Can't get lathe to Feed
- Thank you received: 4654
23 Aug 2021 13:52 #218507
Replied by andypugh on topic Can't get lathe to Feed
You might need to update.
But, first, comment-out the line, start linuxcnc, then open a terminal andto see if the pin exists.
halcmd show pin *encoder*Please Log in or Create an account to join the conversation.
- rider-83
- Thank you received: 10
15 Sep 2021 17:30 - 15 Sep 2021 18:35 #220720
by rider-83
Replied by rider-83 on topic Can't get lathe to Feed
Well, I've done that , but I'm not sure what I'm looking for. A ton of stuff comes up for 'encoder.0'.
If I'm looking for 'missing-teeth' , then its not there. Did earlier versions of 2.9 not have this Pin ?
Last edit: 15 Sep 2021 18:35 by rider-83.
- rider-83
16 Sep 2021 12:41 #220792
by rider-83
I've updated from pre0.3825 to .4616
No the whole thing no longer works at all
All sorts of errors relating gmoccapy
- rider-83
16 Sep 2021 13:51 #220795
by rider-83
Can anyone help ??
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0-pre0-4616-g4cca8d4a2
Machine configuration directory is '/home/boxford/linuxcnc/configs/lathe'
Machine configuration file is 'lathe.ini'
INIFILE=/home/boxford/linuxcnc/configs/lathe/lathe.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=gmoccapy
COORDINATES=X Z
KINEMATICS=trivkins coordinates=XZ
Starting LinuxCNC...
Found file(REL): ./lathe.hal
Found file(REL): ./custom.hal
Starting DISPLAY program: gmoccapy
task: main loop took 0.123324 seconds
Found an error!
The following information may be useful in troubleshooting:
File "/usr/lib/python3/dist-packages/gladevcp/iconview.py", line 188, in __init__
pixbuf = Gtk.IconTheme.get_default().load_icon("gtk-quit", 48, 0)
gi.repository.GLib.GError: gtk-icon-theme-error-quark: Icon 'gtk-quit' not present in theme Tango (0)
'IconFileSelection' object has no attribute 'store'
'IconFileSelection' object has no attribute 'iconView'
'IconFileSelection' object has no attribute 'on_btn_jump_to'
Icon from stock
0 = /usr/bin/gmoccapy
1 = -ini
2 = /home/boxford/linuxcnc/configs/lathe/lathe.ini
Entry = trivkins
Entry = coordinates=XZ
found the following coordinates xz
**** GMOCCAPY GETINIINFO ****
Number of joints = 2
2 COORDINATES found = xz
joint 0 = axis x
joint 1 = axis z
{0: 'x', 1: 'z'}
[KINS] KINESTYPE is trivkins
No MIN_ANGULAR_VELOCITY entry found in [DISPLAY] of INI file
Using default value of 0.1 degree / min
No DEFAULT_ANGULAR_VELOCITY entry found in [DISPLAY] of INI file
Using default value of 360 degree / min
No MAX_ANGULAR_VELOCITY entry found in [DISPLAY] of INI file
Using default value of 3600 degree / min
No MAX_RAPID_OVERRIDE entry found in [DISPLAY] of INI file
Default settings 100 % applied!
Preference file path: /home/boxford/linuxcnc/configs/lathe/lathe.pref
No DEFAULT_SPINDLE_SPEED entry found in [DISPLAY] of INI file
**** GMOCCAPY INFO ****
**** no valid probe config in INI File ****
**** disabled tool measurement ****
**** Entering make_DRO
axis_list =
**** Entering make ref axis button
Filepath = /usr/share/gmoccapy/images/ref_all.png
get button with image
Filepath = /usr/share/gmoccapy/images/ref_x.png
Filepath = /usr/share/gmoccapy/images/ref_z.png
Filepath = /usr/share/gmoccapy/images/unhome.png
**** Entering make touch button
**** Entering make jog increments
**** Entering make jog button
**** Entering make macro button
found 0 Macros
**** we have a lathe here
False
**** arrange DRO
3
**** Place in table
**** get DRO order
**** arrange JOG button
**** Invalid embedded tab configuration ****
**** No tabs will be added! ****
**** no audio available! ****
**** PYGST libray not installed? ****
**** is python-gstX.XX installed? ****
**** Entering init gremlin ****
Kinematics type changed
_set_enable_tooltips = True
Found an error!
File "/usr/bin/gmoccapy", line 5299, in <module>
app = gmoccapy(sys.argv)
File "/usr/bin/gmoccapy", line 328, in __init__
self._init_IconFileSelection()
File "/usr/bin/gmoccapy", line 2101, in _init_IconFileSelection
self.widgets.IconFileSelection1.show_filelabel(False)
File "/usr/lib/python3/dist-packages/gladevcp/iconview.py", line 404, in show_filelabel
self.file_label.hide()
AttributeError: 'IconFileSelection' object has no attribute 'file_label'
Jog Pin Changed
x+
Jog Button released = x+
Jog Pin Changed
x-
Jog Button released = x-
Jog Pin Changed
z+
Jog Button released = z+
Jog Pin Changed
z-
Jog Button released = z-
on tool chnage
_kill_dynamic_childs
task: 2667 cycles, min=0.000015, max=0.123324, avg=0.010126, 1 latency excursions (> 10x expected cycle time of 0.010000s)
config string '0 out'
Debug file information:
Note: Using POSIX realtime
Waiting for component 'inihal' to become ready...
(gmoccapy:760): Gtk-WARNING **: 14:48:04.765: Invalid icon size 48
(gmoccapy:760): Gtk-WARNING **: 14:48:04.779: Invalid icon size 48
/usr/bin/gmoccapy:717: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: wiki.gnome.org/PyGObject/InitializerDeprecations
lbl = Gtk.Label("")
/usr/bin/gmoccapy:735: DeprecationWarning: Gtk.Image.set_from_stock is deprecated
image.set_from_stock(stock, 48)
/usr/bin/gmoccapy:896: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: wiki.gnome.org/PyGObject/InitializerDeprecations
btn = Gtk.ToggleButton(_(" edit\noffsets"))
/usr/bin/gmoccapy:900: DeprecationWarning: Gtk.Widget.modify_bg is deprecated
btn.modify_bg(Gtk.StateFlags.ACTIVE, Gdk.color_parse("#FFFF00"))
/usr/bin/gmoccapy:944: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: wiki.gnome.org/PyGObject/InitializerDeprecations
btn = Gtk.Button(_("zero\n G92"))
/usr/bin/gmoccapy:959: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: wiki.gnome.org/PyGObject/InitializerDeprecations
btn = Gtk.Button(_(" set\nselected"))
/usr/bin/gmoccapy:1168: PyGTKDeprecationWarning: Using positional arguments with the GObject constructor has been deprecated. Please specify keyword(s) for "label" or use a class specific constructor. See: wiki.gnome.org/PyGObject/InitializerDeprecations
btn = Gtk.Button(name.upper())
/usr/bin/gmoccapy:1374: DeprecationWarning: Gtk.Table.resize is deprecated
self.widgets.tbl_jog_btn_axes.resize(3,3)
(gmoccapy:760): Gtk-WARNING **: 14:48:07.020: Invalid icon size 48
(gmoccapy:760): Gtk-WARNING **: 14:48:07.021: Invalid icon size 48
727
757
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Thu 16 Sep 14:48:58 BST 2021
UTC Date: Thu 16 Sep 13:48:58 UTC 2021
this program: /usr/bin/linuxcnc_info
uptime: 14:48:58 up 2 min, 1 user, load average: 0.65, 0.57, 0.24
lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/boxford/linuxcnc/configs/lathe
USER: boxford
LOGNAME: boxford
HOME: /home/boxford
EDITOR:
VISUAL:
LANGUAGE: en_GB:en
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1024x768 pixels (270x203 millimeters)
PATH: /usr/bin:/home/boxford/linuxcnc/configs/lathe/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: debian
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.19.194-3 (2021-07-18)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-17-rt-amd64 root=UUID=b6a2426d-e685-4d59-bacc-3bb3bddf73f7 ro initrd=/install/gtk/initrd.gz quiet
model name: Intel(R) Core(TM)2 Duo CPU E4500 @ 2.20GHz
cores: 2
cpu MHz: 2018.098
parport: 0000-0000 : parport0 0000-0000 : parport0 0000-0000 : parport1 0000-0000 : parport1
serial: 0000-0000 : serial 0000-0000 : serial
Versions:
gcc: gcc (Debian 8.3.0-6) 8.3.0
python: Python 3.7.3
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: glade 3.22.1
linuxcnc_var all:
LINUXCNCVERSION: 2.9.0-pre0-4616-g4cca8d4a2
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python3.7
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-cn 1:2.9.0~pre0.4616.g4cca8d4a2 all motion controller for CNC machines and robots (Chinese
ii linuxcnc-doc-en 1:2.9.0~pre0.4616.g4cca8d4a2 all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.9.0~pre0.4616.g4cca8d4a2 all controlador de movimiento para máquinas CNC y robots (Español).
ii linuxcnc-doc-fr 1:2.9.0~pre0.4616.g4cca8d4a2 all motion controller for CNC machines and robots (French documentation)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 1:2.9.0~pre0.4616.g4cca8d4a2 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.9.0~pre0.4616.g4cca8d4a2 amd64 PC based motion controller for real-time Linux
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TASK=milltask
HALUI=
DISPLAY=gmoccapy
COORDINATES=X Z
Found an error!
Icon from stock
1 = -ini
Entry = trivkins
joint 0 = axis x
joint 1 = axis z
{0: 'x', 1: 'z'}
axis_list =
found 0 Macros
False
**** arrange DRO
3
**** Place in table
**** get DRO order
Found an error!
Jog Pin Changed
x+
Jog Pin Changed
x-
Jog Pin Changed
z+
Jog Pin Changed
z-
on tool chnage
lbl = Gtk.Label("")
727
757
pastebin.com
USER: boxford
LOGNAME: boxford
HOME: /home/boxford
EDITOR:
VISUAL:
LANGUAGE: en_GB:en
TERM: dumb
COLORTERM:
DISPLAY: :0.0
uname items:
nodename -n: debian
machine -m: x86_64
/proc items:
cores: 2
cpu MHz: 2018.098
Versions:
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: glade 3.22.1
linuxcnc_var all:
RTS: uspace
- rider-83
19 Sep 2021 13:56 #221087
by rider-83
Andy,
I don't know if you have seen my other thread, but since my latest update in order to obtain 'missing-teeth' I've run into allsorts of frustrating issues with Gmoccapy.
However, that said, I've managed to work out a way to get the system up and test the 'missing-teeth' with a G71 call.
We no longer have the errors reporting missing pins etc, and I can run the CNC program.
The spindle starts but the tool sits there presumably waiting for its strobe signal to start screw cutting. Any ideas?
- virencq
- Thank you received: 5
05 May 2022 06:41 - 05 May 2022 09:40 #242022
by virencq
Replied by virencq on topic Can't get lathe to Feed
I have weared situation. mine G95 working. But at 1200 spindle speed .3 mm/rev, 20 mm dia at 80 SMM. taking 3 minutes to complete 100 mm.
Theoritacly it should complete in 16.67 sec.
Please correct me if I am wrong
Last edit: 05 May 2022 09:40 by virencq.
- virencq
05 May 2022 10:20 - 05 May 2022 14:54 #242029
by virencq
Mission accomplished in 3 hrs.
Last edit: 05 May 2022 14:54 by virencq.
05 May 2022 22:45 #242080
So, perhaps your spindle encoder scale is wrong?
Of you open a halmeter and look at spindle.0.revs, then manually turn the spindle by 1 turn, does it increase by exactly 1.0?
You are not wrong.I have weared situation. mine G95 working. But at 1200 spindle speed .3 mm/rev, 20 mm dia at 80 SMM. taking 3 minutes to complete 100 mm.
The following user(s) said Thank You: virencq
- virencq
07 May 2022 11:09 #242227
by virencq
G95 working, feed and finish ok.
Threading not working as it should be.
- virencq
07 May 2022 11:47 - 07 May 2022 14:34 #242229
by virencq
Andy Sir, as per your suggestions Hal-meter shows 1.05 for 1 complete revolution.
After changing encoder scale 100.000 to 100 now it shows 1 for 1 spindle turn manualy.
From my spindle.hal
that makes my feed mm/rev usable.
But when I run threading macro G76 with 2 mm pitch. threads are very fine.
From my spindle.hal
encoder.0.velocity throws fluctuated numbers in halshow. so I used spindle.0.speed-out-rps with spindle.0.speed-in.
Last edit: 07 May 2022 14:34 by virencq.
