- Thank you received: 3
[ Vfdmod ] An easy VFD control over MODBUS RTU
- ShemJ
1 year 6 months ago #326438
by ShemJ
Replied by ShemJ on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
I've been having issues with MB2HAL and an L510 VFD rebrand. I was hoping to try VFDMOD but unfortunately, the ARM DEB package is armhf and I am using an Rpi 5.Early days for my linuxCNC'ing, but....Is it possible to repackage for arm64 from 32bit?Also thought I'd attach the wiki here just in case.
1 year 6 months ago - 1 year 6 months ago #326580
Replied by andypugh on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
For the benefit of anyone else using the L510 (or the RS-branded RS510) VFD this component seems to work:
github.com/gitcoffey/l510_vfd
after making this change
github.com/gitcoffey/l510_vfd/pull/1
Install with
Install with
sudo halcompile --userspace --install --extra-link-args="-lm -lmodbus" l510_vfd.c
Last edit: 1 year 6 months ago by andypugh.
- xenon-alien
- Thank you received: 4
10 months 1 day ago #340751
by xenon-alien
Replied by xenon-alien on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
Hello!
Can anybody help me out with this step by step? (I'm not a Linux user)
I have my old setup, but i don't remember how to add Vfdmod to the LCNC, to see the pins and other.
I have now a Buster system with LCNC 2.9.7 and have a "not found file/directory Vfdmod" message.
All old links not works... How to compile it and from where and which file I have no clue...
- nwallace
- Thank you received: 10
10 months 1 day ago #340752
by nwallace
Replied by nwallace on topic [ Vfdmod ] An easy VFD control over MODBUS RTU
Unfortunately Vfdmod is no longer maintained and isn't really a good option for new installs. It was a bit of a pain but I switched to mb2hal. Between the documentation and a few examples I was able to figure it out with some trial and error. I suggest switching to that.
- xenon-alien
10 months 1 day ago - 10 months 1 day ago #340766
by xenon-alien
Can you help me with mb2hal?
Here is my old setup for vfdmod file for Danfoss VLT FC-51
There was only a few commands cw, ccw, stop and frequency.
Last edit: 10 months 1 day ago by xenon-alien.
- nwallace
10 months 13 hours ago #340813
by nwallace
Sorry, I am definitely not an expert in this. You can take a look at my config and the documentation here:
[url] linuxcnc.org/docs/html/drivers/mb2hal.html [/url]
Attached is my mb2hal ini file and the spindle bits from my hal file. I am not an expert but I was able to figure it out just with the VFD manual and the documentation.
The following user(s) said Thank You: xenon-alien
Time to create page: 1.227 seconds
