Can't get lathe to Feed
07 Jul 2021 18:16 #213981 by rider-83
Replied by rider-83 on topic Can't get lathe to Feed
Andy, I've got lost in my own threads. This is the project (Boxford) were you recommended a sensor from RS and I wired it to one input pin ( '10' on my 2nd LPT ) . We then combined the two signals (A & Z) to this pin.
If I remember correctly I think you guided me to some script were I could past it into my .HAL
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
07 Jul 2021 18:22 #213982 by andypugh
Replied by andypugh on topic Can't get lathe to Feed
Can you attach your current HAL?
07 Jul 2021 19:11 #213983 by rider-83
# BOXFORD B160TCL WITH ATC #
loadrt [KINS]KINEMATICS
#autoconverted trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt stepgen step_type=0,0,0,0
loadrt pwmgen output_type=1
addf pwmgen.make-pulses base-thread
addf stepgen.update-freq servo-thread
###########PARALLEL PORT############
loadrt hal_parport cfg="0x378 0xdcc8"
setp parport.0.reset-time 200
setp parport.1.reset-time 200
addf parport.1.read base-thread
addf parport.1.write base-thread
addf parport.1.reset base-thread
# DEFINE SPINDLE #
net spindle-cmd-rpm => pwmgen.0.value
net spindle-on <= spindle.0.on => pwmgen.0.enable
net spindle-pwm <= pwmgen.0.pwm
setp pwmgen.0.pwm-freq 50
setp pwmgen.0.scale 3000
#setp pwmgen.0.offset -0.0220338983051
#setp pwmgen.0.dither-pwm true
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs
net spindle-cw <= spindle.0.forward
net coolant-flood <= iocontrol.0.coolant-flood
# SPINDLE ENCODER SYNCHRONISATION #
#Add Encoder detail
loadrt encoder
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
# set the HAL encoder to 100 pulses per revolution.
setp encoder.3.position-scale 100
#set the HAL encoder count mode
setp encoder.0.counter-mode 1
# connect the HAL encoder outputs to LinuxCNC.
net spindle-position encoder.0.position-interpolated => spindle.0.revs
net spindle-velocity encoder.0.velocity => spindle.0.speed-in
net spindle-index-enable encoder.0.index-enable <=> spindle.0.index-enable
#Connect HAL Encoder to Parallel Port
net pulse-index-combined parport.1.pin-10-in encoder.0.phase-A encoder.0.phase-Z
#SPINDLE AT SPEED DETAIL
# load a near component and attach it to a thread
loadrt near
addf near.0 servo-thread
# connect one input to the commanded spindle speed
net spindle-cmd => near.0.in1
# connect one input to the encoder-measured spindle speed
net spindle-velocity => near.0.in2
# connect the output to the spindle-at-speed input
net spindle-at-speed spindle.0.at-speed <= near.0.out
# set the spindle speed inputs to agree if within 1%
setp near.0.scale 1.01
# DEFINE D25 PINS #
net coolant-flood => parport.0.pin-01-out
setp parport.0.pin-01-out-invert 1
net xstep => parport.0.pin-02-out
net xdir => parport.0.pin-03-out
setp parport.0.pin-02-out-reset 1
net ystep => parport.0.pin-04-out
net ydir => parport.0.pin-05-out
setp parport.0.pin-04-out-reset 1
net zstep => parport.0.pin-06-out
net zdir => parport.0.pin-07-out
setp parport.0.pin-06-out-reset 1
net astep => parport.0.pin-08-out
net adir => parport.0.pin-09-out
setp parport.0.pin-08-out-reset 1
net spindle-pwm => parport.0.pin-14-out
net spindle-on => parport.0.pin-16-out
net spindle-cw => parport.0.pin-17-out
setp parport.0.pin-16-out-invert 1
# EMERGENCY STOP #
net estop-ext <= parport.0.pin-10-in-not
net estop-ext => iocontrol.0.emc-enable-in
# SET UP HOME & LIMITS #
net min-home-x joint.0.neg-lim-sw-in <= parport.0.pin-11-in-not
net min-home-x => joint.0.home-sw-in <= parport.0.pin-11-in-not
net min-home-z joint.2.neg-lim-sw-in <= parport.0.pin-12-in-not
net min-home-z => joint.2.home-sw-in <= parport.0.pin-12-in-not
#SET UP EXTERNAL HOME BUTTON#
net home-all halui.home-all <= parport.0.pin-13-in
# SET UP EXTERNAL CYCLESTART BUTTON #
net cycle-start-btn halui.program.run <= parport.0.pin-15-in
# DEFINE AXIS #
# X-AXIS #
setp stepgen.0.position-scale [JOINT_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 34000
setp stepgen.0.dirsetup 34000
setp stepgen.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net xpos-cmd joint.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => joint.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable joint.0.amp-enable-out => stepgen.0.enable
# Y-AXIS #
setp stepgen.1.position-scale [JOINT_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 34000
setp stepgen.1.dirsetup 34000
setp stepgen.1.maxaccel [JOINT_0]STEPGEN_MAXACCEL
net ypos-cmd joint.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => joint.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable joint.1.amp-enable-out => stepgen.1.enable
# Z-AXIS #
setp stepgen.2.position-scale [JOINT_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 34000
setp stepgen.2.dirsetup 34000
setp stepgen.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL
net zpos-cmd joint.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => joint.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable joint.2.amp-enable-out => stepgen.2.enable
# A-AXIS #
setp stepgen.3.position-scale [JOINT_3]SCALE
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 0
setp stepgen.3.dirhold 34000
setp stepgen.3.dirsetup 34000
setp stepgen.3.maxaccel [JOINT_3]STEPGEN_MAXACCEL
net apos-cmd joint.3.motor-pos-cmd => stepgen.3.position-cmd
net apos-fb stepgen.3.position-fb => joint.3.motor-pos-fb
net astep <= stepgen.3.step
net adir <= stepgen.3.dir
net aenable joint.3.amp-enable-out => stepgen.3.enable
# TOOL CHANGE SECTION #
#MY ADAPTATION OF ATC
#net tool-number <= iocontrol.0.tool-prep-number
#net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
#net tool-change-loopback iocontrol.0.tool-change => iocontrol.0.tool-changed
#MANUAL CHANGE
#loadusr -W hal_manualtoolchange
#net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
#net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
#net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
#AUTOMATIC
#loadrt toolchanger
#addf toolchanger servo-thread
#net tool-change iocontrol.0.tool-change => toolchanger.toolchange
#net tool-changed iocontrol.0.tool-changed <= toolchanger.toolchanged
#net tool-number iocontrol.0.tool-prep-number => toolchanger.toolnumber
#net tool-oldnumber iocontrol.0.tool-number => toolchanger.currenttoolnumber
#net apos-cmd toolchanger.position-cmd => stepgen.3.position-cmd
#net ahomed joint.3.homed => toolchanger.ishomed
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
07 Jul 2021 19:26 #213985 by andypugh
I think that you just need to change:
to
setp encoder.0.position-scale 100
07 Jul 2021 19:34 #213987 by rider-83
Andy,
That seemed to work, but this has appeared:
custom_postgui.hal:4: signal 'spindle-at-speed' already has writer(s)
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
07 Jul 2021 20:16 #213990 by andypugh
Hmm, so what is in the custom_postgui file? (That's an unusual place to define spindle-at-speed)
08 Jul 2021 17:52 #214040 by rider-83
I've had a look inside custom_postgui file and found something naughty in there.
The system now comes up. I'm going to do some stuff to test things out.
08 Jul 2021 18:17 - 08 Jul 2021 18:17 #214043 by rider-83
So I've run a few simple tests.
Command      Actual
S100             103RPM
S500             445 RPM
S1000           1062RPM
S2000           2270RPM
S3000           2920RPM
Also, no feed movements (G1) in G95 (Feed per Rev)
Last edit: 08 Jul 2021 18:17 by rider-83.
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
09 Jul 2021 12:01 #214084 by andypugh
You need spindle,0,revs and spindle.0.speed-in connected to the spindle encoder.
linuxcnc.org/docs/2.8/html/man/man9/moti....html#SPINDLE%20PINS
I thought that there was a specific section on spindle synched motion, but I confess that I can not find it.
06 Aug 2021 17:22 #217064 by rider-83
I'm loosing the will to live here. I'm trying to find out what it is I'm supposed to do with those two commands you have stated, but I can't find any useful help.
Where do I need to look on how to set this up ?
Time to create page: 0.548 seconds
