Kinematics... again:/
9 years 5 months ago #92736
Replied by andypugh on topic Kinematics... again:/
"Inside the source tree" would mean downloading all of the LinuxCNC source (which is
here
) and putting your new kinematics file in src/emc/kinematics with all the other kinematics files. You would then need to compile the whole of LinuxCNC. (Actually I am sure there is a way to only compile the bits you want, but I don't know it)
"Outside the source tree" means that the file can be anywhere you want, as long as it is in the same directory where you call the halcompile command from.
You won't get a new configuration, you will only get a new executable file called robotkins.ko or robotkins.so in the /usr/bin/ folder.
If you have halcompile then I think you already have linuxcnc-dev (and it looks like you do have halcompile).
if "ls" shows robotkins.c but "halcompile --install robotkins.c" says that the file doesn't exist, then I am a bit puzzled.
Actually, I am a lot puzzled.
The following user(s) said Thank You: Boogie
- Thank you received: 4153
9 years 5 months ago - 9 years 5 months ago #92738
Replied by rodw on topic Kinematics... again:/
from the same folder, try
sudo hal compile --install ./robotkins.c
Not saying it will work but sometimes it helps...
./ says look in the current folder. Maybe its got confused and is looking in roots home folder instead of yours.
Last edit: 9 years 5 months ago by rodw.
- Boogie
- Thank you received: 9
9 years 5 months ago #92751
by Boogie
Replied by Boogie on topic Kinematics... again:/
Unfortunatelly i'm away from my linuxcnc computer but after carefully reading your advices guys i found one little thing at the begining that might be important:) the kinematics file from you Andy IS NOT robotkins.c but robokins.c ...
I'll try halcompile again tomorrow morning.
- Boogie
9 years 5 months ago - 9 years 5 months ago #92765
by Boogie
Progress with no errors:
bogicnc@bogicnc:~/Downloads$ sudo halcompile --install robokins.c
[sudo] password for bogicnc:
make KBUILD_EXTRA_SYMBOLS=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/Module.symvers -C /usr/src/linux-headers-3.4-9-rtai-686-pae SUBDIRS=`pwd` CC=gcc V=0 modules
make[1]: Entering directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
CC [M] /tmp/tmpAwBFRa/robokins.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/tmpAwBFRa/robokins.mod.o
LD [M] /tmp/tmpAwBFRa/robokins.ko
make[1]: Leaving directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
cp robokins.ko /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/
Thanks to the above a new real time component was created:
/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/robokins.ko
now how can i check what HAL pins are created? How to hook it up to HAL and INI files? Should i use Stepconf Wizard to create some basic configuration folder, i.e. robokins in:
/home/myfolder/linuxcnc/configs/robokins/
that contains robokins.hal and robokins.ini files, and then edit them to put D1, D2, and D3 HAL pins (and maybe other HAL pins that are used by robokins kinematics module - again: how to check what pins are created?)?
MODPOST 1 modules
Last edit: 9 years 5 months ago by Boogie.
9 years 5 months ago #92915
Kinematics modules quite often don't create any HAL pins.
it seems that robokins (which is a slightly modified scarakins) creates the pins
scarakins.D1, scarakins.D2 and scarakins.D3.
The description of what these numbers means is part of the source code comments (and seems fairly clear).
So, to use the kins you would replace "loadrt trivkins" with "loadrt robokins" in your INI file, and then use "setp" statements to set the dimensions.
You might prefer to edit robokins to create pins with robokins names.
loadrt robokins
setp scarakins.D1 100
setp ...
- Boogie
9 years 5 months ago #92943
by Boogie
This is what i've done yesterday, well almost. I picked up scara sim configuration. It created it's own folder with HAL, INI and other files in 'configs' in linuxcnc folder. Then i tried to modify INI and HAL by removing 4th and 5th joints and axes. I've changes axis 0 type from ANGULAR to LINEAR. I've placed robokins instead of scarakins...and failed.
I'll try another approach tomorrow morning.
Time to create page: 0.485 seconds
