Kinematics... again:/
9 years 5 months ago #92497
Replied by andypugh on topic Kinematics... again:/
Here is a discussion about the kinematics of the actual machine in your first post:
sourceforge.net/p/emc/mailman/emc-users/...ail.com/#msg26845536
Missing from that conversation are several off-list messages that Viesturs and I exchanged. He did get quite a long way down the line of making a version of genserkins that handles sliding joints, I have attached the modified genserkins.c and gensekins.h files that we came up with, but be aware that they don't necessarily work
In the end Viesturs used a modified version of scarakins, called robotkins.c for that welding robot, I have also attached that.
- Boogie
- Thank you received: 9
9 years 5 months ago #92675
by Boogie
Replied by Boogie on topic Kinematics... again:/
How can i thank you for this?
Now i'm reading it and trying to understand what is going on there. It will take same time and i'm sure more questions will arise. C-language file have to be compiled, right? And compillation process will create proper folders and files automatically, right??
9 years 5 months ago #92677
You should be able to compile and install the robotkins.c file using the LinuxCNC Halcompile utility.
linuxcnc.org/docs/2.7/html/hal/comp.html
sudo halcompile --install robotkins.c
- Boogie
9 years 5 months ago #92731
by Boogie
After reading:
i know that the robotkins.c (or other C language files with kinematics) is a real time component and it is to be compiled and installed 'outside the source tree' - but what does it mean 'outside the source tree'? You know the sentences like this make a non-linux user very confused. One is reading things like this and thinks he understand what he is reading but in fact he don't:)
I couldn't find the answer where should i go in the terminal? Should i be in home directory and then issue
sudo halcompile --install custonkim.c or maybe it is no important where am i? Where customkin.c file should be located when issuing halcompile?
Please tell me: after succesful compiling and installation of the new kinematics will there be a new configuration (i.e. 'customkin') available in 'My Configurations' tree in the LinuxCNC Configuration selector window?
Sorry for so newbie questions... it is all Gill Bates from Michaelsoft corp. fault;P
- Boogie
9 years 5 months ago #92734
by Boogie
so far i tried this:
in terminal go to 'Downloads' directory where robotkins.c file was downloaded and say: 'sudo halcompile --install robotkins.c'. The following messages popped out:
bogicnc@bogicnc:~/Downloads$ sudo halcompile --install robotkins.c
[sudo] password for bogicnc:
File "/usr/bin/halcompile", line 1353, in <module>
main()
File "/usr/bin/halcompile", line 1336, in main
shutil.copy(f, tempdir)
File "/usr/lib/python2.7/shutil.py", line 119, in copy
copyfile(src, dst)
File "/usr/lib/python2.7/shutil.py", line 82, in copyfile
with open(src, 'rb') as fsrc:
IOError: [Errno 2] No such file or directory: 'robotkins.c'
what now?
main()
copyfile(src, dst)
what now?
- Boogie
9 years 5 months ago #92735
by Boogie
there is no 'compile' element in /usr/bin folder.
Should i install:
sudo apt-get install linuxcnc-dev
Should i install:
Time to create page: 1.453 seconds
