Can't get lathe to Feed
06 Aug 2021 18:11 #217067 by rider-83
Replied by rider-83 on topic Can't get lathe to Feed
In my HAL file (as referenced above) those statements are present.
If I set my scale to 50 still no feed movements in G1
If I swap G95 to G94, still no movements in G1.
What am I doing wrong ?
06 Aug 2021 20:00 #217082 by andypugh
Replied by andypugh on topic Can't get lathe to Feed
I suspect that spindle-at-speed is being too picky. It seems to be set up to accept 1% error, which is probably far too tight.
Change
# set the spindle speed inputs to agree if within 1%
setp near.0.scale 1.01
To
setp near.0.scale 1.333
Also open a halmeter (eg from the "machine" menu in Axis) and watch the signal "spindle-at-speed" and the pin "spindle.0.at-speed"
07 Aug 2021 09:40 - 07 Aug 2021 10:32 #217111 by rider-83
OK, scale is now 1.333
RPM SET TO 500, and M3
Still no feed.
HALMeter shows:
spindle-at-speed =FALSE
spindle.0.at-speed = FALSE
pulse-index-combined = swaps FALSE/TRUE
spindle-velocity  = 8
spindle-cmd-rpm = 500
spindle-cmd = 0
Last edit: 07 Aug 2021 10:32 by rider-83.
07 Aug 2021 14:00 #217119 by rider-83
In an attempt to try and understand,Ive tried a few things:
Should 'spindle-velocity' display (via halmeter) the true RPM?
If so, if I change the scale from 100 to 1.6, then my rpm matches that of the displayed rpm on the drive.
Then if I swap 'net spindle-cmd => near.0.in2' to 'net spindle-cmd-rpm => near.0.in2' then 'spindle.0.at-speed' goes TRUE.
But, still no feed movements,
I'm not saying this is the correct thing to do, but just an effort to track my problem
07 Aug 2021 18:42 #217149 by rider-83
I should very much like to contact the person who has successfully converted this Boxford machine to work with LinuxCNC. It would save me a whole world of frustration.
07 Aug 2021 18:56 #217150 by PCW
Replied by PCW on topic Can't get lathe to Feed
# set the HAL encoder to 100 pulses per revolution.
setp encoder.3.position-scale 100
#set the HAL encoder count mode
setp encoder.0.counter-mode 1
# connect the HAL encoder outputs to LinuxCNC.
net spindle-position encoder.0.position-interpolated => spindle.0.revs
net spindle-velocity encoder.0.velocity => spindle.0.speed-in
net spindle-index-enable encoder.0.index-enable <=> spindle.0.index-enable
#Connect HAL Encoder to Parallel Port
net pulse-index-combined parport.1.pin-10-in encoder.0.phase-A encoder.0.phase-Z
A couple mistakes here
1. You cannot use a combined index-Z/A unless you have 1 count per turn
(index must be 1 count/turn)
2. You are using encoder.0.velocity (which is scaled in RPS) rather than encoder.0.velocity-rpm
08 Aug 2021 12:49 #217218 by rider-83
I'm not sure what my solution is here:
08 Aug 2021 13:49 #217229 by rider-83
Just out of interest, is it possible to use a sensor wheel with only 'one' slot and set the scale to '1'. I'm only asking out of curiosity
08 Aug 2021 14:21 #217232 by PCW
Free up a  parallel port input and add an index sensor would be one way.
08 Aug 2021 14:22 #217233 by PCW
Yes, of course this cannot compensate for speed variations during the turn so works better at higher speeds and constant loads
Time to create page: 1.226 seconds
