Tiny Computer with Printer port
- tkamsker
- Thank you received: 5
07 Apr 2013 17:38 #32371
by tkamsker
Replied by tkamsker on topic Running a machine with the NCBOX
Hi,.
finnaly it was the card .
i now have followed and used the files (thanks a lot arceye )
so i can build the new kernel then i have internet
i can build linuxcnc 2.5.2 but ,,.
both together dont work
any hint what i did wrong ?
Where does the 2.5.2 check the kernel versio n?
here some photos ?
Any hint welcome if someone would point me towards the solution would be fine
thx thomas
here some photos ?
thx thomas
- ArcEye
- Thank you received: 758
07 Apr 2013 22:05 - 07 Apr 2013 22:08 #32384
by ArcEye
Replied by ArcEye on topic Running a machine with the NCBOX
Hi
Glad you are making progress.
If you build a new rtai kernel, you must then build realtime (magma) against it, and then build linuxcnc against them both.
The error you had was because the linuxcnc build you used, was built against 2.6.24-16-rtai (the stock 8.04 kernel) and you were running a different kernel (the 2.6.30-rtai one?)
Either you are running the wrong kernel or are trying to access the wrong linuxcnc build
I don't know exactly what you have done, my original scripts etc built 2.5.1 as a RIP build in /usr/src/build
You would need to cd to /usr/src/build,
run . ./scripts/rip-environment from there
and then call linuxcnc to run the RIP build.
i can build linuxcnc 2.5.2 but both together dont work
any hint what i did wrong ? Where does the 2.5.2 check the kernel versio n?
Last edit: 07 Apr 2013 22:08 by ArcEye.
- ArcEye
14 Apr 2013 22:09 - 14 Apr 2013 22:09 #32728
by ArcEye
An update re the previous
I spoke to tkamsker off forum and hopefully his build is now sorted.
I have updated the build script to download and build linuxcnc-2.5.2 now
The key thing to grasp if you are installing my packages, is that they leave the original Live CD install of 8.04 with the 2.6.24-rtai kernel untouched, so that it will still run as previously
The linuxcnc 2.5.2 build is done as a Run In Place build to be run when using the 2.6.30-rtai kernel
If you are running the 2.6.24 kernel, just run linuxcnc from a terminal or the menu.
If you are running the 2.6.30 kernel, you must open a terminal
cd /usr/src/build,
and then call linuxcnc from within that terminal session (not from the menu or another terminal)
cd /usr/src/build,
Last edit: 14 Apr 2013 22:09 by ArcEye.
- ArcEye
03 May 2013 17:20 #33556
by ArcEye
Update regards previous
Thomas has now succeeded in building a RIP versions and an installed user version of Linuxcnc on his NCBOX
One of the big stumbling points was that magma now appears to have changed with all the recent updates concentrating on the 3.5.7 kernel, in a way that has broken it for
the 2.6.30 kernel
Fortunately I had retained the compiled version of magma from my initial tests and he was able to install realtime using that.
Those files and a howto from Thomas are on my webpage along with the other downloads
myweb.tiscali.co.uk/drahthaar/CNC/
the 2.6.30 kernel
- submicro
03 Jun 2013 00:14 - 03 Jun 2013 00:15 #35149
by submicro
Replied by submicro on topic Running a machine with the NCBOX
ArcEye
The following Links not working on your download page.
README - General overview and instructions for process- - read and follow instructions first
stage1 - script to install kernel headers, images and modules and set up ready to boot new kernel
I'm a bit confused, where to start?
Robert
Robert
Last edit: 03 Jun 2013 00:15 by submicro.
- ArcEye
03 Jun 2013 12:56 #35167
by ArcEye
I changed servers, some of the links obviously got orphaned, I'll look at it later.
The first place to start is to install 8.04 Live CD onto a CF card and get that working. (see the early stages of the post)
The scripts etc are about replacing with a better rtai kernel and later linuxcnc, but you have to get it working with 8.04 first
- ArcEye
03 Jun 2013 22:50 #35197
by ArcEye
Hi
I don't know what is wrong with the links, the other 2 files are at the same locations and work, those don't
Attached is a zip of the files, I will correct the links when I work out what is wrong
- submicro
04 Jun 2013 03:51 #35227
by submicro
Thanks ArcEye
The readme was whatI was needing, Gotta RTFM
Submicro
Submicro
- submicro
19 Jun 2013 04:30 - 19 Jun 2013 04:34 #35794
by submicro
Replied by submicro on topic Re:Tiny Computer with Printer port
"( Set the installation to boot from the MBR of the CF card not hd0 or you will overwrite your machines MBR! )
/boot/grub/menu.lst edited to correct the root address"
Could you explain how you did this?
Never mind figured it out!
Last edit: 19 Jun 2013 04:34 by submicro.
- submicro
20 Jun 2013 05:36 - 20 Jun 2013 05:47 #35820
by submicro
I'm getting stuck on stage2 I can't get my wifi adapter to work so it can't download necessary files! At least I think that's the problem???
When I type in the ./stage2 it spits out a bunch of complaints about unable to get certain files.
Any ideas on how to get my usb wifi adapter to work?
Robert
Robert
Last edit: 20 Jun 2013 05:47 by submicro.
Time to create page: 0.173 seconds
