Parallel Port Tester
6 years 2 months ago #179698 by Todd Zuercher
Replied by Todd Zuercher on topic Parallel Port Tester
If your pc only has 1 parallel port, have you tried just using the line
loadrt hal_parport cfg="0"
Or if you have 2 ports you might need to use
loadrt hal_parport cfg="1"
to access the "other" port.
6 years 2 months ago #179699 by Todd Zuercher
What does the following command show at a command line?
cat /proc/ioports |grep parport
6 years 2 months ago #179702 by shortcircuit48
Replied by shortcircuit48 on topic Parallel Port Tester
Only have one parallel port
~$ loadrt hal_parport cfg="0"
bash: loadrt: command not found
hamish@hamish-HP-500B-Microtower:~$ sudo loadrt hal_parport cfg="0"
[sudo] password for hamish:
sudo: loadrt: command not found
hamish@hamish-HP-500B-Microtower:~$ cat /proc/ioports |grep parport
Looks like I have a problem with commands. Will look in "packages"?
6 years 2 months ago #179739 by tommylight
Replied by tommylight on topic Parallel Port Tester
shortcircuit48 wrote: hamish@hamish-HP-500B-Microtower:~$ cat /proc/ioports |grep parport
That means no parallel port !
Did you try lspci -v on Mint 20?
6 years 2 months ago #179759 by shortcircuit48
I have reinstalled Mint 20 and have as yet to install cnc. From lspci -v I get
03:04.0 Parallel controller: Device 1c00:2170 (rev 0f) (prog-if 01 [BiDir])
Subsystem: Device 1c00:2170
Flags: medium devsel, IRQ 10
I/O ports at ec00
I/O ports at e880
Which suggest there is a parport.
Will try later today. Thanks
6 years 2 months ago #179796 by shortcircuit48
I cleaned system out and installed Mint 20 Ulyana along with 2.8test, which appear ok. Latency test has come down but appears a bit high.
I have run the parport tester but it still fails to find port with
Note: Using POSIX realtime
config string '0xec00 out'
Linux parallel port @60416 not found
When I run lspci - vv I get
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 10
Region 0: I/O ports at ec00
Region 1: I/O ports at e880
Does this suggest I do have a parport?
Thanks for help
Time to create page: 0.459 seconds
