Parallel Port Tester
1 year 7 months ago #325410 by ContinenteCNC
Replied by ContinenteCNC on topic Parallel Port Tester
If anyone needs, these are my custom parallel port tester hal files for IN, and X modes.
1 year 7 months ago #325422 by ContinenteCNC
If anyone needs [2] a simple circuit to test parallel port pin by pin as either input or output, this is good solution.
No ICs and no transistors required.
More about here:  forum.linuxcnc.org/18-computer/55803-a-s...el-port-tester-board
1 year 2 months ago - 1 year 2 months ago #333127 by juergen-home
Replied by juergen-home on topic Parallel Port Tester
I have altered the parallel port tester to test the DB25 "parallel" port of my mesa 6i25 which is used with a cheap "China BOB Mach3".
File Name: ptest-mesa...DB25.zip
File Size:1.61 KB
File Name: ptest_6i25...tton.zip
File Size:1.89 KB
Last edit: 1 year 2 months ago by juergen-home. Reason: + attachment customized with checkbuttons + attached 2 screenshots
The following user(s) said Thank You: andypugh
Time to create page: 0.327 seconds
