Axis Position Logger
  • Aciera
  • Administrator
  • Administrator
2 years 7 months ago - 2 years 7 months ago #296115 by Aciera
Replied by Aciera on topic Axis Position Logger
I renamed this to 'lcnc_logger' and put this on my GitHub page so it does not interfere with the original version:
github.com/Sigma1912/lcnc_logger
Also I added 'motion.digital-out-xx' and 'motion.analog-out-xx' as possible log triggers:
Last edit: 2 years 7 months ago by Aciera.
The following user(s) said Thank You: jurod, tommylight, partec, Tchefter, besriworld, jimmyrig, cakeslob, Ehsan_R
1 year 9 months ago - 1 year 9 months ago #318939 by Ehsan_R
Replied by Ehsan_R on topic Axis Position Logger
How can I add lcnc_logger to the user interface?
[code]EMBED_TAB_NAME = lcnc_logger MBED_TAB_LOCATION = ntb_user_tabs EMBED_TAB_COMMAND = gladevcp -c gladevcp -u lcnc_logger.py -H manual-example.hal lcnc_logger.ui
[/code]
Last edit: 1 year 9 months ago by Ehsan_R.
  • Aciera
  • Administrator
  • Administrator
1 year 9 months ago #318943 by Aciera
Not sure but I doubt it's possible to embed a PyQt window in gmoccapy.
1 year 5 months ago #327518 by fery15sty
Replied by fery15sty on topic Axis Position Logger
how to run lcnc_logger? what to add in .ini file?
  • Aciera
  • Administrator
  • Administrator
1 year 5 months ago #327524 by Aciera
you need to execute 'lcnc_logger.py' with linuxcnc running. This can also be done using a custom mcode as outlined here (note that the file has since been renamed to 'lcnc_logger.py') :
forum.linuxcnc.org/21-axis/30986-axis-po...gger?start=60#294514
The following user(s) said Thank You: fery15sty
1 year 5 months ago #327988 by fery15sty
can this g2/g3 line use radius type R and not use i, j, k?
Time to create page: 0.278 seconds
