Schaublin 125-CNC retrofit.
4 years 5 months ago #243607
Replied by andypugh on topic Schaublin 125-CNC retrofit.
It seems likely:
www.gracesguide.co.uk/L._Gamet_Products
So, started off in France.
The patent makes interesting reading: patents.google.com/patent/US2499640
- RotarySMP
- Thank you received: 595
4 years 4 months ago - 4 years 4 months ago #244606
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Made some decent progress on the reassembly...
Last edit: 4 years 4 months ago by RotarySMP.
The following user(s) said Thank You: arvidb, tommylight, Muzzer, anfänger, spumco, CarterKraft
- arvidb
- Thank you received: 158
4 years 4 months ago #244745
by arvidb
Replied by arvidb on topic Schaublin 125-CNC retrofit.
Nice work! Good catch that you had to prime the pump. I would have had no idea why it didn't work.
I have no real experience with these things, but if it was my beautiful Schaublin I would remove the motor and turn the screw by hand through its full range of motion to feel that everything was alright before applying the full motor torque.
- RotarySMP
4 years 4 months ago - 4 years 4 months ago #244984
by RotarySMP
Good idea. I need to do that.
a few minor steps this week:
The following user(s) said Thank You: arvidb, tommylight, anfänger
- RotarySMP
4 years 3 months ago #247000
by RotarySMP
I dont get it, I have Hall sensors outputting a 4V "High" signal into a 7i84 with the Field voltage set at 5V for that bank, but am not getting a LO-->HI transition in the HALshow. The 7i84 should go high above about 2.6V or so.
Any troubleshooting advice appreciated.
The following user(s) said Thank You: anfänger
- Thank you received: 7491
4 years 3 months ago #247004
Replied by tommylight on topic Schaublin 125-CNC retrofit.
What type of hal sensor?
What output does it have?
Might need a resistor as pull up or pull down.
Some give variable voltage on the output depending on magnetic field.
Moderators: piasdom
Time to create page: 0.271 seconds
