Parallel Port Tester
14 years 2 months ago #23623 by Tonico
Replied by Tonico on topic Re:Parallel Port Tester
Thanks for the reply. Unfortunately it did not help. The address in the Hal file is in fact the same as the port (onboard parallel port)
Is there anything that I need to do or set up BEFORE I run the test?
TIA
Tony
14 years 2 months ago - 14 years 2 months ago #23634 by BigJohnT
Replied by BigJohnT on topic Re:Parallel Port Tester
Are you running this on a computer with LinuxCNC installed via the LiveCD?
It should just work...
Are both files in the same directory?
Did you open the files with a windoze editor that might have tacked on some funny stuff to the end of each line?
Last edit: 14 years 2 months ago by BigJohnT.
14 years 2 months ago #23639 by Todd Zuercher
Here's the corrected X-mode ptest files. I fell pray to windows scrambling the xml file when I posted from my windows machine.
File Name: ptest-b452...b853.zip
File Size:1.21 KB
14 years 2 months ago #23641 by Tonico
Yes it was installed from a Live CD 8.04 -
Yes both files in the same directory
Downloaded directly to the Linux box and used "text editor" to verify the port address.
Tony
14 years 2 months ago #23642 by Tonico
Tried it does exactly the same thing.
Tony
14 years 2 months ago #23647 by andypugh
Replied by andypugh on topic Re:Parallel Port Tester
Tonico wrote:
" Waiting for component 'PortTest' to become ready" a bunch of dots and than halcmd: I also get a new blank window called PortTest.,
Does anything else work?
Can you run Axis using one off the sim configurations?
Time to create page: 0.157 seconds
