Computer to run Linux CNC
- Thank you received: 5336
A RPI 4 is another option
Also HP 8300 USDTs have a (very quiet) fan but are small and fast and work well
with LinuxCNC and are available in the $100 region with 4 to 8G of RAM and a good
sized hard drive.
- BeagleBrainz
- Visitor
I left mine on for about a month over the summer (+40'C alot of days)vand never had a heat issue, when idle nor when machining, and this is with the board in a 1U case.
- raychar
Are all the previous issues of it with Mesa card 7i96e to run Linux CNC resolved?
- bbsr_5a
- Thank you received: 106
lots of older D525MW available in Australia as they come of the postal service centersI know they a little difficult to get in Australia, NIC to access my home network as the on board one is connected to my 7i92.
- BeagleBrainz
- Visitor
None on ebay au. Only listings are international.
And FFS if you are going to quote a post of mine don't edit it so it make no [insert_string_of_aussie_expletives] sense.
And if I wanted to run a Atom I have a Atomic Pi and a Acer Aspire One at hand.....and neither are what you would call fantastic.
What issues?
- raychar
on the host, but this is identical to x86 systems. The RPI4 is comparable speed wise with
J1900/J3455 systems but its Ethernet is not fast enough to run a 1 KHz servo thread
reliably. I will run a 500 Hz servo thread which is fine for most stepper motor lathe and mill
applications. The "smoothness" of the motion is not related to latency, as long as the servo
thread scheduling is always met with some margin (say no more than 1 ms latency on a 2 ms servo thread)
- Clive S
- Thank you received: 486
Damn you beat me to it. I posted about that little beastie the other day. Interested in to see how it goes.
That's why I bought it. I watched the vid Although I have never dual booted before I would like to try it with win10 and linuxcnc. I will have to wait as the shipping is 20-30 days
- raychar
Hm! Still not have much confident but i really want to get it a try...
