- Thank you received: 595
Schaublin 125-CNC retrofit.
- RotarySMP
- J Green
- Thank you received: 24
See that ZincBoy has posted the SSR Bd. schematic an parts listed --#201613
One 48 volt centrer tap Xfmr could power the conntactors an also the 24 -12 and 5 volt DC power.
- db1981
- Thank you received: 276
where is 1:2 transmission to get the 3000 upm at the spindle ?
RotarySMP wrote: Getting a 48VAC transformer is not so much the problem, it is that I dont was a whole bunch of them. As it is I will need 24VDC, 12VDC, 5VDC but an get them in DIN rail format and mount them on the back of the door.
On my mill I get the voltages < 24 from a bunch of DC-DC converters.
This style, with digital display of input and output voltages:
Currently three of them, 12V for the PC, 5V for the Mesa cards and 4.2V for the Ikea LED lights.
- RotarySMP
db1981 wrote: hmm,
Electrically switching from 8 pole to 4 poles on the motor.
Mark
- RotarySMP
Thanks, you have posted those before. Look pretty good, and I will consider them, altough Din Rail transformers are now cheap as well, and I wouldn't have to muck around designing and printing a housing.
