- Thank you received: 127
Schaublin 125-CNC retrofit.
- tecno
5 years 7 months ago #201937
by tecno
Lichuan B2
www.93x57r.se/tecno-cnc/CNC3000.html (still not installed :( )
/Bengt
Replied by tecno on topic Schaublin 125-CNC retrofit.
RotarySMP wrote: Thanks, which model number are your drivers?
Mark
Lichuan B2
/Bengt
- Hakan
- Thank you received: 454
5 years 7 months ago - 5 years 7 months ago #201943
by Hakan
Replied by Hakan on topic Schaublin 125-CNC retrofit.
Regarding the Lichuan A4 servo driver - I just installed two of those on my milling machine with 1kW servos.
Speed mode, analog +-10V input. Works just fine as far as I can tell. As is the case with the drives I have used,
speed/position/torque mode and input source are settable through drive registers.
Last edit: 5 years 7 months ago by Hakan.
- Muzzer
- Thank you received: 49
5 years 7 months ago - 5 years 7 months ago #201971
by Muzzer
Replied by Muzzer on topic Schaublin 125-CNC retrofit.
I also have Lichuan A4. I am using step / dir, as I prefer to stay in the digital domain, although they seem to support +/-10V.
The Lichuan B2 appears to support analogue input, too. Would be surprising if they didn't. Are you sure they don't?
servo.xlichuan.com/ProductsStd_207.html
Last edit: 5 years 7 months ago by Muzzer. Reason: typo
- tecno
5 years 7 months ago #202073
by tecno
Yes I am absolutely sure.
Analog is usually +/-10V but B2 is 0-10 + switch to change direction = not fast enough.
- Muzzer
5 years 7 months ago #202080
by Muzzer
That's annoying. I'm glad I didn't go the analogue route. It has to be said, the Lichuans are thin on features compared to the likes of Yaskawa etc and the setup "software" is little more than a parameter table you can configure offline and upload.
As modern drives and controllers are both inherently digital, what is the benefit of going analogue +/-10V? The signals are being converted from digital to analogue at the controller, then back to digital at the servo drives, with the opportunity for noise, delays (filters etc) and offsets along the way.
- RotarySMP
- Thank you received: 595
5 years 7 months ago #202204
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
The guys answered my similar question on Analog v Step/Dir a few pages back.
forum.linuxcnc.org/26-turning/41498-scha...ofit?start=40#200693
The cutting oil used has hardened to a varnish, and glues the ways down pretty well. I am having to break it down further than I hoped, but am very happy with yhat I am finding so far.
Mark
Mark
The following user(s) said Thank You: arvidb, tommylight, Aciera
Time to create page: 0.757 seconds
