Parallel Port Tester
6 years 2 months ago #179819 by tommylight
Replied by tommylight on topic Parallel Port Tester
shortcircuit48 wrote: config string '0xec00 out'
Region 0: I/O ports at ec00
Region 1: I/O ports at e880
try
'0 out'
instead of the port address, then if that does not work try
config string '0xe880 out'
Restart the PC between tries.
6 years 2 months ago #179827 by shortcircuit48
Replied by shortcircuit48 on topic Parallel Port Tester
When I used"0 out" I now get
Note: Using POSIX non-realtime
config string '0 out'
Linux parallel port #0 not found
hal_parport: rtapi_app_main: No such file or directory (-2)
ptest.hal:1: waitpid failed /usr/bin/rtapi_app hal_parport
ptest.hal:1: /usr/bin/rtapi_app exited without becoming ready
ptest.hal:1: insmod for hal_parport failed, returned -1
halcmd:
Using"0xe880" was as previously listed
6 years 2 months ago #179829 by tommylight
Picture of the parallel port card where the chip can be clearly seen ?
Not from the internet, take a picture of your card.
6 years 2 months ago - 6 years 2 months ago #179834 by shortcircuit48
Hopefully I can attach pictures
Attachment not found
I despair
There is a single chip, CH351Q
Last edit: 6 years 2 months ago by shortcircuit48.
6 years 2 months ago - 6 years 2 months ago #179837 by shortcircuit48
6 years 2 months ago #179838 by shortcircuit48
Time to create page: 0.316 seconds
