Kinematics... again:/
9 years 5 months ago #92946 by andypugh
Replied by andypugh on topic Kinematics... again:/
The axes are linear. The joints might be rotary.
Which LinuxCNC version are you using?
When you say "..and failed", how did you fail?
The following user(s) said Thank You: Boogie
9 years 5 months ago #92991 by Boogie
Replied by Boogie on topic Kinematics... again:/
failed - i mean some series of errors popped out on linuxcnc startup.
Axes - linear, joints - angular or linear. Thank you for pointing that out. I meant in INI file there are sections [AXIS_0], [AXIS_1], etc. and type of motion is set there. TYPE = ANGULAR was changed to LINEAR as first joint in robokins is linear. I thought of [AXIS_xxx} as joints as if there is, say, 6 joints so there is 6 [AXIS_xx] sections in INI file.
I believe it is 2.7. I can't check it now:/
9 years 5 months ago #93019 by andypugh
In LinuxCNC v2.8 there are separate sections in the INI for [JOINT_0] and [AXIS_X] for example.
For a non-trivkins robot I strongly suggest using LinuxCNC v2.8, actually.
What errors did you get? You can copy from the error dialog and paste here.
9 years 5 months ago - 9 years 5 months ago #93029 by bkt
Replied by bkt on topic Kinematics... again:/
your robot is on video at first your post?
in these case you need to change your kins. You not can use the robokins .... but you can modify it .... actually (probabily because not read it) axis0 or axis1 not perform the linear movement that see on video ... robokins has 6 rotary axis ... you must add your optional linear axis in these way:
world->d = joint[6]; and world->d = joint[6];
if you not use joint 5 or 4 not connect it at all but insert it on hal and ini file ... simply make it unconnected and perform zero axis on place ....
You have an optional join/axiswhich works in addition to some axis in cartesian world so probabily you must add & subtract it in linear manner (so in these case joint = axis) from x or y or z ... never try to play with robokins so I not know the cartesian axis orientation ... but these is your first kins problem.
Giorgio
Last edit: 9 years 5 months ago by bkt.
9 years 5 months ago #93092 by andypugh
k-1 wrote: your robot is on video at first your post?
in these case you need to change your kins. You not can use the robokins o
I believe that the robokins that I posted was the kinematics used with the actual machine in the video.
9 years 5 months ago #93098 by Boogie
I was given another PC to play with and i'm going to install linuxcnc 2.8 as Andy suggested. It will take some time though. I'm curious about those joints. The joints count used in INI/HAL have to be the same as in kinematics file, right? According to C file (robokins.c) first joint (joint 0) is linear so i thought i have to set it linear in INI file as well.
Mr. K-1: the sentence:
is a mystery for me, firstly b'cause both parts are the same, secondly i thought there are XYZ ABC and UVW coords in cnc world...
Time to create page: 0.145 seconds
