Tiny Computer with Printer port
22 Jul 2012 15:32 - 01 Aug 2012 16:49 #22319 by ArcEye
Post and links withdrawn - superseded by impending post
Last edit: 01 Aug 2012 16:49 by ArcEye.
22 Jul 2012 18:09 #22323 by BigJohnT
Replied by BigJohnT on topic Re:Running Linuxcnc 2.5 on 10.04 on the NCBOX
I ran into a couple of snags for me. My computer that has a CF card reader in it won't boot from 8.04. I created a 8.04 LiveCd and the NCBOX won't boot from the USB stick. I get a BusyBox ... and a prompt (imitramgs) if I try and install or I try to just test.
I might have another CF reader somewhere...
23 Jul 2012 08:40 #22335 by ArcEye
Hi John
I presume you are trying to install 8.04, seems the best choice.
The initramfs image from 2.6.24 doesn't work properly with the box without the BIOS changes, it can't resolve the root device, either as a UUID or a /dev/sda1 notation.
There are two possible solutions for you, both require the same start.
Boot the box and immediately press and hold the [delete] key, you will enter BIOS setup
Make the changes as per section 3) of my 8.04 instructions
If you have the original CF card installation still intact you can upgrade that
Re-boot and hold down the [Escape] key to get into the GRUB menu.
(you need to have a PS2 plugged keyboard or a USB one with a PS2 adaptor because USB is not recognised at that stage)
When in the GRUB menu, select the rtai kernel, which should now boot.
After that you can follow load the tarballs and follow the instructions
If you just have your USB stick, that should likewise now boot (so long as you remove the CF card or change the boot order in BIOS)
and you can continue from there.
23 Jul 2012 11:20 #22338 by BigJohnT
Replied by BigJohnT on topic Re:Running Linuxcnc 2.5 on 8.04 on the NCBOX
If I recall correctly the original is still on the CF card.
I did the bios changes before trying to install the 8.04 LiveCD.
I'll be able to try your changes when I get back to the shop later this morning.
Thanks for all your work on this.
23 Jul 2012 13:18 #22340 by ArcEye
You had me doubting myself, so I went back into BIOS and reverted the settings to original.
That does not boot 2.6.24-16-rtai and drops into busybox shell
Changed IDE Operate Mode to Native Mode and still did not boot
Change Standard IDE Compatible to Enabled and it booted
Typically I had made 2 changes at once when I originally tested it, looks like only the second was needed, but just in case it needs the combination of the 2, do both.
Its a long time since I immersed myself in the minutiae of the linux boot sequence.
What I imagine is happening is, that with the default IDE settings, that kernel cannot probe IDE and discover what devices are available in order to build the devices in /dev
Then when it hits the root=xxx location, it cannot find the specified drive.
The error you get is something like 'device xxxxxxxxxxxx does not exist in /dev/disk/by-uuid/' which fits.
I may have given you a duff steer there, seem to recall that whilst it had the 2.6.24-16-rtai kernel on it, it did not in fact have the realtime files or emc2.
You could put them on, but would probably be easier to do an install from the Live CD to CF card, by whatever method and start from there.
23 Jul 2012 17:57 #22352 by BigJohnT
So far the only thing that I can make work is to boot on the Ubuntu 8.04 kernel 2.6.30-vortex86xAPM.
Booting from the thumb drive with the 8.04 LiveCD fails and gives me the busybox.
Interesting that when I opened up the synaptic package manager and went to resources > third party software and what do I find but www.linuxcnc.org/emc2/breezy emc2.1!
So I guess the big hurdle is getting the real time kernel installed.
25 Jul 2012 15:39 - 01 Aug 2012 14:46 #22460 by ArcEye
Hi
Today received the .configs and patches used by Anthony's engineer to build the 2.6.32-vortex86-sg-rtai kernel for the NCBOX, enabling Ubuntu 10.04 to run Linuxcnc.
Hoped they might be able to be tweaked to improve latency
The kernel patch for vortex is pretty much about updating the PCI IDs so that the chips are recognised and nothing to be done with that.
The kernel .config was very similar to the one I made myself in testing, no SMP, 486 instruction set used.
The only extra thing I did was to disable all the power management functions.
I rebuilt the kernel, realtime and a RIP of emc2-2.5~pre to test.
The results were quite disappointingly similar, indeed worse regards the servo thread.
base thread max jitter about 8% better at 27657 servo thread - awful at 344466
This all just goes to evidence that the NCBOX runs far better (very well actually) with the earlier 2.6.24 kernel on Ubuntu 8.04,
probably irrespective of whether you are using a stepper based machine or not.
Last edit: 01 Aug 2012 14:46 by ArcEye.
02 Aug 2012 10:31 #22668 by ArcEye
Hi
After another week spent compiling kernels and testing resultant re-builds, I have consolidated everything that resulted into one download page
(location subject to change - see below)
The 10.04 install, with the new vortex kernel, does run Linuxcnc, but the latency figures are so poor, especially on servo thread that I have discounted it.
It is the old problem of newer kernels on old type processors, just not running well, even if built as non SMP etc
Accordingly I have posted 2 methods of upgrading the Live CD install of 8.04 with EMC2 2.3
The first replaces the kernel with a 2.6.30-vortex86mx-rtai kernel image I built, which has proper working network
This enables all the other files needed to upgrade, to be downloaded as sources and built.
It builds a RIP install of Linuxcnc 2.5, so that you can still dual boot kernels and use the original install version.
The second uses zips of packages to carry out the upgrade sequence required to change EMC2 2.3 to Linuxcnc 2.5 on a machine without networking
This may be of use to those wishing to do the same on an ordinary computer, in a shop with no network
There is nothing to prevent you doing both procedures and running Linuxcnc 2.5 on both dual booting kernels - that is what I have done
It can all be found at myweb.tiscali.co.uk/drahthaar/CNC / for now
Both kernels will run at between 10 -15K heavily loaded on Base thread and 10 - 50K on servo (the newer kernel is higher than the stock 2.6.24 one)
Both are perfectly usable for software stepper and external card setups, so now I really am going to stop fiddling with kernels etc and actually trial the NCBOX in the workshop!
02 Aug 2012 11:44 #22673 by BigJohnT
Thanks for all your work on this. I'll see if this kernel noob can follow the instructions in a short while.
03 Aug 2012 14:21 #22725 by BigJohnT
I followed the instructions and for some strange reason I upgraded the installed version to 2.5 which won't work with the vortec kernel... dumb mistake. Anyway reading on I ran the rip-environment then ran a latency test. I can't read the numbers well for jitter but servo is 6x,xxx and base is 2x,xxx after a few minutes.
So to run it you have to be su root? So I'm guessing it is not possible to just have a desktop launcher for this?
I'm amazed that the MCBOX didn't come with LinuxCNC installed...
Time to create page: 0.111 seconds
