Parallel Port Tester
6 years 2 months ago #178920 by tommylight
Replied by tommylight on topic Parallel Port Tester
That is old, so most of the issues are due to very limited RAM memory.
As for the parallel port, just have a look on the back side, there should be a female DB25 connector, violet colour, it is the biggest connector on the back.
6 years 2 months ago #178921 by shortcircuit48
Replied by shortcircuit48 on topic Parallel Port Tester
Yes , there was one card and I added another, neither of which were violet in colour. I think I will look for a replacement either new or from ebay. I have noted a thread on this topic and will now read through it. I did increase RAM but will find out to what.
6 years 2 months ago - 6 years 2 months ago #179678 by shortcircuit48
Back again. I now have a HP 500B MT desktop. My first problem came as it only had one port able to take the parallel port card and this was occupied by an Ethernet card even although there was an onboard Ethernet connection. After much trial and error freed up the port and internet now connected to onboard. Parallel port card now fitted and if enter lspci --vv the card appears with port reference. I change the reference in the tester but port is not found when attempting to run.
Screen shot
03:04.0 Parallel controller: Device 1c00:2170 (rev 0f) (prog-if 01 [BiDir])
Subsystem: Device 1c00:2170
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 10
Region 0: I/O ports at ec00
Region 1: I/O ports at e880
hamish@debian:~/Downloads$ halrun -I -f ptest.hal
Note: Using POSIX realtime
config string '0xec00 out'
Linux parallel port @60416 not found
I am sure it must be simple but any advise would be appreciated.
Last edit: 6 years 2 months ago by shortcircuit48.
6 years 2 months ago #179688 by Todd Zuercher
Replied by Todd Zuercher on topic Parallel Port Tester
Did you try it with the 0xe880 address?
6 years 2 months ago #179691 by shortcircuit48
Yes. Have just this moment installed Mint 20 and now going to follow procedure to install.
Thanks will keep you updated
6 years 2 months ago #179697 by shortcircuit48
That is Linuxcnc now running on Mint 20 which was no bother to install following instructions. Unfortunately I still can not get ptest to work as it still cant find port. Ahead but no further forward.
Time to create page: 0.369 seconds
