Hardware latency tests, used PC's
- garja
- Thank you received: 9
24 May 2024 16:14 #301325
by garja
Replied by garja on topic Hardware latency tests, used PC's
Thanks Tommy... I'll give it a try.
- garja
24 May 2024 17:21 #301336
by garja
I checked the settings you listed above. I was able to find everything you listed except hyper-threading. Under Advanced; CPU configuration, I only have the following:
Active Processor Cores (All)
Intel Virtualization Technology (Disabled)
Vt-d (Enabled)
Intel Text Support (Disabled)
SW Guard Extensions (Enabled)
Enhanced Speedstep (Enabled)
Turbo Mode (Disabled)
Package C State Limit (Auto)
The active core options I have is All, 1, 2 or 3. Would it help to reduce the number of cores?
Vt-d (Enabled)
- Thank you received: 7485
24 May 2024 17:31 #301337
You can certainly give it a try and see how it influences latency.
Replied by tommylight on topic Hardware latency tests, used PC's
Reducing the number of cores might help but would make the PC sluggish to some degree.Vt-d (Enabled) ==== disable
Package C State Limit (Auto) ===== can this be disabled or turned off?
The following user(s) said Thank You: garja
- Thank you received: 5328
24 May 2024 20:38 #301354
Replied by PCW on topic Hardware latency tests, used PC's
also disable Enhanced Speedstep
- royka
- Thank you received: 135
24 May 2024 22:56 #301362
by royka
Replied by royka on topic Hardware latency tests, used PC's
Somehow with my mini pc with a N100 cpu I had a better result with turbo enabled, so that is something you could try. Sometimes a newer kernel version can help. This one works well with that mini pc:
drive.google.com/drive/folders/1L28lG0zD...2XQJx?usp=drive_link
- ississ
- Thank you received: 28
29 May 2024 09:22 #301738
by ississ
Replied by ississ on topic Hardware latency tests, used PC's
Please tell the exact maker/model of the pc.Somehow with my mini pc with a N100 cpu I had a better result with turbo enabled, so that is something you could try. Sometimes a newer kernel version can help. This one works well with that mini pc:
- royka
29 May 2024 09:46 #301739
by royka
At that moment the cheapest Chinese model: Firebat T8 plus LPDDR 5 16gb
30 Aug 2025 00:56 #334141
HP Z600 WorkStation
forum.linuxcnc.org/18-computer/57073-hp-...or-use-with-linuxcnc
