think I'll wait and see before thinking of deleting this commercial thread...
- lucrece_lu
08 Jun 2012 01:34 - 08 Jun 2012 01:58 #20736
by lucrece_lu
Replied by lucrece_lu on topic Re:Tiny Computer with Printer port
Last edit: 08 Jun 2012 01:58 by lucrece_lu.
- BigJohnT
08 Jun 2012 10:42 #20743
by BigJohnT
I feel better about this post now...
- ArcEye
08 Jun 2012 15:03 #20757
by ArcEye
Hi lucrece_lu ,
OK you have got our interest.
When you post the video of LinuxCNC working on the box, could you also post a spec sheet for it.
You will need to indicate what the install process was, ie. a straight EMC2 2.3.0 LiveCD creation of a USB thumb-drive and booting from that untouched,
or has it required changes (new rtai kernel, realtime and emc2 re-build or whatever).
Was that latency test shot taken as soon as the dialog appeared, or is it a realistic loaded figure?
You will find a lot of the forum members are far more knowledgeable technically than your average Mach user
and that they are not interested in buying a 'box with promises',
but are open to considering the possibilities raised by a technically sound new piece of hardware.
- lucrece_lu
11 Jun 2012 03:25 - 11 Jun 2012 06:15 #20812
by lucrece_lu
the EMC2 demo video
1. install with liveCD directly no special step, but due the LAN chip is not in standard, so no internet in directl isntall, have to patch kernel or install LAN drive, the patch and driver is available.
2. the demo is use 2nd LPT port, the NCBox can have 2 LPT ports, 1st (port 278) is on rear side (physical) , the 2nd LPT (port 378) is use BIOS simulate to LPT port
3. boot device can be USB or CF card.
4. Any question are welcome.
5. Hardware spec.
CPU : PMX-1000 / Vortex86MX+ (933MHz)
RAM : 1GB DDR2 (on board)
Graphic : Integrated Graphics Chip
LAN : 10/100Mbps (PXE boot supported)
CF Slot x 1
USB : 3 ports (USB 2.0)
Power : DC 8V -24V
Size: 115 x 115 x 35 mm
Weight : 50g
Operation temp : 5 - 50 Deg C
5. Hardware spec.
CF Slot x 1
Power : DC 8V -24V
Weight : 50g
Last edit: 11 Jun 2012 06:15 by lucrece_lu.
- BigJohnT
13 Jul 2012 20:33 #21923
by BigJohnT
How many watts of power does the computer need?
- lucrece_lu
14 Jul 2012 02:04 #21932
by lucrece_lu
around 10 watts
Time to create page: 0.080 seconds
