- Thank you received: 9
Hardware latency tests, used PC's
- garja
2 years 5 months ago #301325
by garja
Replied by garja on topic Hardware latency tests, used PC's
Thanks Tommy... I'll give it a try.
- garja
2 years 5 months ago #301336
by garja
I checked the settings you listed above. I was able to find everything you listed except hyper-threading. Under Advanced; CPU configuration, I only have the following:
Active Processor Cores (All)
Intel Virtualization Technology (Disabled)
Vt-d (Enabled)
Intel Text Support (Disabled)
SW Guard Extensions (Enabled)
Enhanced Speedstep (Enabled)
Turbo Mode (Disabled)
Package C State Limit (Auto)
The active core options I have is All, 1, 2 or 3. Would it help to reduce the number of cores?
Vt-d (Enabled)
- Thank you received: 7491
2 years 5 months ago #301337
You can certainly give it a try and see how it influences latency.
Replied by tommylight on topic Hardware latency tests, used PC's
Reducing the number of cores might help but would make the PC sluggish to some degree.Vt-d (Enabled) ==== disable
Package C State Limit (Auto) ===== can this be disabled or turned off?
The following user(s) said Thank You: garja
- Thank you received: 5334
2 years 5 months ago #301354
Replied by PCW on topic Hardware latency tests, used PC's
also disable Enhanced Speedstep
- royka
- Thank you received: 135
2 years 5 months ago #301362
by royka
Replied by royka on topic Hardware latency tests, used PC's
Somehow with my mini pc with a N100 cpu I had a better result with turbo enabled, so that is something you could try. Sometimes a newer kernel version can help. This one works well with that mini pc:
drive.google.com/drive/folders/1L28lG0zD...2XQJx?usp=drive_link
- ississ
- Thank you received: 28
2 years 5 months ago #301738
by ississ
Replied by ississ on topic Hardware latency tests, used PC's
Please tell the exact maker/model of the pc.Somehow with my mini pc with a N100 cpu I had a better result with turbo enabled, so that is something you could try. Sometimes a newer kernel version can help. This one works well with that mini pc:
Time to create page: 0.134 seconds
